πŸ‘‰ Join us here: [here]
FAQ
Quick Troubleshooting
1. Hardware
Compatible Systems
Systems that passed testing on the Raspberry Pi 5:
../_images/compitable_os2.png
Power Button
The power button extends the original Raspberry Pi 5 power button and behaves similarly.
../_images/power_button1.jpg
Power Button Not Working?
  1. First, confirm the expected power button behavior:
    • Raspberry Pi OS Desktop: Press the power button twice in quick succession to shut down. Hold for 5 seconds to force a hard shutdown. Press once to power on from a shutdown state.
    • Raspberry Pi OS Lite: Press the power button once to shut down. Hold for 5 seconds to force a hard shutdown. Press once to power on.
  2. Check whether the power converter pins are correctly aligned with the Raspberry Pi 5’s J2 pads (between the RTC battery connector and the board edge).
  3. Check whether the pins inside the power converter socket are properly aligned with the power button connector. Reconnect the power button cable if necessary.
  4. Use a screwdriver to briefly short the two pins on the power converter socket where the button connects. If the Pi powers on, the button itself may be faulty; otherwise, the issue is likely with the converter board or Pi 5 connection.
Copper Pipe Ends on the Tower Cooler
The flattened ends of the U-shaped copper heat pipes are part of the normal manufacturing process and are designed to allow the heat pipes to pass through the aluminum fins.
../_images/tower_cooler11.png
Raspberry Pi AI HAT+
The Raspberry Pi AI HAT+ is not compatible with the Pironman 5 MAX.
../_images/output31.png
The Raspberry Pi AI Kit combines the Raspberry Pi M.2 HAT+ and the Hailo AI accelerator module.
../_images/output21.jpg
You can detach the Hailo AI accelerator module from the Raspberry Pi AI Kit and insert it directly into the NVMe PIP module of the Pironman 5 MAX.
Can I use the Pironman5 Max’s vibration switch function?
From v1.3.6, OLED wake-up uses the power button. You must remove the vibration switch jumper to avoid occupying Raspberry Pi GPIO pins and prevent potential conflicts. Please check whether this jumper exists; if not, please ignore this notice.
../_images/remove_vib_jumper.jpg
2. Cooling and Fans
CPU Fan Not Working?
The CPU fan on the Pironman 5 is controlled by the Raspberry Pi system. The CPU fan speed depends on the Raspberry Pi 5 CPU temperature.
Default CPU fan curve:
  • < 50Β°C: Off (0%)
  • 50Β°C+: Low speed (30%)
  • 60Β°C+: Medium speed (50%)
  • 67.5Β°C+: High speed (70%)
  • 75Β°C+: Full speed (100%)
Check the current CPU temperature (example output: temp=48.7'C):
vcgencmd measure_temp
You can manually control the CPU fan using the following commands:
pinctrl FAN_PWM op dl   # Enable fan (low active)
pinctrl FAN_PWM op dh   # Disable fan (high active)
pinctrl FAN_PWM a0      # Auto mode
You can also adjust the CPU fan temperature thresholds by editing:
nano /boot/firmware/config.txt
Add:
dtparam=cooling_fan=on
dtparam=fan_temp0=40000
dtparam=fan_temp0_hyst=10000
dtparam=fan_temp0_speed=125
This configuration starts the CPU fan at 40Β°C with PWM speed level 125.
After saving the file, reboot the Raspberry Pi for the changes to take effect.
GPIO Fans Not Working?
First, check whether the FAN jumper cap on the IO Expander board is installed correctly.
../_images/io_board_fan_j91.png
Then set the GPIO Fans to Always On mode and check whether the fans start spinning.
sudo pironman5 -gm 0
You can also connect the GPIO Fans directly to the Raspberry Pi 5V and GND pins for testing.
If the fans spin normally when connected directly, the issue may be related to the IO Expander board. Please contact us for further support.
If the issue still persists, open the Dashboard Log page and check for error messages. You can also send us the following log file:
cat /var/log/pironman5/pironman5.log
3. OLED and RGB
OLED Screen Not Working?
If the OLED screen is not displaying or displaying incorrectly, follow these troubleshooting steps:
  1. Ensure the FPC cable of the OLED screen is securely connected. It is recommended to reconnect the OLED screen and then power on the device.
  2. Confirm that the Raspberry Pi is running a supported operating system.
    See Compatible Systems.
  3. When the OLED screen is powered on for the first time, it may only display pixel blocks. You need to follow the instructions in 4. Set up or Install Software to complete the configuration before it can display proper information.
