πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.7 Potentiometer
Introduction
The ADC function can be used to convert analog signals to digital signals, and in this experiment, ADC0834 is used to get the function involving ADC. Here, we implement this process by using potentiometer. Potentiometer changes the physical quantity – voltage, which is converted by the ADC function.
Required Components
../_images/list_2.1.4_potentiometer.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
Potentiometer
ADC0834
Schematic Diagram
../_images/image311.png ../_images/image312.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image180.png
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Open the code file.
cd ~/raphael-kit/c/2.1.7/
Step 3: Compile the code.
gcc 2.1.7_Potentiometer.c -lwiringPi
Step 4: Run.
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
    #include <wiringPi.h>
    #include <stdio.h>
    #include <softPwm.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define     ADC_CS    0
#define     ADC_CLK   1
#define     ADC_DIO   2
#define     LedPin    3
    uchar i;
    uchar dat1=0, dat2=0;
    int sel = channel > 1 & 1;
    int odd = channel & 1;
    digitalWrite(ADC_CLK, 1);
    delayMicroseconds(2);
    digitalWrite(ADC_CLK, 0);
    pinMode(ADC_DIO, OUTPUT);
    digitalWrite(ADC_CS, 0);
    // Start bit
    digitalWrite(ADC_CLK,0);
    digitalWrite(ADC_DIO,1);    delayMicroseconds(2);
    digitalWrite(ADC_CLK,1);    delayMicroseconds(2);
    //Single End mode
    // ODD
    digitalWrite(ADC_DIO,odd);  delayMicroseconds(2);
    //Select
    digitalWrite(ADC_DIO,sel);    delayMicroseconds(2);
    for(i=0;i<8;i++)
        digitalWrite(ADC_CLK,0);    delayMicroseconds(2);
        pinMode(ADC_DIO, INPUT);
    for(i=0;i<8;i++)
    digitalWrite(ADC_CS,1);
int main(void)
    uchar analogVal;
    softPwmCreate(LedPin,  0, 100);
    pinMode(ADC_CS,  OUTPUT);
    pinMode(ADC_CLK, OUTPUT);
        printf("Current analogVal : %d\n", analogVal);
        softPwmWrite(LedPin, analogVal);
            delay(100);
Code Explanation
#define     ADC_CS    0
#define     ADC_CLK   1
#define     ADC_DIO   2
#define     LedPin    3
Define CS, CLK, DIO of ADC0834, and connect them to GPIO0, GPIO1 and GPIO2 respectively. Then attach LED to GPIO3.
    uchar i;
    // Start bit
    //Single End mode
    // ODD
    //Select
    for(i=0;i<8;i++)
    for(i=0;i<8;i++)
There is a function of ADC0834 to get Analog to Digital Conversion. The specific workflow is as follows:
Set CS to low level and start enabling AD conversion.
// Start bit
When the low-to-high transition of the clock input occurs at the first time, set DIO to 1 as Start bit. In the following three steps, there are 3 assignment words.
//Single End mode
As soon as the low-to-high transition of the clock input occurs for the second time, set DIO to 1 and choose SGL mode.
// ODD
Once occurs for the third time, the value of DIO is controlled by the variable odd.
//Select
The pulse of CLK converted from low level to high level for the forth time, the value of DIO is controlled by the variable sel.
Under the condition that channel=0, sel=0, odd=0, the operational formulas concerning sel and odd are as follows:
When the condition that channel=1, sel=0, odd=1 is met, please refer to the following address control logic table. Here CH1 is chosen, and the start bit is shifted into the start location of the multiplexer register and conversion starts.
../_images/image313.png
Here, set DIO to 1 twice, please ignore it.
for(i=0;i<8;i++)
In the first for() statement, as soon as the fifth pulse of CLK is converted from high level to low level, set DIO to input mode. Then the conversion starts and the converted value is stored in the variable dat1. After eight clock periods, the conversion is complete.
for(i=0;i<8;i++)
In the second for() statement, output the converted values via DO after other eight clock periods and store them in the variable dat2.
return(dat1==dat2) ? dat1 : 0 is used to compare the value gotten during the conversion and the output value. If they are equal to each other, output the converting value dat1; otherwise, output 0. Here, the workflow of ADC0834 is complete.
The function is to use software to create a PWM pin, LedPin, then the initial pulse width is set to 0, and the period of PWM is 100 x 100us.
        delay(100);
In the main program, read the value of channel 0 that has been connected with a potentiometer. And store the value in the variable analogVal then write it in LedPin. Now you can see the brightness of LED changing with the value of the potentiometer.
Phenomenon Picture
../_images/image181.jpeg
