👉 Join us here: [here]
Installing the OS on a Micro SD Card
If you are using a Micro SD card, you can follow the tutorial below to install the system onto your Micro SD card.
  • A Personal Computer
  • A Micro SD card and Reader
1. Install Raspberry Pi Imager
  1. Visit the official Raspberry Pi Imager download page: Raspberry Pi Imager. Download the correct installer for your operating system.
    ../../_images/imager_download1.png
  2. Follow the installation prompts (language, install path, confirmation). After installation, launch Raspberry Pi Imager from your desktop or applications menu.
    ../../_images/imager_install1.png
2. Install the OS to the microSD Card
  1. Insert your microSD card into your computer using a card reader. Before proceeding, back up any important data on the card, as it will be erased.
    ../../_images/insert_sd1.png
  2. When Raspberry Pi Imager opens, you will see the Device page. Select your Raspberry Pi 5 model from the list.
    ../../_images/imager_device1.png
  3. Go to the OS section, scroll down to the bottom of the page, and select your operating system.
    • For Ubuntu, click Other general-purpose OSUbuntu, then select Ubuntu Desktop 24.04 LTS (64-bit) or Ubuntu Server 24.04 LTS (64-bit).
    • For Kali Linux, Home Assistant, and Homebridge, click Other specific-purpose OS, then select the corresponding system.
    Warning
    Whichever system you choose, be sure to select a 64-bit version. On a 32-bit system, some packages are only available for aarch64 (64-bit), and certain features may fail to install or work properly.
    ../../_images/imager_other_os1.png
  4. In the Storage section, select your microSD card. For safety, it is recommended to unplug other USB storage devices so that only the microSD card appears in the list.
    ../../_images/imager_storage1.png
  5. Click NEXT.
    • For systems that cannot be configured in advance, clicking NEXT will skip the Customisation step and go directly to Writing, where the OS is written to the microSD card.
    • For systems that support pre-configuration, follow the Customisation steps to configure options such as Hostname, WiFi, and Enable SSH.
    ../../_images/imager_write_other_os1.png
  6. When the “Write Successful” popup appears, the image has been fully written and verified. You can now safely remove the microSD card and use it to boot your Raspberry Pi.
