👉 Join us here: [here]
Installing Ubuntu/Kali Linux/Homebridge/Home Assistant
You can choose the installation method based on whether you have a Micro SD or an NVMe SSD at hand.
Using a Micro SD Card Only
If you are using a Micro SD card, you can simply follow the first method below.
Using an M.2 NVMe SSD
  • If you are using an M.2 NVMe SSD, you will also need an M.2 NVMe SSD Enclosure Adapter to connect your SSD to your computer and follow the second method to install the OS.
    ../../_images/m2_nvme_adapter1.png
