from .llm import LLM
from .stt import STT
from .tts import Piper as TTS
from ._keyboard_input import KeyboardInput
from typing import Callable
NAME = "Buddy"
""" Default assistant name """
WITH_IMAGE = True
""" Enable image, need to set up a multimodal language model """
TTS_MODEL = "en_US-ryan-low"
""" Default TTS model """
STT_LANGUAGE = "en-us"
""" Default STT language """
KEYBOARD_ENABLE = True
""" Enable keyboard input """
WAKE_ENABLE = True
""" Enable wake word """
WAKE_WORD = [f"hey {NAME.lower()}"]
""" Default wake word """
ANSWER_ON_WAKE = "Hi there"
""" Default answer on wake word, set empty to disable """
WELCOME = f"Hi, I'm {NAME}. Wake me up with: " + ", ".join(WAKE_WORD)
""" Default welcome message """
INSTRUCTIONS = f"You are a helpful assistant, named {NAME}."
""" Default set instructions """
[Doku]
class VoiceAssistant:
""" Voice assistant class
Args:
llm (:class:`sunfounder_voice_assistant.llm.LLM`): Language model
name (str, optional): Robot name, default is NAME
with_image (bool, optional): Enable image, need to set up a multimodal language model, default is WITH_IMAGE
tts_model (str, optional): Text-to-speech model, default is TTS_MODEL
stt_language (str, optional): Speech-to-text language, default is STT_LANGUAGE
keyboard_enable (bool, optional): Enable keyboard input, default is KEYBOARD_ENABLE
wake_enable (bool, optional): Enable wake word, default is WAKE_ENABLE
wake_word (list, optional): Wake word, default is WAKE_WORD
answer_on_wake (str, optional): Answer on wake word, default is ANSWER_ON_WAKE
welcome (str, optional): Welcome message, default is WELCOME
instructions (str, optional): Set instructions, default is INSTRUCTIONS
disable_think (bool, optional): Disable think, default is False
def __init__(self,
llm: LLM,
name: str = NAME,
with_image: bool = WITH_IMAGE,
tts_model: str = TTS_MODEL,
stt_language: str = STT_LANGUAGE,
keyboard_enable: bool = KEYBOARD_ENABLE,
wake_enable: bool = WAKE_ENABLE,
wake_word: list = WAKE_WORD,
answer_on_wake: str = ANSWER_ON_WAKE,
welcome: str = WELCOME,
instructions: str = INSTRUCTIONS,
disable_think: bool = False,
) -> None:
self.llm = llm
self.name = name
self.with_image = with_image
self.wake_enable = wake_enable
self.keyboard_enable = keyboard_enable
self.wake_word = wake_word
self.answer_on_wake = answer_on_wake
self.welcome = welcome
self.disable_think = disable_think
self.instructions = instructions.format(name=name)
self.tts = TTS(model=tts_model)
self.stt = STT(language=stt_language)
self.llm.set_instructions(self.instructions)
self.stt.set_wake_words(self.wake_word)
self.waked = False
self.running = False
self.wake_waiting = False
self.wait_wake_thread = None
self.triggers = []
if self.wake_enable:
self.add_trigger(self.trigger_wake_word)
if self.keyboard_enable:
self.keyboard_input = KeyboardInput()
self.add_trigger(self.trigger_keyboard_input)
if self.with_image:
self.init_camera()
[Doku]
def before_listen(self) -> None:
""" Before listen """
[Doku]
def after_listen(self, stt_result: str) -> None:
""" After listen
Args:
stt_result (str): Speech-to-text result
[Doku]
def before_think(self, text: str) -> None:
""" Before think
Args:
text (str): Text to think
[Doku]
def after_think(self, text: str) -> None:
""" After think
Args:
[Doku]
def on_start(self) -> None:
""" On start """
[Doku]
def on_wake(self) -> None:
""" On wake """
[Doku]
def on_heard(self, text: str) -> None:
""" On heard
Args:
text (str): Text heard
[Doku]
def parse_response(self, text: str) -> str:
""" Parse response
Args:
text (str): Text to parse
Returns:
str: Parsed text
return text
[Doku]
