👉 Ready to explore and create with us? Click [qui] and join today!
Install OpenSSH via PowerShell
If you see the following error when running ssh <username>@<hostname>.local or ssh <username>@<IP>:
ssh: The term 'ssh' is not recognized as the name of a cmdlet, function, script file, or operable program.
It means your Windows system does not have OpenSSH installed. Follow the steps below to install it manually.
  1. Open the Windows Start Menu, type powershell, right-click Windows PowerShell, and select Run as administrator.
    ../../_images/powershell_ssh.png
  2. Install the OpenSSH Client:
  3. After installation, you should see output similar to:
    Path          :
    Online        : True
    RestartNeeded : False
  4. Verify the installation:
  5. If OpenSSH is installed, the output will include:
    State : Installed
    State : NotPresent
    Avvertimento
    If Installed does not appear, your Windows system may be too old. In this case, we recommend using a third-party SSH tool. See: PuTTY
  6. Close PowerShell, reopen it (no need to run as administrator this time), and use the ssh command to log in:
    ../../_images/powershell_login.png
