.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.1.7_c_pi5:
2.1.7 Potentiometer
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
The ADC function can be used to convert analog signals to digital
signals, and in this experiment, ADC0834 is used to get the function
involving ADC. Here, we implement this process by using potentiometer.
Potentiometer changes the physical quantity -- voltage, which is
converted by the ADC function.
.. image:: ../img/list_2.1.4_potentiometer.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_led`
- |link_led_buy|
* - :ref:`cpn_potentiometer`
- |link_potentiometer_buy|
* - :ref:`cpn_adc0834`
Schematic Diagram
.. image:: ../img/image311.png
.. image:: ../img/image312.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/image180.png
.. note::
Please place the chip by referring to the corresponding position
depicted in the picture. Note that the grooves on the chip should be on
the left when it is placed.
**Step 2:** Open the code file.
.. raw:: html
.. code-block::
cd ~/raphael-kit/c/2.1.7/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.1.7_Potentiometer.c -lwiringPi
**Step 4:** Run.
.. raw:: html
.. code-block::
After the code runs, rotate the knob on the potentiometer, the intensity
of LED will change accordingly.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
typedef unsigned char uchar;
typedef unsigned int uint;
#define ADC_CS 0
#define ADC_CLK 1
#define ADC_DIO 2
#define LedPin 3
uchar i;
uchar dat1=0, dat2=0;
int sel = channel > 1 & 1;
int odd = channel & 1;
digitalWrite(ADC_CLK, 1);
delayMicroseconds(2);
digitalWrite(ADC_CLK, 0);
pinMode(ADC_DIO, OUTPUT);
digitalWrite(ADC_CS, 0);
// Start bit
digitalWrite(ADC_CLK,0);
//Single End mode
// ODD
//Select
for(i=0;i<8;i++)
pinMode(ADC_DIO, INPUT);
for(i=0;i<8;i++)
dat2 = dat2 | ((uchar)(digitalRead(ADC_DIO))< 1 & 1;
// Start bit
//Single End mode
// ODD
//Select
for(i=0;i<8;i++)
for(i=0;i<8;i++)
When the condition that channel=1, sel=0, odd=1 is met, please refer to
the following address control logic table. Here CH1 is chosen, and the
start bit is shifted into the start location of the multiplexer register
and conversion starts.
.. image:: ../img/image313.png
.. code-block:: c
Here, set DIO to 1 twice, please ignore it.
.. code-block:: c
for(i=0;i<8;i++)
In the first for() statement, as soon as the fifth pulse of CLK is
converted from high level to low level, set DIO to input mode. Then the
conversion starts and the converted value is stored in the variable
dat1. After eight clock periods, the conversion is complete.
.. code-block:: c
for(i=0;i<8;i++)