def add_trigger(self, trigger_function: Callable[[], tuple[bool, bool, str]]) -> None:
""" Add trigger function
Args:
trigger_function (Callable[[], tuple[bool, bool, str]]): Trigger function
self.triggers.append(trigger_function)
[Doku]
def before_say(self, text: str) -> None:
""" Before say
Args:
text (str): Text to say
[Doku]
def after_say(self, text: str) -> None:
""" After say
Args:
[Doku]
def on_stop(self) -> None:
""" On stop """
[Doku]
def on_finish_a_round(self) -> None:
""" On finish a round """
[Doku]
def capture_image(self, path: str) -> None:
""" Capture image
Args:
path (str): Path to save image
if self.with_image and self.picam2:
self.picam2.capture_file(path)
[Doku]
def trigger_wake_word(self) -> tuple[bool, bool, str]:
""" Trigger wake word
Returns:
tuple[bool, bool, str]: Triggered, disable image, message
triggered = False
disable_image = False
message = ''
if self.stt.is_waked():
# listen
self.stt.stop_listening()
self.on_wake()
if len(self.answer_on_wake) > 0:
self.tts.say(self.answer_on_wake)
print("Waked, Listening ...")
message = self.listen()
self.on_heard(message)
self.waked = False
triggered = True
return triggered, disable_image, message
[Doku]
def init_camera(self) -> None:
""" Initialize camera """
self.picam2 = Picamera2()
self.picam2.configure(self.picam2.create_preview_configuration(main={"size": (640, 480)}))
self.picam2.start()
[Doku]
def close_camera(self) -> None:
""" Close camera """
self.picam2.close()
[Doku]
def listen(self) -> str:
""" Listen
Returns:
str: Speech-to-text result
self.before_listen()
stt_result = ""
for result in self.stt.listen(stream=True):
if self.running == False:
break
if result["done"]:
print(f"heard: {result['final']}")
stt_result = result['final']
print(f"heard: {result['partial']}", end="\r", flush=True)
print("")
if stt_result == False or stt_result == "":
stt_result = None
self.after_listen(stt_result)
return stt_result
[Doku]
def think(self, text: str, disable_image: bool=False) -> str:
""" Think
Args:
disable_image (bool, optional): Disable image, defaults to False
Returns:
str: LLM response
self.before_think(text)
if self.with_image and not disable_image:
image_path = './img_input.jpeg'
self.capture_image(image_path)
image_path = None
kwargs = {
'image_path': image_path,
'stream': True,
if self.disable_think:
kwargs['think'] = False
response = self.llm.prompt(text, **kwargs)
llm_text = ""
for next_word in response:
break
if next_word:
print(next_word, end="", flush=True)
llm_text += next_word
print('')
result = llm_text.strip()
self.after_think(result)
return result
[Doku]
def main(self) -> None:
""" Main loop """
self.running = True
self.on_start()
self.tts.say(self.welcome)
# Main loop
while self.running:
triggered = False
message = ''
# Start listening wake words if wake enabled
self.stt.start_listening_wake_words()
# Start keyboard input
self.keyboard_input.start()
# Wait for triggers
while self.running:
for trigger in self.triggers:
triggered, disable_image, message = trigger()
if triggered:
break
if triggered:
break
time.sleep(0.01)
# Stop listening wake words if wake enabled
# Stop keyboard input
self.keyboard_input.stop()
# think
result = self.think(message, disable_image=disable_image)
response_text = self.parse_response(result)
# tts
_status = False
if response_text != '':
self.before_say(response_text)
self.tts.say(response_text)
# on finish a round
self.on_finish_a_round()
# Wait a second before next round
time.sleep(1)
[Doku]
def run(self) -> None:
""" Run """
self.main()
except Exception as e:
finally:
self.stt.close()
if self.with_image:
self.close_camera()
self.on_stop()
