25. Reverse Radar System
When reversing a car, it is crucial to be aware of obstacles behind the vehicle, especially in situations with limited visibility. To enhance safety, many modern vehicles are equipped with reverse radar systems.
Today, we’re going to learn how to build and program an ultrasonic radar system using Arduino. This system will use an ultrasonic sensor to measure distances and provide feedback through an LCD display and a buzzer. We’ll go through each section of the code, explaining what it does and why it’s important.
Reverse Radar System Evolution
The development of reverse radar systems, also known as parking sensors, began in the late 20th century to address the need for safer vehicle parking. Initially developed in the 1970s using ultrasonic technology similar to marine sonar, these systems used sound waves to detect objects and calculate distances.
Significant advancements came in the 1990s with the introduction of microcontroller-based systems and electromagnetic sensors, which provided more precise measurements and improved vehicle integration. This period saw the incorporation of these sensors into luxury vehicles, enhancing both safety and luxury appeal.
By the early 2000s, reverse radar systems had advanced to include visual, auditory, and haptic feedback, along with digital displays and integration with vehicle navigation systems, offering drivers real-time, comprehensible information about their surroundings.
Today, the technology continues to evolve with the integration of AI and IoT, using a mix of cameras, radar, and ultrasonic sensors to provide a detailed view of the vehicle’s environment, reducing accident risks and easing parking. This technology is now a fundamental component of the autonomous driving systems poised to revolutionize the automotive industry.
Building the Circuit
Components Needed
1 * Arduino Uno R3 |
1 * Ultrasonic Module |
1 * Active Buzzer |
1 * I2C LCD1602 |
1 * USB Cable |
1 * Breadboard |
Jumper Wires |
Building Step-by-Step
Follow the wiring diagram, or the steps below to build your circuit.
Insert the ultrasonic module into the breadboard.
Connect the VCC pin of the ultrasonic module to the positive side of the breadboard, the Trig pin to pin 8 on the Arduino board, the Echo pin to pin 7, and the GND to the negative side of the breadboard.
Insert the active buzzer (with a white sticker) into the breadboard. Connect the “+” pin to pin 9 and the “-” pin to GND.
Connect the I2C LCD1602 module: GND to the negative rail on the breadboard, VCC to the positive rail on the breadboard, SDA to pin A4, and SCL to pin A5.
Finally, connect the GND and 5V pins of the Arduino Uno R3 to the negative and positive rails of the breadboard, respectively.
Code Creation
In a reverse radar system, each component plays a critical role in ensuring accurate distance measurement and effective feedback:
The ultrasonic sensor is used to detect the distance to objects in front of it.
The I2C LCD1602 is used to display the distance detected by the ultrasonic sensor.
The active buzzer is used to change the beeping interval based on the distance measured by the ultrasonic sensor.
Here is how the system reacts based on different distance ranges:
Less than 10cm: The buzzer beeps at a rapid interval of 100 milliseconds.
Between 10cm and 20cm: The beeping interval increases to 500 milliseconds.
Between 20cm and 50cm: The interval extends further to 1000 milliseconds (1 second).
Greater than 50cm: The buzzer beeps at a relaxed interval of 2000 milliseconds (2 seconds).
Now, let’s start coding to see how we can implement the functionality described above.
If you are not familiar with the ultrasonic sensor, I2C LCD1602, or active buzzer, you can first learn their basic usage in the following projects:
Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
Save your sketch as
Lesson25_Reverse_Radar_SystemusingCtrl + Sor by clicking “Save”.First, we include the necessary libraries for using the LCD and initialize it with the correct I2C address and size.
LiquidCrystal I2C library is used here, you can install it from the Library Manager.
#include <Wire.h>
// Initialize the LCD with I2C address 0x27 and size 16x2
LiquidCrystal_I2C lcd(0x27, 16, 2);
Next, define the pins on the Arduino that connect to the ultrasonic sensor’s trigger, echo, and the buzzer.
#define TRIGGER_PIN 8 // Pin to trigger the ultrasonic pulse
#define ECHO_PIN 7 // Pin to receive the echo
#define BUZZER_PIN 9 // Pin for the buzzer
Set up variables to control how frequently the buzzer beeps based on the distance measured.