  4. Use the following command to check if the OLED I2C address 0x3C is detected:
    sudo i2cdetect -y 1
    • If the I2C address 0x3C is detected, restart the Pironman 5 service:
    • If the address is not detected, enable I2C:
      Add:
      dtparam=i2c_arm=on
      Save the file and reboot the Raspberry Pi.
  5. If the issue still persists, please send us the following log file:
RGB LEDs Not Working?
  1. The two pins on the expansion board are used to connect the RGB LEDs to GPIO10. Ensure that the jumper cap on these two pins is properly installed.
    ../_images/io_board_rgb_pin1.png
  3. Run the following command to enable SPI:
    sudo raspi-config
    Navigate to:
    3 Interfacing Options β†’ I3 SPI β†’ YES
    Then reboot the Raspberry Pi.
  4. If the issue still persists, please send us the following log file:
How to Customize the OLED Display?
If you want to customize the OLED display, such as adding custom 2–4 digit image displays, you can modify the OLED page files in one of the following ways.
  • Method 1: Modify the Installed Files Directly
    1. List the OLED page files:
      ls /opt/pironman5/venv/lib/python3.13/site-packages/pm_auto/addons/oled/pages/
    2. Modify the desired Python files.
    3. Restart the service to apply the changes:
  • Method 2: Clone and Reinstall ``pm_auto``
    1. Clone the pm_auto repository:
      git clone -b 1.4.x https://github.com/sunfounder/pm_auto/
    2. After making changes, reinstall the modified package:
      sudo /opt/pironman5/venv/bin/pip3 uninstall pm_auto -y && \
      sudo /opt/pironman5/venv/bin/pip3 install ~/pm_auto --no-build-isolation && \
      sudo chown -R pironman5:pironman5 /opt/pironman5
    3. Restart the service:
  • Testing and Debugging
    To view runtime logs:
    journalctl -xefu pironman5.service
    You can also stop the service and run it manually for faster testing:
    sudo systemctl stop pironman5.service
    sudo pironman5 start
4. Dashboard and Software
The Dashboard Shows No Data
If the Dashboard shows no data, first open the Dashboard Log page and check whether there are any error messages related to influxdb.
Common errors include:
  • database not found
  • failed to connect to influxdb
  • connection refused
  • timeout
You can try the following steps to resolve the issue.
  1. Clear your browser cache, or reopen the Dashboard page using Incognito / Private mode.
  2. Check whether the following services are running properly:
    sudo systemctl status pironman5 --no-pager
    sudo systemctl status influxdb --no-pager
    Both services should display:
    active (running)
  3. If either service is not running properly, restart them:
    sudo systemctl restart influxdb
    sudo systemctl restart pironman5
    Then wait about 30 seconds and refresh the Dashboard page.
  4. Check whether the pironman5 database exists:
    influx
    Then run:
    SHOW DATABASES;
    You should see:
    pironman5
    _internal
  5. If the database is missing or corrupted, you can try clearing the historical data from the Dashboard using:
    Settings β†’ Clear All Data
  6. If the issue still persists after trying all the above steps, we recommend reinstalling the Raspberry Pi OS and Pironman 5 software.
How to Disable the Web Dashboard
Once you have completed the installation of the pironman5 module, you will be able to access the View and Control from Dashboard.
If you do not need this feature and want to reduce CPU and RAM usage, you can disable the dashboard during installation by adding the --disable-dashboard flag.
cd ~/pironman5
sudo python3 install.py --disable-dashboard
If you have already installed pironman5, you can remove the Dashboard module and influxdb:
/opt/pironman5/venv/bin/pip3 uninstall pm-dashboard influxdb
sudo apt purge influxdb
How to Uninstall and Reinstall the Pironman 5 Software
  1. Uninstall the current pironman5 software:
    cd ~/pironman5
    sudo python3 install.py --uninstall
  2. Reboot the Raspberry Pi as prompted, then remove the pironman5 directory:
    cd ~/
    sudo rm -rf pironman5
  3. Run the following command to reinstall the software for your Pironman 5 model:
    curl -sSL "https://raw.githubusercontent.com/sunfounder/pironman5/v1/install.sh" | sudo bash
How to Control Components Using the pironman5 Command
You can refer to the following tutorial to control the components of the Pironman 5 series using the pironman5 command.
5. Boot and Storage
If I set up OMV, can I still use the Pironman5’s function?
