22. Remote-Controlled Colorful Light
As Christmas approaches, many people decorate their homes with colorful lights. Imagine creating your own remote-controlled colorful light setup! In this lesson, we’ll use an Arduino, an infrared receiver, and an RGB LED to make a festive, programmable light display.
By the end of this lesson, you will be able to:
  • Understand how an infrared receiver works.
  • Decode infrared signals from a remote control.
  • Control an RGB LED using decoded signals to display various colors and effects.
Building the Circuit
Components Needed
1 * Arduino Uno R3
1 * RGB LED
3 * 220Ω Resistor
1 * IR Receiver
list_uno_r3
list_rgb_led
list_220ohm
list_receiver
1 * Remote Control
1 * Breadboard
Jumper Wires
1 * USB Cable
list_remote
list_breadboard
list_wire
list_usb_cable
Building Step-by-Step
Follow the wiring diagram, or the steps below to build your circuit.
../_images/22_receiver_gnd_5v.png
  1. Find the infrared receiver.
../_images/22_receiver_pin.png
  • OUT: Signal output
  • GND: Ground
  • VCC: Power supply, 2.5V~5V
The SL838 infrared receiver is a component that receives infrared signals and can independently receive infrared rays and output signals compatible with TTL level. It is similar in size to a normal plastic-packaged transistor and is suitable for all kinds of infrared remote control and infrared transmission.
Infrared (IR) communication is a popular, low-cost, and easy-to-use wireless communication technology. Infrared light has a slightly longer wavelength than visible light, making it imperceptible to the human eye—ideal for wireless communication. A common modulation scheme for infrared communication is 38KHz modulation.
  1. The infrared receiver is paired with a 21-key remote control.
../_images/22_receiver_remote_control.jpeg
This sleek remote features 21 keys for various functions, boasting an effective transmission distance of up to 8 meters. Its compact dimensions (85x39x6mm) make it ideal for small hands, while the 3V key-type lithium manganese battery ensures long-lasting performance. Operating at an infrared carrier frequency of 38KHz and wrapped in a durable 0.125mm PET surface, this remote is built to withstand over 20,000 uses, making it a reliable choice for controlling a wide range of devices.
  1. Insert the infrared receiver into the breadboard. The infrared receiver has a front and back side, with the protruding side being the front. The pin order from left to right is OUT, GND, and VCC.
../_images/22_receiver_receiver.png
  1. Connect the OUT pin of the infrared receiver to pin 2 on the Arduino Uno R3, GND to the negative rail of the breadboard, and VCC to the positive rail of the breadboard.
../_images/22_receiver_receiver_pins.png
  1. Insert the RGB LED into the breadboard with its longest pin positioned in the second pin from the left.
../_images/22_receiver_rgb.png
  1. Insert a 220-ohm resistor in the same row as the R, G, and B pins.
../_images/22_receiver_rgb_resistors.png
  1. Connect these resistors to pins 9, 10, and 11 on the Arduino Uno R3 with jumper wires as illustrated.
../_images/22_receiver_rgb_pins.png
  1. Connect the longest pin of the RGB LED to the breadboard’s negative rail using a jumper wire.
../_images/22_receiver_rgb_gnd.png
  1. Finally, connect the GND and 5V pins of the Arduino Uno R3 to the negative and positive rails of the breadboard, respectively.
Code Creation - Getting the Key Values
Here, we will learn how the infrared receiver works and how it recognizes different key values from the infrared remote control.
  1. Open the Arduino IDE and start a new project by selecting “New Sketch” from the “File” menu.
  2. Save your sketch as Lesson22_Get_Key_Value using Ctrl + S or by clicking “Save”.
  3. Like the I2C LCD1602, the Arduino IDE does not come with a built-in library for the infrared receiver. You need to manually download it from the Library Manager. Now, search for IRremote in the Library Manager, then click INSTALL.
../_images/22_receiver_install_lib.png
  1. Now, let’s start coding. Before using each library, it is essential to include it in your sketch. Then, define the infrared receiver pin.
#include <IRremote.h>
const int receiverPin = 2;  // Define the pin number for the IR Sensor
  1. In the void setup() function, initialize serial communication at 9600 bps and initialize the IR receiver on the specified pin with LED feedback enabled.
  • The specified pin usually refers to the built-in LED on pin 13 of the Arduino board. Every time you press a key on the remote towards the infrared receiver, the LED on pin 13 of the Arduino board will flash quickly once, indicating that an IR signal has been received.
  // Start serial communication at a baud rate of 9600
  Serial.begin(9600);
  // Initialize the IR receiver on the specified pin with LED feedback enabled
  IrReceiver.begin(receiverPin, ENABLE_LED_FEEDBACK);
  1. In the loop() function, first use the IrReceiver.decode() function to check if the infrared receiver has received a signal. If a signal is received, it will return true.
  if (IrReceiver.decode()) {                                // Check if the IR receiver has received a signal
  1. Next, print the received key value to the Serial Monitor. The Serial.println() function outputs numbers in decimal format by default. To get the hexadecimal key value, set the format to HEX.
    Serial.print("0x");                                     // print the "0x"
    Serial.println(IrReceiver.decodedIRData.command, HEX);  // Print the command from the decoded IR data
    delay(100);
    IrReceiver.resume();                                    // Prepare the IR receiver to receive the next signal
  1. Here is your complete code. You can upload it to the Arduino Uno R3.
#include <IRremote.h>  // Include the IRremote library
  Serial.begin(9600);
    delay(100);
  1. After uploading the code, you can try pressing different keys. You will see the hexadecimal key values being printed to the Serial Monitor.
