2.2.1 Photoresistor(MCP3008)ο
Introductionο
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
WiringPi |
BCM |
SPICE0 |
pin24 |
10 |
8 |
SPIMOSI |
pin19 |
12 |
10 |
SPIMISO |
pin21 |
13 |
9 |
SPISCLK |
pin23 |
14 |
11 |
GPIO22 |
pin15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
cd ~/raphael-kit/c/2.2.1-2/
Step 3: Compile the code.
gcc 2.2.1_Photoresistor.c -o photoresistor -lwiringPi -lm
./photoresistor
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#define SPI_CHANNEL 0 // Use SPI channel 0 (CE0)
#define SPI_SPEED 1000000 // 1 MHz SPI speed
#define LedPin 3 // GPIO3 (WiringPi) for LED PWM
// Read ADC value from MCP3008, channel 0~7
int readMCP3008(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // SGL/DIF = 1, D2-D0 = channel
buffer[2] = 0;
// Combine the result
int result = ((buffer[1] & 3) << 8) | buffer[2];
return result;
int main(void) {
if (wiringPiSetup() == -1) {
printf("wiringPi init failed!\n");
printf("SPI setup failed!\n");
softPwmCreate(LedPin, 0, 100); // Init software PWM
while (1) {
int analogVal = readMCP3008(0); // Read from CH0
printf("ADC Value: %d\n", analogVal);
// Scale 10-bit ADC value (0β1023) to PWM range (0β100)
int pwmVal = analogVal * 100 / 1023;
softPwmWrite(LedPin, pwmVal);
delay(100);
Code Explanation
The codes here are the same as that in 2.1.7 Potentiometer. If you have any other questions, please check the code explanation of 2.1.7 Potentiometer(MCP3008) for details.