Yes, OpenMediaVault is set up on the Raspberry Pi system. Please follow the steps of Setting Up on Raspberry Pi OS/Ubuntu/Kali Linux/Homebridge to continue the configuration.
PI5 Fails to Boot (Red LED)?
This issue may be caused by a system update, changes to the boot order, or a corrupted bootloader. You can try the following steps to resolve the problem:
  1. Check USB-HDMI Adapter Connection
    • Please carefully check whether the USB-HDMI adapter is securely connected to the PI5.
    • Try unplugging and reconnecting the USB-HDMI adapter.
    • Then reconnect the power supply and check if the PI5 boots successfully.
  2. Test PI5 Outside the Case
    • If reconnecting the adapter does not solve the problem:
    • Remove the PI5 from the Pironman 5 series case.
    • Power the PI5 directly with the power adapter (without the case).
    • Check if it can boot normally.
  3. Restore the Bootloader
    • If the PI5 still cannot boot, the bootloader may be corrupted. You can follow this guide: 2. Update the Bootloader and choose whether to boot from SD card or NVMe/USB.
    • Insert the prepared SD card into the PI5, power it on, and wait at least 10 seconds. Once the recovery is complete, remove and reformat the SD card.
    • Then use Raspberry Pi Imager to flash the latest Raspberry Pi OS and try booting again.
NVMe PIP Module Not Working?
  1. Confirm that your NVMe SSD is compatible. Refer to the compatible NVMe SSD list for verified, stable, and compatible drives.
  2. Ensure the FPC cable connecting the NVMe PIP module to the Raspberry Pi 5 is securely attached.
  3. Confirm that your SSD is properly secured to the NVMe PIP module.
  4. Check the status of the NVMe PIP Module’s LEDs:
    After confirming all connections, power on the device and observe the two indicators on the NVMe PIP Module:
    • PWR LED: Should be lit.
    • STA LED: Should blink to indicate normal operation.
    ../_images/dual_nvme_pip_leds.png
    • If the PWR LED is on but the STA LED is not blinking, it indicates the NVMe SSD is not recognized by the Raspberry Pi.
    • If the PWR LED is off, short the β€œForce Enable” pins on the module. If the PWR LED lights up, it could indicate a loose FPC cable or unsupported system configuration for NVMe.
    ../_images/dual_nvme_pip_j4.png
  5. Confirm that your NVMe SSD has a properly installed operating system. Refer to 3. Installing the Operating System.
  1. If the issue still persists, please send us the following log file:
NVMe SSD Detected but Causes System Restart on Read/Write?
In some cases (especially with the WD Blue SN5000), the NVMe SSD may be detected by the Raspberry Pi 5 but cause the system to restart during read/write operations. This is a PCIe compatibility/stability issue between the SSD and the Raspberry Pi 5, not a Pironman 5 hardware fault.
Try the following steps to resolve the issue:
  1. Update the Raspberry Pi 5 bootloader to the latest version:
    sudo rpi-eeprom-update -a
    sudo reboot
  2. Force PCIe Gen3 speed by adding the following line to /boot/firmware/config.txt:
    dtparam=pciex1_gen=3
  3. Disable ASPM (Active State Power Management) by adding pcie_aspm=off to the kernel command line. Edit /boot/firmware/cmdline.txt and append it to the existing line (do not create a new line):
    pcie_aspm=off
    pcie_aspm=off is often the critical fix β€” PCIe ASPM issues are very common on the Raspberry Pi 5 and can cause NVMe drives to randomly disconnect or restart the system during heavy I/O.
  4. After applying the above changes, reboot the Raspberry Pi:
    sudo reboot
  5. If the issue persists, repartition and reformat the NVMe SSD, then reinstall the operating system.
How to Change the Raspberry Pi Boot Order Using Commands
If you are already logged into your Raspberry Pi, you can change the boot order using commands.
How to Modify the Boot Order with Raspberry Pi Imager
In addition to modifying the BOOT_ORDER in the EEPROM configuration, you can also use Raspberry Pi Imager to change the boot order.
How to Copy the System from the SD Card to an NVMe SSD
If you do not have an NVMe-to-USB adapter, you can first install the system onto a Micro SD card, then copy the system to the NVMe SSD after booting successfully.
6. Advanced Usage
How to Remove the Protective Film
Two acrylic panels are included in the package, both covered with yellow/transparent protective film on both sides to prevent scratches.
The protective film may be difficult to remove. Use a screwdriver to gently lift one corner, then carefully peel off the entire film.
../_images/peel_off_film1.jpg
