2.1.9 Joystick(MCP3008)
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use MCP3008 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/c/2.1.9-2/
Step 3: Compile the code.
gcc 2.1.9_Joystick.c -o joystick -lwiringPi
./joystick
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000 // 1 MHz
#define BtnPin 3 // WiringPi 3 = BCM GPIO22
// Read from MCP3008 channel (0–7)
int read_ADC(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Channel config
buffer[2] = 0;
int result = ((buffer[1] & 0x03) << 8) | buffer[2];
return result;
int main(void) {
if (wiringPiSetup() == -1) {
printf("WiringPi setup failed!\n");
printf("SPI setup failed!\n");
pinMode(BtnPin, INPUT);
pullUpDnControl(BtnPin, PUD_UP);
while (1) {
int x_val = read_ADC(0); // VRX on CH0
int y_val = read_ADC(1); // VRY on CH1
int btn_val = digitalRead(BtnPin); // SW button
printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
delay(100);
Code Explanation
This section initializes the libraries needed for GPIO and SPI communication.
#include <wiringPi.h> #include <wiringPiSPI.h> #include <stdio.h> #define SPI_CHANNEL 0 #define SPI_SPEED 1000000 // 1 MHz #define BtnPin 3 // WiringPi 3 = BCM GPIO22
Defines a function
read_ADC()to read analog data from MCP3008. It communicates over SPI to request data from a given channel (0–7), then parses the response to get a 10-bit ADC result.int read_ADC(int channel) { if (channel < 0 || channel > 7) return -1; unsigned char buffer[3]; buffer[0] = 1; buffer[1] = (8 + channel) << 4; buffer[2] = 0; wiringPiSPIDataRW(SPI_CHANNEL, buffer, 3); int result = ((buffer[1] & 0x03) << 8) | buffer[2]; return result; }
The main function initializes the WiringPi and SPI interfaces, configures the joystick’s button pin, and continuously reads joystick values and prints them to the console.
int main(void) { if (wiringPiSetup() == -1) { printf("WiringPi setup failed!\n"); return 1; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("SPI setup failed!\n"); return 1; } pinMode(BtnPin, INPUT); pullUpDnControl(BtnPin, PUD_UP); while (1) { int x_val = read_ADC(0); // VRX to CH0 int y_val = read_ADC(1); // VRY to CH1 int btn_val = digitalRead(BtnPin); // SW to GPIO22 printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val); delay(100); } return 0; }
In this program:
The joystick’s VRX is connected to CH0 of MCP3008.
The VRY is connected to CH1.
The button (SW) is connected to GPIO22 (WiringPi pin 3).
The
read_ADC()function is used to read analog values from VRX and VRY.The digital value of the joystick button is read using
digitalRead().All values are printed continuously every 100 milliseconds.
