Get technical support and troubleshooting help.
Learn and share projects, tips, and tutorials.
Access early product previews and updates.
Enjoy exclusive discounts and giveaways.
👉 Join us here: [here]
Control with Commands
In addition to viewing data from the Pironman 5 Pro MAX and controlling various devices through the Dashboard, you can also use commands to control them.
View the Basic Configurations
The pironman5 module offers basic configurations for Pironman, which you can review with the following command.
sudo pironman5 -c
The standard configurations appear as follows:
"system": {
"data_interval": 1,
"enable_history": true,
"rgb_color": "#ff3dbe",
"rgb_brightness": 50,
"rgb_style": "breathing",
"rgb_speed": 50,
"rgb_enable": true,
"rgb_led_count": 18,
"temperature_unit": "C",
"oled_enable": true,
"oled_rotation": 0,
"oled_sleep_timeout": 10,
"default_dashboard_page": "small",
"oled_pages": [
"mix",
"performance",
"ips",
"disk"
"debug_level": "INFO"
Customize these configurations to fit your needs.
Use pironman5 or pironman5 -h for instructions.
usage: pironman5 [-h] [-v] [-c] [-drd [DATABASE_RETENTION_DAYS]] [-dl [{DEBUG,INFO,WARNING,ERROR,CRITICAL,debug,info,warning,error,critical}]] [-rd] [-cp [CONFIG_PATH]]
[-eh [ENABLE_HISTORY]] [-re [RGB_ENABLE]] [-rs [RGB_STYLE]] [-rc [RGB_COLOR]] [-rb [RGB_BRIGHTNESS]] [-rp [RGB_SPEED]] [-rl [RGB_LED_COUNT]] [-u [{C,F}]] [-oe [OLED_ENABLE]]
[-or [{0,180}]] [-op [OLED_PAGES]] [-os [OLED_SLEEP_TIMEOUT]]
{start,stop,launch-browser} ...
Pironman 5 Pro Max command line interface
options:
-h, --help show this help message and exit
-v, --version Show version
-c, --config Show config
-drd, --database-retention-days [DATABASE_RETENTION_DAYS]
Database retention days
-dl, --debug-level [{DEBUG,INFO,WARNING,ERROR,CRITICAL,debug,info,warning,error,critical}]
Debug level
-rd, --remove-dashboard
Remove dashboard
-cp, --config-path [CONFIG_PATH]
Config path
-eh, --enable-history [ENABLE_HISTORY]
Enable history, True/true/on/On/1 or False/false/off/Off/0
-re, --rgb-enable [RGB_ENABLE]
RGB enable True/False
-rs, --rgb-style [RGB_STYLE]
RGB style: ['solid', 'breathing', 'flow', 'flow_reverse', 'rainbow', 'rainbow_reverse', 'hue_cycle']
-rc, --rgb-color [RGB_COLOR]
RGB color in hex format without # (e.g. 00aabb)
-rb, --rgb-brightness [RGB_BRIGHTNESS]
RGB brightness 0-100
-rp, --rgb-speed [RGB_SPEED]
RGB speed 0-100
-rl, --rgb-led-count [RGB_LED_COUNT]
RGB LED count int
-u, --temperature-unit [{C,F}]
Temperature unit
-oe, --oled-enable [OLED_ENABLE]
OLED enable True/true/on/On/1 or False/false/off/Off/0
-or, --oled-rotation [{0,180}]
Set to rotate OLED display, 0, 180
-op, --oled-pages [OLED_PAGES]
OLED pages, split by ',': mix,performance,ips,disk
-os, --oled-sleep-timeout [OLED_SLEEP_TIMEOUT]
OLED sleep timeout in seconds
Subcommands:
start Start Pironman5
stop Stop Pironman5
launch-browser Launch browser
Each time you modify the status of pironman5.service, you need to use the following command to make the configuration changes take effect.
Verify the
pironman5program status using thesystemctltool.sudo systemctl status pironman5.service
Alternatively, inspect the program-generated log files.
ls /var/log/pironman5/
Control RGB LEDs
The board features 18 WS2812B addressable RGB LEDs: 6 onboard and 12 integrated into the RGB fans. Users can control power, color, brightness, display modes, animation speed, and the number of active LEDs.
