👉 Join us here: [here]
Control with Commands
In addition to viewing data from the Pironman 5 MAX and controlling various devices through the Dashboard, you can also use commands to control them.
  • For the Home Assistant system, you can only monitor and control the Pironman 5 MAX through the dashboard by opening the webpage at http://<ip>:34001.
View the Basic Configurations
The pironman5 module offers basic configurations for Pironman, which you can review with the following command.
sudo pironman5 -c
The standard configurations appear as follows:
    "system": {
        "data_interval": 1,
        "database_retention_days": 30,
        "temperature_unit": "C",
        "enable_history": true,
        "oled_enable": true,
        "oled_rotation": 0,
        "oled_sleep_timeout": 10,
        "oled_pages": [
            "mix",
            "performance",
            "ips",
            "disk"
        "rgb_enable": true,
        "rgb_color": "#0a1aff",
        "rgb_brightness": 100,
        "rgb_style": "breathing",
        "rgb_speed": 50,
        "rgb_led_count": 4,
        "rgb_led_count_min": 4,
        "gpio_fan_pin": 6,
        "gpio_fan_mode": 0,
        "gpio_fan_led": "on",
        "gpio_fan_led_pin": 5,
        "debug_level": "INFO"
Customize these configurations to fit your needs.
Use pironman5 or pironman5 -h for instructions.
usage: pironman5 [-h] [-v] [-c] [-drd [DATABASE_RETENTION_DAYS]] [-dl [{DEBUG,INFO,WARNING,ERROR,CRITICAL,debug,info,warning,error,critical}]] [-rd] [-cp [CONFIG_PATH]] [-eh [ENABLE_HISTORY]] [-re [RGB_ENABLE]] [-rs [RGB_STYLE]]
                [-rc [RGB_COLOR]] [-rb [RGB_BRIGHTNESS]] [-rp [RGB_SPEED]] [-rl [RGB_LED_COUNT]] [-u [{C,F}]] [-gm [GPIO_FAN_MODE]] [-gp [GPIO_FAN_PIN]] [-fl [GPIO_FAN_LED]] [-fp [GPIO_FAN_LED_PIN]] [-oe [OLED_ENABLE]] [-or [{0,180}]]
                [-op [OLED_PAGES]] [-os [OLED_SLEEP_TIMEOUT]]
                {start,stop,launch-browser} ...
Pironman 5 Max command line interface
options:
  -h, --help            show this help message and exit
  -v, --version         Show version
  -c, --config          Show config
  -drd, --database-retention-days [DATABASE_RETENTION_DAYS]
                        Database retention days
  -dl, --debug-level [{DEBUG,INFO,WARNING,ERROR,CRITICAL,debug,info,warning,error,critical}]
                        Debug level
  -rd, --remove-dashboard
                        Remove dashboard
  -cp, --config-path [CONFIG_PATH]
                        Config path
  -eh, --enable-history [ENABLE_HISTORY]
                        Enable history, True/true/on/On/1 or False/false/off/Off/0
  -re, --rgb-enable [RGB_ENABLE]
                        RGB enable True/False
  -rs, --rgb-style [RGB_STYLE]
                        RGB style: ['solid', 'breathing', 'flow', 'flow_reverse', 'rainbow', 'rainbow_reverse', 'hue_cycle']
  -rc, --rgb-color [RGB_COLOR]
                        RGB color in hex format without # (e.g. 00aabb)
  -rb, --rgb-brightness [RGB_BRIGHTNESS]
                        RGB brightness 0-100
  -rp, --rgb-speed [RGB_SPEED]
                        RGB speed 0-100
  -rl, --rgb-led-count [RGB_LED_COUNT]
                        RGB LED count int
  -u, --temperature-unit [{C,F}]
                        Temperature unit
  -gm, --gpio-fan-mode [GPIO_FAN_MODE]
                        GPIO fan mode, 0: Always On, 1: Performance, 2: Cool, 3: Balanced, 4: Quiet
  -gp, --gpio-fan-pin [GPIO_FAN_PIN]
                        GPIO fan pin
  -fl, --gpio-fan-led [GPIO_FAN_LED]
                        GPIO fan LED state on/off/follow
  -fp, --gpio-fan-led-pin [GPIO_FAN_LED_PIN]
                        GPIO fan LED pin
  -oe, --oled-enable [OLED_ENABLE]
                        OLED enable True/true/on/On/1 or False/false/off/Off/0
  -or, --oled-rotation [{0,180}]
                        Set to rotate OLED display, 0, 180
  -op, --oled-pages [OLED_PAGES]
                        OLED pages, split by ',': mix,performance,ips,disk
  -os, --oled-sleep-timeout [OLED_SLEEP_TIMEOUT]
                        OLED sleep timeout in seconds
Subcommands:
    start               Start Pironman5
    stop                Stop Pironman5
    launch-browser      Launch browser
Each time you modify the status of pironman5.service, you need to use the following command to make the configuration changes take effect.
