33. Exploring the RF522-RFID Module
Gone are the days of waiting in long checkout lines at the grocery store, thanks to RFID technology! Imagine an RFID-based automatic checkout system where you can simply fill up your cart and walk out the door. Each item, tagged with an RFID label, will be instantly detected and recorded. No more waiting for each item to be scanned one by one!
In this exciting lesson, we dive into the world of RFID technology using the RC522 RFID reader/writer module. This module is a favorite among hobbyists due to its low power consumption, affordability, durability, ease of interface, and widespread popularity.
In this lesson, you will able to:
  • Understand the basics of RFID technology and its applications.
  • Learn how to interface the RC522 RFID reader module with an Arduino.
  • Write personal data to an RFID tag using the RC522 module.
  • Read and verify the written data from the RFID tag.
  • Display the RFID tag information on an I2C LCD.
What is RC522 Module and RFID technology?
RC522 Module
The RC522 RFID reader module, operating at a frequency of 13.56MHz, is designed to communicate with RFID tags adhering to the ISO 14443A standard. This compact and versatile device is ideal for applications in access control, inventory tracking, and contactless payment systems due to its ability to interface with microcontrollers via a 4-pin SPI connection, supporting data rates up to 10 Mbps, and additional I2C and UART communication protocols.
Operating between 2.5 and 3.3V, its 5V tolerant logic pins facilitate easy integration with Arduino and other 5V logic microcontrollers, eliminating the need for a logic level converter.
../_images/33_rfid_module.png
  • VCC: Powers the module (2.5 to 3.3V). Connect to Arduino’s 3.3V output. Do not connect to 5V as it can damage the module.
  • RST: Resets and powers down the module. Goes into power-down mode when low and resets on the rising edge.
  • GND: Ground pin, connect to Arduino’s GND.
  • IRQ: Interrupt pin, alerts the microcontroller when an RFID tag is nearby.
  • MISO / SCL / Tx: Acts as master-in-slave-out for SPI, serial clock for I2C, and serial data output for UART.
  • MOSI: SPI input to the module.
  • SCK: Serial clock input from the SPI bus master (Arduino).
  • SS / SDA / Rx: Signal input for SPI, serial data for I2C, and serial data input for UART. Often marked with a square.
RFID Technology
An RFID system, or radio frequency identification system, comprises two key components: a tag attached to the object to be identified and a reader that reads this tag.
The reader contains an RF module and an antenna that creates a high-frequency electromagnetic field. Tags are typically passive, meaning they lack a battery. They consist of a microchip for storing and processing information and an antenna for receiving and transmitting signals.
../_images/33_rfid_com.png
When the tag is placed near the reader, the reader’s electromagnetic field powers the tag’s chip by inducing electron flow through its antenna.
The chip then transmits its stored data back to the reader via a radio signal, a process known as backscattering. The reader captures and decodes this signal, sending the information to a computer or microcontroller for further processing.
Build the Circuit
Now that we know everything about the module, let’s start connecting it to our Arduino!
Components Needed
1 * Arduino Uno R3
1 * RFID Module and Tag
1 * I2C LCD1602
list_uno_r3
list_rc522_module
list_i2c_lcd1602
Jumper Wires
1 * Breadboard
1 * USB Cable
list_wire
list_breadboard
list_usb_cable
Building Steps
Follow the wiring diagram, or the steps below to build your circuit.
../_images/33_rfid_connect_lcd.png
  1. First, insert RC522-RFID module into the breadboard.
../_images/33_rfid_plug_rc522.png
  1. Then, connect the RC522-RFID module and the Arduino Uno R3.
RC522-RFID
Arduino UNO R3
3.3V
3.3V
RST
9
GND
GND
IRQ
MISO
12
MOSI
11
SCK
13
SDA
10
../_images/33_rfid_connect_rc522.png
  1. Finally, connect the I2C LCD1602 module: GND to the GND on the Arduino Uno R3, VCC to the pin 5V, SDA to pin A4, and SCL to pin A5.
