fusion_hat._logger のソースコード
import logging
from logging.handlers import RotatingFileHandler
DEBUG = logging.DEBUG
INFO = logging.INFO
WARNING = logging.WARNING
ERROR = logging.ERROR
CRITICAL = logging.CRITICAL
[ドキュメント] class ColoredFormatter(logging.Formatter): COLOR_CODES = { 'DEBUG': '\033[94m', # 蓝色 'INFO': '\033[92m', # 绿色 'WARNING': '\033[93m', # 黄色 'ERROR': '\033[91m', # 红色 'CRITICAL': '\033[95m' # 紫色 } RESET_CODE = '\033[0m' # 重置颜色
[ドキュメント] def format(self, record): levelname = record.levelname color_code = self.COLOR_CODES.get(levelname, '') reset_code = self.RESET_CODE if color_code else '' # 添加颜色代码并保留原始格式 record.levelname = f'{color_code}{levelname}{reset_code}' return super().format(record)
[ドキュメント] class Logger(logging.Logger): """ Logger class """ def __init__(self, name='logger', level=logging.INFO, file:str=None, maxBytes=10*1024*1024, backupCount=10): """ Initialize Logger Args: name (str, optional): Logger name, default is 'logger' level (int, optional): Log level, default is 0 file (str, optional): Log file path, default is None, no log file will be created maxBytes (int, optional): Maximum log file size, default is 10MB backupCount (int, optional): Maximum number of backup log files, default is 10 """ self.log_path = file super().__init__(name, level=level) # Create a handler, used for output to the console console_formatter = ColoredFormatter('[%(levelname)s] %(message)s') console_handler = logging.StreamHandler() console_handler.setLevel(level) console_handler.setFormatter(console_formatter) self.addHandler(console_handler) if file is not None: # Create a handler, used for output to a file file_formatter = logging.Formatter('%(asctime)s.%(msecs)03d [%(levelname)s] %(message)s', datefmt='%y/%m/%d %H:%M:%S') file_handler = RotatingFileHandler(self.log_path, maxBytes=maxBytes, backupCount=backupCount) file_handler.setLevel(level) file_handler.setFormatter(file_formatter) self.addHandler(file_handler)
[ドキュメント] def setLevel(self, level: [int, str]): """ Set log level Args: level (int or str): Log level """ if isinstance(level, str): level = level.upper() super().setLevel(level) for handler in self.handlers: handler.setLevel(level)
