11. The Colors of the Rainbow
Imagine if you could paint with light, blending red, green, and blue to create every hue imaginable—just like mixing paints on a palette but with beams of light.
Welcome to this lesson, where you will explore the captivating world of RGB LEDs and discover how the combination of primary colors can create a vibrant spectrum of hues. This hands-on course will guide you through the principles of RGB LED functionality and introduce you to the practical applications of programming and circuit building.
In this lesson, you will learn:
Understand the operational principles of RGB LEDs.
Learn to create and utilize functions in your code to simplify tasks and enhance readability.
Explore the impact of different color combinations by manipulating the RGB LED.
Learn to use Pulse Width Modulation (PWM) for nuanced color mixing with RGB LED.
Enhance your coding efficiency and clarity by creating functions that take parameters in Arduino.
Building the Circuit
Components Needed
1 * Arduino Uno R3 |
1 * RGB LED |
3 * 220Ω Resistor |
Jumper Wires |
1 * USB Cable |
1 * Breadboard |
1 * Multimeter |
Step-by-Step Building Instructions
Follow the wiring diagram or these steps to construct the circuit.
Start with an RGB LED.
RGB LEDs emit light in various colors by integrating red, green, and blue LEDs within a single package. By varying the voltage input on the three pins, these LEDs can combine to produce up to 16,777,216 different colors.
Depending on their design, RGB LEDs can be either common anode or common cathode. For this project, we use a common cathode RGB LED, where all three LEDs share a negative connection.
Common cathode RGB LEDs have a shared negative connection.
Common anode RGB LEDs have a shared positive connection.
An RGB LED typically has 4 pins; the longest one is the ground. When placing the RGB LED, ensure the longest lead is second from the left, configuring the pins as Red, GND, Green, and Blue from left to right.
You can also use a multimeter in Diode Test mode to identify the color each pin emits.
Set the multimeter to the Continuity setting for resistance measurement.
Touch the black lead of the multimeter to the RGB LED’s longest pin, and touch the red lead to the other pins individually. You will see the RGB LED light up in red, green, or blue accordingly.
Insert the RGB LED into the breadboard with the longest pin going into hole 17D, and the other three pins into 18C, 16C, and 15C, respectively.
Insert three 220ohm resistors as shown from holes 15E to 15G, 16E to 16G, and 18E to 18G.
Connect these resistors to pins 9, 10, and 11 on the Arduino Uno R3 with jumper wires as illustrated.
Connect the longest pin of the RGB LED to breadboard’s negative rail using a jumper wire.
Code Creation - Lighting Up an RGB LED
Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
Save your sketch as
Lesson11_Rainbow_ColorusingCtrl + Sor by clicking “Save”.Create three variables to store the three pins of the RGB LED and set them as OUTPUT.
const int redPin = 11;
const int greenPin = 10;
const int bluePin = 9;
pinMode(bluePin, OUTPUT); // Set Blue pin of RGB LED as output
pinMode(greenPin, OUTPUT); // Set Green pin of RGB LED as output
pinMode(redPin, OUTPUT); // Set Red pin of RGB LED as output
// put your main code here, to run repeatedly:
Now in the
void loop()set the RGB LED’s red pin toHIGH, and the other two pins toLOW.
Since we are using PWM pins 9, 10, and 11, you have the option to use either digitalWrite() or analogWrite() to output a high or low level.
For this lesson, as we are simply setting the pins to high or low, we’ll use digitalWrite().
digitalWrite(bluePin, LOW); // Turn off the Blue pin of RGB LED
digitalWrite(greenPin, LOW); // Turn off the Green pin of RGB LED
digitalWrite(redPin, HIGH); // Turn on the Red pin of RGB LED
Save the code and click “Upload” to send it to your Arduino Uno R3. Let’s see what happens.
You will see the RGB LED light up red. But what if you want to light up green and blue too? How should you modify the code?
Now copy the three digitalWrite() commands twice more. Set the pin you want to display as HIGH and the others as LOW. Each color lighting up should be given a second to shine.
delay(1000); //Wait for 1 second
digitalWrite(greenPin, HIGH); // Turn on the Green pin of RGB LED
digitalWrite(redPin, LOW); // Turn off the Red pin of RGB LED
digitalWrite(bluePin, HIGH); // Turn on the Blue pin of RGB LED
Upload the code again to see the effects. You will find the RGB LED cycles through red, green, and blue.
Questions:
If you want other colors, what should you do? Refer to the diagram below and fill in your ideas in your handbook.
