Add Card by Code Editor¶
After adding any card, you can manually edit the card’s yaml file. Click on SHOW CODE EDITOR on the card editing page.
Then directly modify the yaml file. We provide some useful PiPower Pro configurations. Please copy the following yaml code directly into the box.
Quick Overview
type: vertical-stack
cards:
- type: entities
entities:
- entity: switch.pipower_pro_output_switch
- entity: sensor.pipower_pro_output_source
- entity: binary_sensor.pipower_pro_external_power
- entity: sensor.pipower_pro_battery_voltage
- entity: sensor.pipower_pro_output_voltage
title: PiPower Pro
show_header_toggle: true
state_color: true
- square: true
type: grid
cards:
- type: gauge
entity: sensor.pipower_pro_battery_current
min: -2
max: 2
severity:
green: 0
yellow: 2
red: 2
needle: true
- type: gauge
entity: sensor.pipower_pro_output_current
min: 0
max: 3
severity:
green: 0
yellow: 2
red: 2.5
needle: true
- type: gauge
entity: sensor.pipower_pro_battery_level
min: 0
max: 100
severity:
green: 25
yellow: 10
red: 0
needle: true
columns: 3
Battery Information
show_name: false
show_icon: true
show_state: true
type: glance
entities:
- entity: sensor.pipower_pro_battery_current
- entity: sensor.pipower_pro_battery_capacity
- entity: binary_sensor.pipower_pro_is_charging
- entity: sensor.pipower_pro_battery_power
- entity: sensor.pipower_pro_battery_level
title: Battery
columns: 3
Output Information
show_name: false
show_icon: true
show_state: true
type: glance
entities:
- entity: sensor.pipower_pro_output_current
- entity: sensor.pipower_pro_output_power
- entity: sensor.pipower_pro_output_energy
title: Output
Battery Chart
cards:
- type: markdown
content: '## Battery'
- square: true
columns: 3
type: grid
cards:
- hours_to_show: 12
graph: line
type: sensor
detail: 2
- hours_to_show: 12
graph: line
type: sensor
detail: 2
- hours_to_show: 12
graph: line
type: sensor
detail: 2
Output Chart
cards:
- type: markdown
content: '## Output'
- square: true
columns: 3
type: grid
cards:
- hours_to_show: 12
graph: line
type: sensor
detail: 2
- hours_to_show: 12
graph: line
type: sensor
detail: 2
- hours_to_show: 12
graph: line
type: sensor
detail: 2
Settings
type: entities
entities:
- entity: sensor.pipower_pro_input_voltage
- entity: switch.pipower_pro_external_output
- entity: switch.pipower_pro_battery_output
- entity: switch.pipower_pro_esp32_power
- entity: binary_sensor.pipower_pro_sub_device_power_state
- entity: switch.pipower_pro_sub_device_power
- entity: sensor.pipower_pro_version
- entity: sensor.pipower_pro_battery_capacity_algorithm
- entity: button.pipower_pro_factory_reset
title: Settings
show_header_toggle: false
state_color: true
