13. Joystick LED Navigator
When you think of a thumb joystick, a game controller likely comes to mind. However, beyond gaming, these versatile devices are excellent for various DIY electronics projects. They can be used to control robots or rovers, or even manage camera movements.
In this project-based course, you will learn how to interface a joystick with an Arduino to control LEDs according to the joystick’s movements. We’ll explore the working principles of the joystick, utilize the Serial Monitor to read and debug outputs, and develop control logic to activate LEDs in specified directions. This course emphasizes practical applications, making it directly applicable to real-life scenarios where precise directional control is crucial.
By the end of this course, you will be able to:
Understand the working principle of a joystick and its various outputs (X, Y, and SW).
Use the Serial Monitor to read and debug sensor values in Arduino.
Write and understand conditional statements (
if-else if) to control hardware based on input values.
Build the Circuit
Components Needed
1 * Arduino Uno R3 |
4 * LEDs with different colors |
4 * 220Ω Resistor |
1 * Joystick Module |
1 * USB Cable |
1 * Breadboard |
Jumper Wires |
Building Steps
Follow the wiring diagram, or the steps below to build your circuit.
Find a Joystick module.
A joystick module, also known as a joystick sensor, is an input device that measures the movement of a knob in two directions, horizontal (X-axis) and vertical (Y-axis).
GND: Connects to ground.
+5V: Powers the module, compatible with 3.3V to 5V.
VRX: Outputs analog values representing the X-axis position.
VRY: Outputs analog values representing the Y-axis position.
SW: Provides a digital output when the joystick button is pressed. For reliable operation, use an external pull-up resistor, which keeps the SW pin high when idle and low when pressed.
Joystick operates based on the resistance change of two potentiometers (usually 10-kilo ohms). By changing resistance in x and y directions, Arduino receives varying voltages which are interpreted to x and y coordinates. The processor needs an ADC unit to change the joystick’s analog values into digital values and perform necessary processing.
Arduino boards have six 10-bits ADC channels. It means the Arduino’s reference voltage (5 volts) is divided to 1024 segments. When joystick moves along the x-axis, the ADC value rises from 0 to 1023, with the value 512 in the middle. The image below displays the ADC approximate value based on the joystick position.
The joystick also features an inward press function, like a button, useful for selecting menu options or other interactive elements.
Here is how to connect each pin of the joystick module to the Arduino Uno R3
Arduino Uno R3 |
Joystick |
GND |
GND(negative rail of breadboard) |
+5v |
5v |
VRX |
A0 |
VRY |
A1 |
SW |
Insert four differently colored LEDs into the breadboard. Connect the cathode (short pin) of each LED to the breadboard’s negative rail, and the anode (long pin) into specific ports (58A, 53A, 49A, and 45A).
Insert a 220-ohm resistor in the same row as each LED’s anode, protecting the LEDs from excessive current.
Use a jumper wire to connect 58J hole on the breadboard to pin 11 on the Arduino, enabling control over the first LED.
Similarly, connect the other three LEDs to pins 10, 9, and 8 on the Arduino, respectively.
Do not forget to ground your circuit. Connect the Arduino Uno R3’s GND pin to the breadboard’s negative rail and use a jumper wire to connect both negative rails on the breadboard.
Code Creation- Read from Joystick Module
Let’s take a look at what the values from the joystick module’s X-axis, Y-axis, and button look like. For this, we’ll use a tool called the Serial Monitor.
The Serial Monitor is an essential tool when creating projects with Arduino. It can be used as a debugging tool, testing out concepts or to communicate directly with the Arduino board.
Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
Save your sketch as
Lesson13_Joystick_ModuleusingCtrl + Sor by clicking “Save”.Create three variables to store the values from the three pins of the joystick module.
const int xPin = A0; //the VRX attach to
const int yPin = A1; //the VRY attach to
const int swPin = 2; //the SW attach to
// put your main code here, to run repeatedly:
Also, using the Arduino software pull-up feature, set the
swPinas input while also enabling it asPULLUP.
pinMode(swPin, INPUT_PULLUP); // Set sw Pin as input with an internal pull-up resistor
To activate the Serial Monitor, you must initiate serial communication on your Arduino Uno R3. This is typically done in the
void setup()section of your sketch with the commandSerial.begin(baud). Here,baudindicates the data transfer rate per second between the computer and the Arduino Uno R3, with common rates being 9600 and 115200 bits per second.
Serial.begin(9600); // Begin serial communication with a baud rate of 9600
Now, create three variables
xValue,yValue, andswValueto store the values from the X, Y, and SW pins respectively.
