πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.6 Rotary Encoder Module
Introduction
In this project, you will learn about Rotary Encoder. A rotary encoder is an electronic switch with a set of regular pulses in strictly timing sequence. When used with IC, it can achieve increment, decrement, page turning and other operations such as mouse scrolling, menu selection, and so on.
Required Components
../_images/Part_two_25.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Schematic Diagram
../_images/image349.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.1.6_fritzing.png
Step 2: Open the code file.
cd ~/raphael-kit/c/2.1.6/
Step 3: Compile the code.
gcc 2.1.6_RotaryEncoder.c -lwiringPi
Step 4: Run.
You will see the count on the shell. When you turn the rotary encoder clockwise, the count is increased; when turn it counterclockwise, the count is decreased. If you press the switch on the rotary encoder, the readings will return to zero.
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include <stdlib.h>
#include <wiringPi.h>
#define  clkPin    0
#define  dtPin    1
#define  swPin     2
static volatile int globalCounter = 0 ;
unsigned char flag;
unsigned char Last_dtPin_Status;
unsigned char Current_dtPin_Status;
void btnISR(void)
   globalCounter = 0;
void rotaryDeal(void)
   Last_dtPin_Status = digitalRead(dtPin);
   while(!digitalRead(clkPin)){
      Current_dtPin_Status = digitalRead(dtPin);
      flag = 1;
   if(flag == 1){
      flag = 0;
      if((Last_dtPin_Status == 0)&&(Current_dtPin_Status == 1)){
         globalCounter --;
      if((Last_dtPin_Status == 1)&&(Current_dtPin_Status == 0)){
         globalCounter ++;
int main(void)
   if(wiringPiSetup() < 0){
      fprintf(stderr, "Unable to setup wiringPi:%s\n",strerror(errno));
   pinMode(swPin, INPUT);
   pinMode(clkPin, INPUT);
   pinMode(dtPin, INPUT);
   pullUpDnControl(swPin, PUD_UP);
   if(wiringPiISR(swPin, INT_EDGE_FALLING, &btnISR) < 0){
      fprintf(stderr, "Unable to init ISR\n",strerror(errno));
   int tmp = 0;
      rotaryDeal();
      if (tmp != globalCounter){
         printf("%d\n", globalCounter);
         tmp = globalCounter;
Code Analysis
  • Read dtPin value when clkPin is low.
  • When clkPin is high, if dtPin goes from low to high, the count decreases, otherwise the count increases.
  • swPin will output low when the shaft is pressed.
From this, the program flow is shown below:
../_images/2.1.6_flow.png
Phenomenon Picture
../_images/2.1.6rotary_ecoder.JPG