  • Verify the pironman5 program status using the systemctl tool.
    sudo systemctl status pironman5.service
  • Alternatively, inspect the program-generated log.
    cat /var/log/pironman5/pironman5.log
Control RGB LEDs
The board features 4 WS2812 RGB LEDs, offering customizable control. Users can turn them on or off, change the color, adjust the brightness, switch RGB LED display modes, and set the speed of changes.
  • To modify the on and off state of the RGB LEDs, true to turn on the RGB LEDs, false to turn them off.
sudo pironman5 -re true
  • To change their color, input the desired hexadecimal color values, such as fe1a1a.
sudo pironman5 -rc fe1a1a
  • To change the brightness of the RGB LED (range: 0 ~ 100%):
sudo pironman5 -rb 100
  • To switch RGB LED display modes, choose from options: solid/breathing/flow/flow_reverse/rainbow/rainbow_reverse/hue_cycle:
If you set the RGB LED display mode to rainbow, rainbow_reverse, or hue_cycle, you will not be able to set the color using pironman5 -rc.
sudo pironman5 -rs breathing
  • To modify the speed of change (range: 0 ~ 100%):
sudo pironman5 -rp 80
  • The default setup includes 4 RGB LEDs. Connect additional LEDs and update the count using:
sudo pironman5 -rl 12
Control GPIO Fans
The IO expansion board supports up to two 5V non-CPU Fans. Both fans are controlled together.
  • You can use command to configure the operating mode of the two GPIO Fans. These modes determine the conditions under which the GPIO Fans will activate.
For instance, if set to 1: Performance mode, the GPIO Fans will activate at 50°C.
sudo pironman5 -gm 3
  • 4: Quiet: The GPIO Fans will activate at 70°C.
  • 3: Balanced: The GPIO Fans will activate at 67.5°C.
  • 2: Cool: The GPIO Fans will activate at 60°C.
  • 1: Performance: The GPIO Fans will activate at 50°C.
  • 0: Always On: The GPIO Fans will always on.
  • If you connect the control pin of the RGB fan to different pins on the Raspberry Pi, you can use the following command to change the pin number.
sudo pironman5 -gp 18
About Core Fan
The core fan connects to a dedicated 4-pin CPU Fan port on the Raspberry Pi 5. Its default control strategy is a firmware-managed, multi-level intelligent speed adjustment scheme based on CPU temperature. This means that when you use an official or compatible CPU Fan and connect it correctly, the system will automatically adjust the fan speed according to changes in CPU temperature (starting to operate above 50°C) without any manual intervention from you.
Check the OLED Screen
When you have installed the pironman5 library, the OLED screen displays CPU, RAM, Disk Usage, CPU Temperature, and the Raspberry Pi’s IP Address, and it shows this every time you reboot.
If your OLED screen does not display any content, you need to first check if the OLED’s FPC cable is connected properly.
Then you can check the program log to see what might be the problem through the following command.
Or check if the OLED’s i2c address 0x3C is recognized:
i2cdetect -y 1
Checkout the Infrared Receiver
  • Install the lirc module:
    sudo apt-get install lirc -y
  • Now, test the IR Receiver by running the following command.
    mode2 -d /dev/lirc0
  • After running the command, press a button on the remote control, and the code of that button will be printed.
