2.1.7 Potentiometer(MCP3008)
The ADC function is used to convert analog signals into digital values. In this experiment, we use the MCP3008 ADC chip to perform this conversion. A potentiometer is used to generate a variable voltage, which changes the physical quantity. The MCP3008 then converts this analog voltage into a digital value that can be read and processed by the Raspberry Pi.
../_images/list2_2.1.4_potentiometer.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
Potentiometer
MCP3008
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
GPIO22
pin15
../_images/schematic_2.1.7_potentiometer_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_2.1.7_potentiometer_mcp3008.png
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Open the code file.
cd ~/raphael-kit/c/2.1.7-2/
Step 3: Compile the code.
gcc 2.1.7_Potentiometer.c -lwiringPi
Step 4: Run.
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#define SPI_CHANNEL 0  // CE0
#define SPI_SPEED   1000000  // 1MHz
#define LedPin      3
int readADC(int channel) {
    unsigned char buffer[3];
    buffer[0] = 1;                             // Start bit
    buffer[1] = (8 + channel) << 4;            // Single-ended mode, channel
    buffer[2] = 0;
    int value = ((buffer[1] & 3) << 8) | buffer[2];
    return value;
int main(void) {
    if (wiringPiSetup() == -1) {
        printf("WiringPi init failed!\n");
        printf("SPI setup failed!\n");
    softPwmCreate(LedPin, 0, 100);
    while (1) {
        int analogVal = readADC(0);  // CH0
        printf("ADC Value: %d\n", analogVal);
        int pwmVal = analogVal * 100 / 1023;  // Normalize to 0–100
        softPwmWrite(LedPin, pwmVal);
        delay(100);
Code Explanation
#define LedPin      3
Define the SPI channel as CE0 (chip enable 0), set the SPI speed to 1MHz, and assign GPIO3 to the LED pin.
    buffer[2] = 0;
    return value;
This function is used to read analog data from MCP3008.
  • First, it checks if the channel number is within the valid range (0 to 7).
  • It initializes a 3-byte array, where:
    • buffer[0] = 1: Start bit for MCP3008 communication.
    • buffer[1] = (8 + channel) << 4: Constructs the configuration byte for single-ended mode and selects the desired channel.
    • buffer[2] = 0: Placeholder byte to receive the result.
  • wiringPiSPIDataRW sends and receives data through the SPI channel.
  • The return value is extracted from the last two bytes using bitwise operations to obtain a 10-bit ADC result.
int main(void) {
    while (1) {
        delay(100);
In the main function:
  • wiringPiSetup() initializes the WiringPi library.
  • wiringPiSPISetup() initializes SPI communication on channel 0 at 1MHz.
  • softPwmCreate() sets up software PWM on GPIO3 with an initial duty cycle of 0 and a range of 0–100.
The program enters an infinite loop where:
  • It reads the ADC value from channel 0 (connected to a potentiometer).
  • Prints the ADC value to the terminal.
  • Converts the 10-bit ADC value to a PWM duty cycle between 0 and 100.
  • Writes the PWM value to the LED, so the brightness reflects the potentiometer’s position.
delay(100) pauses for 100 milliseconds before the next read/write cycle.