Code Creation - Write and Read
In this section, we will install the libraries required for using the MFRC522 RFID module, and then open example code to write information to a tag and read information from the tag.
Writing Information
  1. To use the MFRC522 RFID module, you need to include the appropriate library. Now, search for MFRC522 in the Library Manager, then click INSTALL.
../_images/33_rfid_install_lib.png
  1. Now, by clicking File -> Examples -> MFRC522, you will see multiple example codes demonstrating different functionalities. Open the rfid_write_personal_data example code.
../_images/33_rfid_open_write.png
  1. Click Upload to upload the code to your Arduino board. Then open the serial monitor, and you will see a prompt message.
../_images/33_rfid_write_open.png
  1. Now place the provided white card or tag near the MFRC522 module. You will see the tag’s UID, PICC type, and a prompt to enter the Family name, followed by a #.
Write personal data on a MIFARE PICC
Card UID: 9B 2F 0A 11 PICC type: MIFARE 1KB
Type Family name, ending with #
  1. Now start typing, for example, I enter XIE#. Press Enter to send your input to the Arduino board, which will then transfer it to the RFID module.
While entering data, ensure that your card or tag remains near the RFID module’s antenna, or else an error will occur.
../_images/33_rfid_write_first_name.png
  1. You will see a success message for writing the data, followed by a prompt to enter the first name.
PCD_Authenticate() success:
MIFARE_Write() success:
Type First name, ending with #
  1. Next, enter the first name, for example, Daisy#. You will see another success message for writing the data.
Reading Information
We have just written our name to the card or tag. Now, let’s open another example code to read the information from this card and check if the data was written correctly.
  1. Similarly, by clicking File -> Examples -> MFRC522, open the rfid_read_personal_data example code.
../_images/33_rfid_read_open.png
  1. Once opened, upload the code to your Arduino board. Then place your card near the RFID module’s antenna. You will see your UID and the previously written name information.
**Card Detected:**
Card SAK: 08
Name:
Daisy XIE
**End Reading**
Code Creation - Display on LCD
Here, we will learn how to display the card’s name and UID on an I2C LCD.
If you are not familiar with the I2C LCD1602, you can first learn its basic usage through the following projects:
LiquidCrystal I2C library is used here, you can install it from the Library Manager.
  1. Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
  2. Save your sketch as Lesson33_RFID_LCD using Ctrl + S or by clicking “Save”.
  3. Libraries for SPI and I2C communication are included to interact with the RFID and LCD modules, respectively. The reset (RST_PIN) and slave select (SS_PIN) pins for the RFID reader are defined.
#include <SPI.h>                // Include the SPI library for SPI communication
#include <MFRC522.h>            // Include the library for the RFID module
#include <Wire.h>               // Include the Wire library for I2C communication
#include <LiquidCrystal_I2C.h>  // Include the library for the I2C LCD
#define RST_PIN 9  // Reset pin for the RFID module
#define SS_PIN 10  // Slave select pin for the RFID module
  1. This initializes the RFID reader and the LCD display with specified pin connections and LCD dimensions/configuration (address 0x27, 16 columns, 2 rows).
// Create an instance of the MFRC522 class to interface with the RFID module
MFRC522 mfrc522(SS_PIN, RST_PIN);
// Create an instance of the LiquidCrystal_I2C class for the LCD
LiquidCrystal_I2C lcd(0x27, 16, 2);
  1. The setup() function initializes serial communication, the SPI bus, the RFID reader, and the LCD. It sets up the LCD backlight and sends a readiness message to the serial monitor.
  Serial.begin(9600);                         // Start serial communication at 9600bps
  SPI.begin();                                // Initialize the SPI bus
  mfrc522.PCD_Init();                         // Initialize the RFID reader
  lcd.init();                                 // Initialize the LCD display
  lcd.backlight();                            // Turn on the backlight of the LCD
  Serial.println(F("Ready to read a card"));  // Print a message to start read
  1. The loop() function continuously checks for new RFID cards. If a card is detected, it reads and displays the UID, reads data from block 4, and then pauses for a moment before clearing the LCD.