After modifying the configuration for pironman5.service, you must restart the service for the changes to take effect:
Enable/Disable RGB LEDs: Use
trueto turn on,falseto turn off.
sudo pironman5 -re true
Change Color: Set a color using a hexadecimal value (without the #), e.g.,
fe1a1afor red.
sudo pironman5 -rc fe1a1a
Adjust Brightness: Set brightness from 0% to 100%.
sudo pironman5 -rb 75
Change Display Mode: Choose from several animation modes:
solid: Static color.breathing: Pulsing fade in/out.flow/flow_reverse: Color flows in one direction.rainbow/rainbow_reverse: Cycles through a rainbow spectrum.hue_cycle: Smoothly cycles through hue values.
sudo pironman5 -rs breathing
When using rainbow, rainbow_reverse, or hue_cycle modes, the color set via pironman5 -rc will be overridden by the mode’s automatic color cycle.
Adjust Animation Speed: Control the speed of effects from 0% (slowest) to 100% (fastest).
sudo pironman5 -rp 50
Set LED Count: The system defaults to controlling 18 LEDs. If you have extended the chain with additional external WS2812B LEDs, update the total count accordingly.
sudo pironman5 -rl 12
Fan
These fans connects to a dedicated 4-pin PWM fan port on the Raspberry Pi 5. Its default control strategy is a firmware-managed, multi-level intelligent speed adjustment scheme based on CPU temperature. This means that when you use an official or compatible PWM fan and connect it correctly, the system will automatically adjust the fan speed according to changes in CPU temperature (starting to operate above 50°C) without any manual intervention from you.
Check the OLED Screen
The 0.96” OLED screen displays system information (CPU, RAM, Disk, Temp, IP) by default after installing the pironman5 library and rebooting.
If the OLED screen is blank:
Ensure the OLED’s FPC cable is securely connected to the mainboard.
Check the service log for errors:
sudo journalctl -u pironman5.service -f
Or check the specific OLED log:
cat /var/log/pironman5/pironman5.logVerify the OLED is detected on the I2C bus (address 0x3C):
i2cdetect -y 1
OLED Configuration Commands
Enable/Disable OLED: Turn the OLED display on or off.
sudo pironman5 -oe false
Rotate Display: Set screen orientation to
0(default) or180degrees.sudo pironman5 -or 180
Configure Display Pages: Choose which info pages to cycle through. Pages are:
mix(overview),performance(detailed CPU/RAM),ips(network IPs),disk(storage). Separate multiple pages with commas.sudo pironman5 -op mix,ips,disk
Set Sleep Timeout: Define how many seconds of inactivity before the OLED turns off (0 = never sleep).
sudo pironman5 -os 120
Check the Infrared Receiver
The built-in IR receiver allows control via remote.
Install the required software:
sudo apt-get install lirc -y
Test the receiver. Run the following command, then point a remote at the case and press buttons. You should see raw code output.
mode2 -d /dev/lirc0
To set up specific remote button mappings (e.g., for Kodi or Volumio), you will need to configure the /etc/lirc/lircd.conf file with your remote’s codes.
General System Commands
Show Version: Display the installed
pironman5package version.
sudo pironman5 -v
Show Current Configuration: Display all current settings.
sudo pironman5 -c
Set Temperature Unit: Switch between Celsius (
C) and Fahrenheit (F) for temperature displays.
sudo pironman5 -u F
Configure Data Logging:
Set Database Retention Days: Control how many days of historical data (like temperature logs) are kept.
sudo pironman5 -drd 30
Enable/Disable History Logging: Turn data collection on or off.
sudo pironman5 -eh false
Set Logging Verbosity: Adjust the detail level of system logs. Options:
DEBUG,INFO,WARNING,ERROR,CRITICAL.
sudo pironman5 -dl DEBUG
Remove Web Dashboard: Uninstall the optional web-based management interface.
sudo pironman5 -rd
Specify Custom Config Path: Use a configuration file from a non-standard location.
sudo pironman5 -cp /home/pi/my_custom_config.json
Service Management Subcommands
Start the Pironman5 Service: Manually start the background service that manages LEDs, fans, OLED, etc.
sudo pironman5 start
Stop the Pironman5 Service: Gracefully stop the background service.
sudo pironman5 stop
Launch Web Dashboard in Browser: If the web dashboard is installed, this command will open it in your default browser.
sudo pironman5 launch-browser