// Timing variables to control the beeping frequency based on distance
unsigned long intervals = 1000; // Default interval for beeping
unsigned long previousMillis = 0; // Store last time the buzzer beeped
// Distance measurement variable
long distance = 0;
In the
void setup()function, configure the pin modes and initialize the LCD and serial communication.
pinMode(TRIGGER_PIN, OUTPUT); // Set the trigger pin as output
pinMode(ECHO_PIN, INPUT); // Set the echo pin as input
pinMode(BUZZER_PIN, OUTPUT); // Set the buzzer pin as output
lcd.init(); // Initialize the LCD
lcd.backlight(); // Turn on LCD backlight
Serial.begin(9600); // Start serial communication at 9600 baud rate
The main loop continuously measures the distance, adjusts the beeping interval, and updates the LCD display.
distance = measureDistance(); // Measure distance
// Adjust intervals based on distance
adjustBeepingInterval();
unsigned long currentMillis = millis(); // Get current time
// Check if it's time to beep
if (currentMillis - previousMillis >= intervals) {
Serial.println("Beeping!");
beep();
previousMillis = currentMillis; // Update previousMillis directly here
updateLCD(); // Update the LCD display
delay(100); // Short delay to stabilize readings
First, we use the
measureDistance()function to determine the distance using the ultrasonic sensor.
Next, adjust the beeping frequency based on the newly measured distance using the
adjustBeepingInterval()function. This dynamically changes how often the buzzer sounds based on how close the detected object is.
The
millis()function is then called to record the current time in milliseconds since the Arduino board started running the program.
Check if the time elapsed since the last beep is greater than or equal to the set interval. If it is, print a message to the serial monitor, activate the buzzer, and reset the
previousMillis. This ensures the buzzer operates at intervals adjusted to the distance, maintaining consistent alert timing.
beep();
Finallly, call
updateLCD()function to update the LCD with the current distance measurement.
About
adjustBeepingInterval()function: Adjust the beeping interval based on the distance measured. This function sets theintervalsvariable. The closer the object, the shorter the interval, making the buzzer beep more frequently as objects get closer.
// Function to adjust intervals based on distance
void adjustBeepingInterval() {
if (distance <= 10) {
intervals = 100;
} else if (distance <= 20) {
intervals = 500;
} else if (distance <= 50) {
intervals = 1000;
} else {
intervals = 2000;
About
beep()function: Turn the buzzer on, then off after a brief pause.
// Function to make buzzer beep
void beep() {
digitalWrite(BUZZER_PIN, HIGH); // Turn buzzer ON
delay(100); // Beep duration: 100 milliseconds
digitalWrite(BUZZER_PIN, LOW); // Turn buzzer OFF
About
measureDistance()funtion: Measure distance using the ultrasonic sensor. This function sends ultrasonic waves and measures how long it takes for the echo to return. Thedistanceis calculated based on the travel time of these waves.
// Function to measure distance using the ultrasonic sensor
long measureDistance() {
digitalWrite(TRIGGER_PIN, LOW); // Ensure trigger pin is low
delayMicroseconds(2);
digitalWrite(TRIGGER_PIN, HIGH); // Send a high pulse
delayMicroseconds(10); // Pulse duration
digitalWrite(TRIGGER_PIN, LOW); // End the pulse
long duration = pulseIn(ECHO_PIN, HIGH); // Measure the duration of high level on Echo pin
long distance = duration * 0.034 / 2; // Calculate the distance in cm
return distance;
About
updateLCD()function: Update the LCD only if the measured distance changes, reducing unnecessary updates. It displays the current distance on the LCD.
// Function to update the LCD display with distance
void updateLCD() {
static float lastDistance = -1; // Store last distance displayed
if (distance != lastDistance) {
lcd.clear(); // Clear LCD display
lcd.setCursor(0, 0); // Set cursor at beginning
lcd.print("Dis: ");
lcd.print(distance);
lcd.print(" cm");
lastDistance = distance; // Update last displayed distance
Now that you’ve written all parts of the code, upload it to your Arduino board to see if it works as expected.
#include <Wire.h>
long distance = 0;
beep();
intervals = 100;
intervals = 500;
intervals = 1000;
} else {
intervals = 2000;
void beep() {
return distance;
void updateLCD() {
lcd.print("Dis: ");
lcd.print(" cm");
Finally, remember to save your code and tidy up your workspace.
Question
In this project, we used an active buzzer to serve as an alert mechanism, but a passive buzzer could also be used to achieve similar functionality. If you were to replace the active buzzer with a passive buzzer, how should the code be modified?
Summary
Throughout this course, we embarked on a journey from conceptual understanding to practical implementation of a reverse radar system. Starting with assembling the circuit on a breadboard, we connected an ultrasonic sensor, an active buzzer, and an LCD display to an Arduino board. Following the hardware setup, we dove into the coding aspect where you learned to manipulate sensor data to trigger auditory and visual feedback based on the distance of obstacles behind a vehicle.
You’ve now successfully programmed your Arduino to measure distances and provide alerts through a buzzer and visual feedback via an LCD, mimicking the functionality of advanced reverse radar systems found in modern cars. This not only demonstrates your ability to integrate various electronic components but also highlights your skill in creating a system that could enhance vehicular safety.