  • Before pressing the keys, you need to remove the plastic tab at the back of the remote to power it.
  • You may notice that most key values are printed two or three times. This happens because the keys can bounce, so even though it feels like you pressed the key once, the Arduino might detect multiple presses.
0x45
0x45
0x43
0x43
0x7
0x7
Questions
  1. Please carefully press each key on the remote control and record the corresponding key values in the table in your manual.
Key Name
Key Value
Key Name
Key Value
POWER
0x45
0
0x16
MODE
MUTE
PLAY/PAUSE
BACKWARD
FORWARD
EQ
8
CYCLE
9
U/SD
Code Creation - Decoding
Now that we know the key value of each key, remembering each key value can be quite challenging. Let’s write a decode function using a switch-case statement to combine these codes into a function, which can simplify recognizing and responding to each key press.
  1. Open the sketch you saved earlier, Lesson22_Get_Key_Value. Hit “Save As…” from the “File” menu, and rename it to Lesson22_Decode_Key_Value. Click “Save”.
  2. Now, after the void loop(), create a decode function - decodeKeyValue() to take a long integer result, which is the command code received from the IR remote.
// Function to map received IR signals to corresponding keys
String decodeKeyValue(long result) {
  1. Now, uses a switch statement to match this result against predefined hex codes (0x45, 0x47, etc.). Each case in the switch corresponds to a different key on the remote, returning a string that represents the function of that key. If no cases match, ERROR is returned, indicating an unrecognized command.
  switch (result) {
    case 0x45: return "POWER";
    case 0x47: return "MUTE";
    case 0x46: return "MODE";
    case 0x44: return "PLAY/PAUSE";
    case 0x40: return "BACKWARD";
    case 0x43: return "FORWARD";
    case 0x7: return "EQ";
    case 0x15: return "-";
    case 0x9: return "+";
    case 0x19: return "CYCLE";
    case 0xD: return "U/SD";
    case 0x16: return "0";
    case 0xC: return "1";
    case 0x18: return "2";
    case 0x5E: return "3";
    case 0x8: return "4";
    case 0x1C: return "5";
    case 0x5A: return "6";
    case 0x42: return "7";
    case 0x52: return "8";
    case 0x4A: return "9";
    case 0x0: return "ERROR";
    default: return "ERROR";
  1. Now, go back to the loop() function, create a String variable key to store the decoded string (key name), and then print it to the Serial Monitor.
    // Convert the decoded IR signal to a readable command.
    String key = decodeKeyValue(IrReceiver.decodedIRData.command);
    Serial.println(key);  // Print the readable command
    delay(100);
  1. Sometimes, some “error” messages are received. Now, using an if statement, only when key is not equal to ERROR will it print.
    bool result = 0;
    if (key != "ERROR") {
      delay(100);
  Serial.begin(9600);
    bool result = 0;
      delay(100);
  switch (result) {
  1. After opening the Serial Monitor, press the keys on the remote control, and you will see the key names. It is recommended to press all 21 keys to see if the names match the actual keys.
POWER
POWER
MODE
MODE
MUTE
MUTE
FORWARD
BACKWARD
BACKWARD
Code Creation - Remote-Controlled Colorful Light
Now that the infrared receiver and its code are ready, we can use it to control the RGB LED to display different colors. Here are the colors and effects we plan to achieve. You can also customize other colors and effects.
  • Press 1 to display red on the RGB LED.
  • Press 2 to display green on the RGB LED.
  • Press 3 to display blue on the RGB LED.
  • Press 4 to display a flashing orange effect on the RGB LED.
  • Press any other key to turn off the RGB LED.
  1. Open the sketch you saved earlier, Lesson22_Decode_Key_Value. Hit “Save As…” from the “File” menu, and rename it to Lesson22_Remote_Colorful_Light. Click “Save”.
  2. Create three variables to store the three pins of the RGB LED and set them as OUTPUT.
// Define the pins of RBG LED
const int redPin = 11;
const int greenPin = 10;
const int bluePin = 9;
  // Initialize RGB LED pins
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  Serial.begin(9600);
  1. After the loop() function, create a setColor() function to drive the RGB LED to display colors.
// Function to set the color of the RGB LED
void setColor(int red, int green, int blue) {
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
  1. Go back to the loop() function, use if else if statements to determine which key is pressed, and then display the corresponding effect on the RGB LED according to our plan.
    bool result = 0;
      delay(100);
    if (key == "1") {
      setColor(255, 0, 0);  // Red
    } else if (key == "2") {
      setColor(0, 255, 0);  // Green
    } else if (key == "3") {
      setColor(0, 0, 255);  // Blue
    } else if (key == "4") {
      setColor(255, 165, 0);  // Orange
      delay(100);
      setColor(0, 0, 0);  // Turn off RGB LED
      delay(100);
    } else {
      setColor(0, 0, 0);  // Turn off RGB LED for any other key
  1. Here is your complete code. You can upload it to the Arduino Uno R3. Afterward, press the keys on the remote control to see if the desired effects are achieved.
  Serial.begin(9600);
    bool result = 0;
      delay(100);
    if (key == "1") {
      delay(100);
      delay(100);
    } else {
  switch (result) {
  1. Finally, remember to save your code and tidy up your workspace.
Summary
In this lesson, we explored how to use an infrared receiver to decode signals from a remote control and control an RGB LED to display different colors and effects. By integrating the IRremote library and writing functions to interpret remote signals, you learned to create a fun and interactive remote-controlled light display. This project not only enhances your understanding of infrared communication but also showcases how to bring holiday cheer with a custom light setup. Keep experimenting with different colors and patterns to make your lights even more festive!