// Read the joystick values
int xValue = analogRead(xPin);
int yValue = analogRead(yPin);
int swValue = digitalRead(swPin);
You are now ready to use the Serial Monitor to print data. You will utilize
Serial.print()to display data and other texts.
Here’s how to use it:
Serial.print(val)orSerial.print(val, format): Prints data to the serial port as human-readable ASCII text.
- Parameters
Serial: serial port object.
val: the value to print. Allowed data types: any data type.- Returns
print()returns the number of bytes written, though reading that number is optional. Data type: size_t.
This command can represent various data types and formats, including numbers, floating points, bytes, and strings. For example:
Serial.print(78); // outputs "78"
Serial.print(78, BIN); // outputs "1001110"
Serial.print(1.23456); // outputs "1.23"
Serial.print(1.23456, 0); // outputs "1"
Serial.print('N'); // outputs "N"
Serial.print("Hello world."); // outputs "Hello world."
Now, use this command to print a prompt indicating the data about to be printed. This is helpful when differentiating multiple data prints at once.
Serial.print("X: ");
Next, print the value from the Joystick module’s VRX pin.
Serial.print(xValue); // print the value of VRX
Use the same method to print the values from the VRY pin and SW pin.
To ensure each output appears on a new line in the Serial Monitor, use
Serial.println()for the SW pin value, which adds a newline character at the end of the print statement.Using
delay(100)ensures a time interval before the next set of data appears. It is recommended to add a delay when printing data to the Serial Monitor to prevent it from refreshing too quickly, which could cause it to crash.
Serial.print(" | Y: ");
Serial.print(yValue); // print the value of VRX
Serial.print(" | SW: ");
Serial.println(swValue); // print the value of SW
delay(100);
The complete code is shown below. You can now click Upload to transfer the code to your Arduino Uno R3.
delay(100);
Afterward, click on the “Serial Monitor” button in the top right corner of the Arduino IDE.
If you see garbled data displayed, you will need to adjust the baud rate to match the one set in your code.
Once uploaded, move the joystick around, and you’ll notice the X and Y values fluctuate between 0 and 1023. Press and release the joystick, and observe the SW pin toggling between 0 and 1.
X: 617 | Y: 1022 | SW: 1
X: 767 | Y: 1023 | SW: 1
X: 1022 | Y: 1022 | SW: 1
X: 516 | Y: 522 | SW: 1
X: 517 | Y: 524 | SW: 1
Now that you know how to print data to the Serial Monitor, let’s explore some buttons in the Serial Monitor:
Toggle Autoscroll: This allows the data to scroll so you can always see the latest readings.
Toggle Timestamp: Turn on timestamps to see data stamped with the exact time to the second.
Clear Output: This is used to clear the data currently displayed on the screen.
Questions
The X and Y axes of the joystick module return analog values, while the SW pin returns a digital value. In previous steps, we’ve already seen these values on the Serial Monitor.
Please summarize the differences between digital and analog values in Arduino programming.
Code Creation - Controlling LEDs Based on Joystick Movements
This tutorial outlines how to program LEDs to respond to the movements of a joystick.
Setup each LED to indicate the direction of joystick movement:
Up Indicator: Connect an LED to pin 10. It lights up when the joystick is pushed up (Y-axis value decreases).
Down Indicator: Connect an LED to pin 9. It lights up when the joystick is pushed down (Y-axis value increases).
Left Indicator: Connect an LED to pin 11. It lights up when the joystick is pushed left (X-axis value decreases).
Right Indicator: Connect an LED to pin 8. It lights up when the joystick is pushed right (X-axis value increases).
This raises a question: How does the Arduino Uno R3 know which direction you are moving the joystick?
Ideally, when the joystick is centered, the values should be (1024/2=512). Therefore, to determine if the joystick is pushing up, down, left, or right, we simply check if the values are greater than or less than 512.
However, due to possible design inaccuracies in the module or resistance in the connections, the values might deviate from 512 even when the joystick is centered. This could lead to misinterpretations by the Arduino Uno R3, such as mistakenly lighting the left indicator LED if the X value is already less than 512 without actual movement.
Therefore, a threshold around the midpoint (512±100) is used:
Up: Y-axis value less than 412.
Down: Y-axis value greater than 612.
Left: X-axis value less than 412.
Right: X-axis value greater than 612.
Now start writing the sketch. Open the sketch you saved earlier,
Lesson13_Joystick_Module. Hit “Save As…” from the “File” menu, and rename it toLesson13_Joystick_Module_LEDs. Click “Save”.Initialize variables to define the four LEDs.
// Define pins for the LEDs
const int ledLeft = 11;
const int ledRight = 8;
const int ledUp = 10;
const int ledDown = 9;
// Define pins for the joystick
Now in
void setup()set all four LED pins to output.
