πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.2.1 Photoresistor
Introduction
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Required Components
../_images/list_2.2.1_photoresistor.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
ADC0834
Photoresistor
Schematic Diagram
../_images/image321.png ../_images/image322.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image198.png
cd ~/raphael-kit/c/2.2.1/
Step 3: Compile the code.
gcc 2.2.1_Photoresistor.c -lwiringPi
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
#include <wiringPi.h>
#include <stdio.h>
#include <softPwm.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define     ADC_CS    0
#define     ADC_CLK   1
#define     ADC_DIO   2
#define     LedPin    3
    uchar i;
    uchar dat1=0, dat2=0;
    int sel = channel > 1 & 1;
    int odd = channel & 1;
    digitalWrite(ADC_CLK, 1);
    delayMicroseconds(2);
    digitalWrite(ADC_CLK, 0);
    pinMode(ADC_DIO, OUTPUT);
    digitalWrite(ADC_CS, 0);
    // Start bit
    digitalWrite(ADC_CLK,0);
    digitalWrite(ADC_DIO,1);    delayMicroseconds(2);
    digitalWrite(ADC_CLK,1);    delayMicroseconds(2);
    //Single End mode
    // ODD
    digitalWrite(ADC_DIO,odd);  delayMicroseconds(2);
    //Select
    digitalWrite(ADC_DIO,sel);    delayMicroseconds(2);
    for(i=0;i<8;i++)
        digitalWrite(ADC_CLK,0);    delayMicroseconds(2);
        pinMode(ADC_DIO, INPUT);
    for(i=0;i<8;i++)
    digitalWrite(ADC_CS,1);
int main(void)
    uchar analogVal;
    softPwmCreate(LedPin,  0, 100);
    pinMode(ADC_CS,  OUTPUT);
    pinMode(ADC_CLK, OUTPUT);
        printf("Current analogVal : %d\n", analogVal);
        softPwmWrite(LedPin, analogVal);
        delay(100);
Code Explanation
The codes here are the same as that in 2.1.7 Potentiometer. If you have any other questions, please check the code explanation of 2.1.7 Potentiometer for details.
Phenomenon Picture
../_images/image199.jpeg