  // Check if a new RFID card is present and can be read
  if (!mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()) {
    return;  // If no new card is present, exit the loop
  displayCardUID();           // Function to display the UID of the card
  readAndDisplayBlock(4);     // Function to read and display block4 of the RFID card
  mfrc522.PICC_HaltA();       // Halt the RFID card to stop reading
  mfrc522.PCD_StopCrypto1();  // Stop encryption on the communication
  delay(5000);                // Delay for 5 seconds
  lcd.clear();                // Clear the LCD display
  1. displayCardUID() function: Handles the display of the card’s UID on both the serial monitor and the LCD. It formats the UID as hexadecimal values.
// Function to display the UID of the RFID card
void displayCardUID() {
  Serial.print(F("Card UID:"));                  // Print the text "Card UID:"
  lcd.setCursor(0, 0);                           // Set the LCD cursor to the top-left
  lcd.print("UID:");                             // Print "UID:" on the LCD
  for (byte i = 0; i < mfrc522.uid.size; i++) {  // Loop through each byte of the UID
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);  // Print UID byte in hexadecimal
    lcd.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    lcd.print(mfrc522.uid.uidByte[i], HEX);  // Print UID byte on the LCD in hexadecimal
  Serial.println();  // Print a newline on the serial monitor
  1. authenticateBlock function: Handles reading a specific block from the RFID card, authenticating access to the block, and then displaying the retrieved data on the LCD.
// Function to authenticate and read a block from the RFID card
bool authenticateBlock(byte block, byte *buffer, byte &size) {
  MFRC522::StatusCode status;  // Variable to hold the status of RFID operations
  MFRC522::MIFARE_Key key;     // Variable to hold the authentication key
  // Set the key to the default key known as FFFFFFFFFFFFh
  for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;  // Default key A for authentication
  // Authenticate the desired block with the key
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("Authentication failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return false;  // If authentication failed, return false
  // Read the block after successful authentication
  status = mfrc522.MIFARE_Read(block, buffer, &size);
    Serial.print(F("Reading failed: "));
    return false;  // If reading failed, return false
  buffer[size - 1] = '\0';  // Ensure the string is null-terminated
  return true;              // Return true if reading is successful
  1. readAndDisplayBlock function: This function attempts to authenticate a specific block on the RFID card using a predefined key. It reads the data if authentication is successful.
// Function to read a block and display its contents
void readAndDisplayBlock(byte block) {
  byte buffer[18];                               // Buffer to store the data read from the RFID card
  byte size = sizeof(buffer);                    // Variable to store the size of the data read
  if (authenticateBlock(block, buffer, size)) {  // If authentication and reading are successful
    lcd.setCursor(0, 1);                         // Set the cursor to the second line of the LCD
    lcd.print("Name: ");                         // Print "Name:"
    // Print the name starting from the second character to skip the size byte
    lcd.print((char *)buffer + 1);
    Serial.print("Name: ");
    Serial.println((char *)buffer + 1);  // Print the name on the serial monitor
  1. The code is as follows. You can upload it to the Arduino Uno R3. Afterward, bring your card or tag close to the RFID module’s antenna, and you will see the name and ID displayed on both the LCD and the serial monitor.
Question
Now that you understand how to use the RC522-RFID module for reading or writing card or tag information and displaying it on an LCD, how would you design a common access control system for everyday use? Describe your design approach.
Summary
In this lesson, we learned how to harness the power of RFID technology using the RC522 module. We explored the fundamental concepts, built the necessary circuits, wrote and read personal data to and from RFID tags, and displayed the information on an LCD. By the end of this lesson, you should be well-equipped to integrate RFID technology into your own projects, making your systems more efficient and user-friendly.