Color |
Red Pin |
Green Pin |
Blue Pin |
Red |
HIGH |
LOW |
LOW |
Green |
LOW |
HIGH |
LOW |
Blue |
LOW |
LOW |
HIGH |
Yellow |
Pink |
Cyan |
White |
Code Creation - Displaying Colors
In our journey to master the control of RGB LEDs, we’ve seen how using digitalWrite() can light up the LED in basic colors. To further explore and unlock the full spectrum of colors that an RGB LED can produce, we’ll now delve into using analogWrite() to send PWM (Pulse Width Modulation) signals, allowing us to achieve a wide range of hues.
Let’s see how we can implement this with code.
Save your sketch as
Lesson11_PWM_Color_MixingusingCtrl + Sor by clicking “Save”.Create three variables to store the three pins of the RGB LED and set them as OUTPUT.
// Set up code to run once:
Use
analogWrite()to send PWM values to the RGB LED. From Lesson 9, we know that PWM values can change an LED’s brightness, and the PWM range is 0-255. To display red, we set the PWM value of the RGB LED’s red pin to 255, and the other two pins to 0.
// Main code to run repeatedly:
analogWrite(bluePin, 0); // Set the PWM value of Blue pin to 0
analogWrite(greenPin, 0); // Set the PWM value of Green pin to 0
analogWrite(redPin, 255); // Set the PWM value of Red pin to 255
With this setup, after uploading the code to the Arduino Uno R3, you will see the RGB LED display red.
The
analogWrite()function allows the RGB LED to display not only the seven basic colors but many other different hues. Now you can adjust the values of pins 9, 10, and 11 separately, and record the observed colors in your handbook.
Red Pin |
Green Pin |
Blue Pin |
Color |
0 |
128 |
128 |
128 |
0 |
255 |
128 |
128 |
255 |
255 |
128 |
0 |
Code Creation - Parameterized Functions
Using the analogWrite() function to display different colors can make your code lengthy if you want to display many colors simultaneously. Therefore, we need to create functions.
Unlike the previous lesson, we are preparing to create a function with parameters.
A parameterized function allows you to pass specific values into the function, which can then use these values to perform its tasks. This is incredibly useful for adjusting properties like color intensity on the fly. It makes your code more flexible and easier to read.
When defining a parameterized function, you specify what values it needs to operate through parameters listed in parentheses right after the function name. These parameters act like placeholders that get replaced by actual values when the function is called.
Here’s how to define a parameterized function for setting the color of an RGB LED:
Open the sketch you saved earlier,
Lesson11_PWM_Color_Mixing. Hit “Save As…” from the “File” menu, and rename it toLesson11_PWM_Color_Mixing_Function. Click “Save”.Start by declaring the function after the
void loop()with the keywordvoid, followed by the function name and parameters in parentheses. For oursetColorfunction, we’ll use three parameters—red,green, andblue—each representing the intensity of the corresponding color component of the RGB LED.
void setColor(int red, int green, int blue) {
Within the function body, use the
analogWrite()command to send PWM signals to the RGB LED pins. The values passed tosetColorwill determine the brightness of each color. The parametersred,green, andblueare used here to directly control the intensity of each LED pin.
// Function to set the color of the RGB LED
// Write PWM value for red, green, and blue to the RGB LED
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
Now you can call your newly created
setColor()function in thevoid loop(). Since you created a function with parameters, you need to fill in the arguments in the()such as(255, 0, 0). Remember to write comments.
setColor(255, 0, 0); // Display red color
We already know that by providing different values to the three pins of the RGB LED, we can light up different colors of light. So, how do we make the RGB LED light up exactly the color we want? This requires the aid of a color palette. Open Paint (this software comes with Windows) or any drawing software on your personal computer.
Choose a color you like, record its RGB values.
Note that before you select a color, adjust the lumens to the proper position.
Fill in the color you selected into the
setColor()function in thevoid loop(), use thedelay()function to specify the display time for each color.
delay(1000); // Wait for 1 second
setColor(0, 128, 128); // Display teal color
setColor(128, 0, 255); // Display purple color
setColor(128, 128, 255); // Display Light blue color
setColor(255, 128, 0); // Display orange color
Below is the complete code; you can click “Upload” to upload the code to the Arduino Uno R3 to see the effects.
Finally, remember to save your code and tidy up your workspace.
Summary
Through a series of coding exercises, you will write sketches that dynamically change the color of the RGB LED. Starting with basic commands to control each color, you will then refactor your code to use functions, making your setup more modular and maintainable. This approach not only makes the code cleaner but also teaches you about the importance of function in programming.
