.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _3.1.4_c_pi5_mcp3008: 3.1.4 Smart Fan(MCP3008) ============================ .. note:: .. image:: ../img/mcp3008_and_adc0834.jpg :width: 25% :align: left Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section. Introduction ----------------- In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable. Required Components ------------------------------ In this project, we need the following components. .. image:: ../img/list2_Smart_Fan.png :align: center It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_gpio_board` - |link_gpio_board_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_power_module` - \- * - :ref:`cpn_thermistor` - |link_thermistor_buy| * - :ref:`cpn_l293d` - \- * - :ref:`cpn_mcp3008` - \- * - :ref:`cpn_button` - |link_button_buy| * - :ref:`cpn_motor` - |link_motor_buy| Schematic Diagram ------------------------ ============ ======== ======== === T-Board Name physical wiringPi BCM SPICE0 Pin 24 10 8 SPIMOSI Pin 19 12 10 SPIMISO Pin 21 13 9 SPISCLK Pin 23 14 11 GPIO22 Pin 15 3 22 GPIO5 Pin 29 21 5 GPIO6 Pin 31 22 6 GPIO13 Pin 33 23 13 ============ ======== ======== === .. image:: ../img/schematic_3.1.4_smart_fan_mcp3008.png :align: center Experimental Procedures ----------------------------- **Step 1:** Build the circuit. .. image:: ../img/july24_3.1.4_smart_fan_mcp3008.png :align: center .. note:: The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard. .. image:: ../img/image118.jpeg :align: center **Step 2**: Get into the folder of the code. .. raw:: html .. code-block:: cd ~/raphael-kit/c/3.1.4-2/ **Step 3**: Compile. .. raw:: html .. code-block:: gcc 3.1.4_SmartFan.c -o SmartFan -lwiringPi -lm **Step 4**: Run the executable file above. .. raw:: html .. code-block:: ./SmartFan As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are **5** kinds of speed grades: **0~4**. When set to the 4\ :sup:`th` speed grade and you press the button, the fan stops working with a **0** wind speed. Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`. Code -------- .. code-block:: c #include #include #include #include #include #define SPI_CHANNEL 0 #define SPI_SPEED 1000000 #define MotorPin1 21 #define MotorPin2 22 #define MotorEnable 23 #define BtnPin 3 int read_ADC(int channel) { if (channel < 0 || channel > 7) return -1; unsigned char buffer[3]; buffer[0] = 1; // Start bit buffer[1] = (8 + channel) << 4; // Single-ended mode and channel buffer[2] = 0; wiringPiSPIDataRW(SPI_CHANNEL, buffer, 3); int result = ((buffer[1] & 3) << 8) | buffer[2]; return result; } int temperture() { int analogVal = read_ADC(0); double Vr = 3.3 * analogVal / 1023.0; // Use 3.3V as Vref for MCP3008 double Rt = 10000.0 * Vr / (3.3 - Vr); double temp = 1 / (((log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0))); double cel = temp - 273.15; double Fah = cel * 1.8 + 32; printf("Celsius: %.2f C Fahrenheit: %.2f F\n", cel, Fah); return (int)cel; } int motor(int level) { if (level == 0) { digitalWrite(MotorEnable, LOW); return 0; } if (level >= 4) { level = 4; } digitalWrite(MotorEnable, HIGH); softPwmWrite(MotorPin1, level * 25); return level; } void setup() { if (wiringPiSetup() == -1) { printf("wiringPi setup failed!\n"); return; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("SPI setup failed!\n"); return; } softPwmCreate(MotorPin1, 0, 100); softPwmCreate(MotorPin2, 0, 100); pinMode(MotorEnable, OUTPUT); pinMode(BtnPin, INPUT); } int main(void) { setup(); int currentState, lastState = 0; int level = 0; int currentTemp, markTemp = 0; while (1) { currentState = digitalRead(BtnPin); currentTemp = temperture(); if (currentTemp <= 0) continue; if (currentState == 1 && lastState == 0) { level = (level + 1) % 5; markTemp = currentTemp; delay(500); } lastState = currentState; if (level != 0) { if (currentTemp - markTemp <= -2) { level = level - 1; markTemp = currentTemp; } if (currentTemp - markTemp >= 2) { level = level + 1; markTemp = currentTemp; } } level = motor(level); } return 0; } Code Explanation ---------------------- .. code-block:: c int read_ADC(int channel) { if (channel < 0 || channel > 7) return -1; unsigned char buffer[3]; buffer[0] = 1; // Start bit buffer[1] = (8 + channel) << 4; // Single-ended mode and channel buffer[2] = 0; wiringPiSPIDataRW(SPI_CHANNEL, buffer, 3); int result = ((buffer[1] & 3) << 8) | buffer[2]; return result; } This function is used to read analog input from MCP3008 on the specified channel. It sends a 3-byte SPI command and returns a 10-bit digital value between 0–1023. .. code-block:: c int temperture() { int analogVal = read_ADC(0); double Vr = 3.3 * analogVal / 1023.0; // Use 3.3V as Vref for MCP3008 double Rt = 10000.0 * Vr / (3.3 - Vr); double temp = 1 / (((log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0))); double cel = temp - 273.15; double Fah = cel * 1.8 + 32; printf("Celsius: %.2f C Fahrenheit: %.2f F\n", cel, Fah); return (int)cel; } The ``temperture()`` function reads the thermistor analog signal via MCP3008, calculates voltage, resistance, then converts to Celsius and Fahrenheit using the thermistor formula (Steinhart–Hart approximation). .. code-block:: c int motor(int level) { if (level == 0) { digitalWrite(MotorEnable, LOW); return 0; } if (level >= 4) { level = 4; } digitalWrite(MotorEnable, HIGH); softPwmWrite(MotorPin1, level * 25); return level; } This ``motor()`` function controls fan speed via PWM. Level ranges from 0–4, where 0 turns the fan off and each level increases the duty cycle by 25%. .. code-block:: c void setup() { if (wiringPiSetup() == -1) { printf("wiringPi setup failed!\n"); return; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("SPI setup failed!\n"); return; } softPwmCreate(MotorPin1, 0, 100); softPwmCreate(MotorPin2, 0, 100); pinMode(MotorEnable, OUTPUT); pinMode(BtnPin, INPUT); } The ``setup()`` function initializes WiringPi, sets up SPI, configures PWM and GPIO pins needed for motor control and button input. .. code-block:: c int main(void) { setup(); int currentState, lastState = 0; int level = 0; int currentTemp, markTemp = 0; while (1) { currentState = digitalRead(BtnPin); currentTemp = temperture(); if (currentTemp <= 0) continue; if (currentState == 1 && lastState == 0) { level = (level + 1) % 5; markTemp = currentTemp; delay(500); } lastState = currentState; if (level != 0) { if (currentTemp - markTemp <= -2) { level = level - 1; markTemp = currentTemp; } if (currentTemp - markTemp >= 2) { level = level + 1; markTemp = currentTemp; } } level = motor(level); } return 0; } The ``main()`` function contains the program loop: 1. Constantly checks button state and reads current temperature. 2. On button press, fan level increases (cycles 0–4) and saves temperature. 3. If temperature changes by ±2°C, it auto-adjusts fan speed accordingly. 4. Calls ``motor(level)`` to update PWM output based on current level.
