2.1.3 Touch Switch Moduleο
Introductionο
In this project, you will learn about touch switch module. It can replace the traditional kinds of switch with these advantages: convenient operation, fine touch sense, precise control and least mechanical wear.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 2.1.3_TouchSwitch.py
While the code is running, the red LED lights up; when you tap on the touch switch module, the yellow LED turns on.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
# Set #17 as touch switch pin, #22 as led1 pin, #27 as led2 pin
touchPin = 17
led1Pin = 22
led2Pin = 27
# Define a setup function for some setup
def setup():
GPIO.setmode(GPIO.BCM)
# Set touchPin input
# Set ledPin output,
# and initial level to High(3.3v)
GPIO.setup(touchPin, GPIO.IN)
GPIO.setup(led1Pin, GPIO.OUT, initial=GPIO.HIGH)
GPIO.setup(led2Pin, GPIO.OUT, initial=GPIO.HIGH)
# Define a main function for main process
def main():
# touch switch high, led1 on
if GPIO.input(touchPin) == 1:
print ('You touch it!')
GPIO.output(led1Pin, GPIO.LOW)
GPIO.output(led2Pin, GPIO.HIGH)
# touch switch low, led2 on
if GPIO.input(touchPin) == 0:
GPIO.output(led2Pin, GPIO.LOW)
GPIO.output(led1Pin, GPIO.HIGH)
time.sleep(0.5)
# Define a destroy function for clean up everything after
# the script finished
def destroy():
# Turn off LED
# Release resource
GPIO.cleanup()
if __name__ == '__main__':
setup()
main()
# When 'Ctrl+C' is pressed, the program
# destroy() will be executed.
destroy()
Code Explanation
touchPin = 17
led1Pin = 22
led2Pin = 27
touchPin, led1Pin and led2Pin connects to the GPIO17, GPIO22 and GPIO27,
namely BCM17, BCM22 and BCM27.
Set the GPIO modes to BCM Numbering. Set led1Pin, led2Pin to output mode
and initial their level to High (3.3v).
When you tap on the touch switch module, touchPin is high, led1 will light up and print "You touch it!". When touchPin is low, led2 will light up.