// Initialize LED pins as outputs
pinMode(ledLeft, OUTPUT);
pinMode(ledRight, OUTPUT);
pinMode(ledUp, OUTPUT);
pinMode(ledDown, OUTPUT);
In this project, we don’t need to constantly check the joystick values, so select the five lines
Serial.print(), and pressCtrl + /to comment them out.
// Serial.print("X: ");
// Serial.print(xValue); // print the value of VRX
// Serial.print(" | Y: ");
// Serial.print(yValue); // print the value of VRX
// Serial.print(" | SW: ");
// Serial.println(swValue); // print the value of SW
// Add a small delay to stabilize readings
delay(100);
Before lighting up the corresponding LED according to the movement of the joystick, first turn off all four LEDs.
// First, turn off all LEDs
digitalWrite(ledLeft, LOW);
digitalWrite(ledRight, LOW);
digitalWrite(ledUp, LOW);
digitalWrite(ledDown, LOW);
delay(100);
To sequentially light up each LED based on the X and Y values of the Joystick module, you will need multiple conditions. You can use
ifto specify actions for different ranges of potentiometer values:
If the Y-axis value is less than 412, then the “up” indicator should be lit.
If the Y-axis value is greater than 612, then the “down” indicator should be lit.
If the X-axis value is less than 412, then the “left” indicator should be lit.
If the X-axis value is greater than 612, then the “right” indicator should be lit.
However, managing these conditions separately can be inefficient, as Arduino needs to check each one in every loop cycle.
To streamline this, utilize the if-else if structure:
if (condition 1) {
// Execute if condition 1 is true
else if (condition 2) {
// Execute if condition 2 is true
else if (condition 3) {
// Execute if condition 3 is true
else {
// Execute if none of the conditions are true
In an if-else if structure, the first condition is tested. If it’s true, the associated commands are executed, and all other conditions are skipped (even if some of them are true). If the first condition is false, it tests the second condition in the structure. If the second condition is true, it executes the commands associated with this condition and then skips the others. If it is false, it tests the third condition, and so on. In some scenarios, there can be multiple true conditions. Therefore, the order of conditions is important. Only the first true condition will have its associated commands run.
First, when the
yValueis less than 412, use thedigitalWrite()function to set the “up” indicator light toHIGHto turn it on.
// Check joystick positions and set LEDs accordingly
if (yValue < 412) {
// Joystick up
digitalWrite(ledUp, HIGH);
Add an
else ifstatement to light up the “down” indicator when theyValueexceeds 612.
if (yValue < 412) {
// Joystick up
else if (yValue > 612) {
// Joystick down
digitalWrite(ledDown, HIGH);
To light up the “left” indicator when the
xValueis below 412, insert anotherelse ifcondition like this:
if (yValue < 412) {
// Joystick up
} else if (yValue > 612) {
// Joystick down
} else if (xValue < 412) {
// Joystick left
digitalWrite(ledLeft, HIGH);
Similarly, add another
else ifcondition to light up the right indicator when thexValueexceeds 612.
if (yValue < 412) {
// Joystick up
// Joystick down
// Joystick left
} else if (xValue > 612) {
// Joystick right
digitalWrite(ledRight, HIGH);
Finally, inside the
elseblock to turn off all four LEDs usingdigitalWrite(). This block contains commands that run when none of the other conditions are true.
if (yValue < 412) {
// Joystick up
// Joystick down
// Joystick left
// Joystick right
} else {
// Joystick in the middle, turn off all LEDs
Your complete code is as follows. Click “Upload” to send the code to your Arduino Uno R3.
if (yValue < 412) {
// Joystick up
// Joystick down
// Joystick left
// Joystick right
} else {
delay(100);
Now wiggle the joystick, and you will see the corresponding directional LEDs light up.
Up Indicator lights up when the joystick is pushed up (Y-axis value decreases).
Down Indicator lights up when the joystick is pushed down (Y-axis value increases).
Left Indicator lights up when the joystick is pushed left (X-axis value decreases).
Right Indicator lights up when the joystick is pushed right (X-axis value increases).
Question
In the last code, we controlled the corresponding LEDs based on the X and Y values of the joystick. How would you modify the code to adjust the brightness of these LEDs while they are lit?
What is the difference in behavior of the LED connected to pin 8 compared to those on other pins, and why?
Summary
In this lesson, you learned about the operational principles of the Joystick module and utilized the Serial Monitor tool to read X, Y, and SW values from the joystick. You gained an understanding of the differences between analog and digital values in Arduino programming. Additionally, you mastered the use of advanced conditional statements, specifically if-else if constructs, to control hardware based on input values.
