Quellcode für fusion_hat.user_button
import threading
import warnings
from typing import Callable, Optional
import evdev
from evdev import InputDevice, ecodes
from .device import raise_if_fusion_hat_not_ready
[Doku]
class UserButton:
""" User button class using evdev for Linux input events
def __init__(self) -> None:
raise_if_fusion_hat_not_ready()
self.pressed = False
self.pressed_for = 0
self.pressed_at = time.time()
self._device: Optional[InputDevice] = None
self._device_path: Optional[str] = None
self.__on_click__ = None
self.__on_press__ = None
self.__on_release__ = None
self.__on_press_released__ = None
# 尝试自动查找按钮设备
self._find_button_device()
# 如果找到设备,设置事件监听
if self._device_path:
self._setup_event_listener()
[Doku]
def set_on_click(self, callback: Callable[[], None]) -> None:
""" Set the callback function when the user button is clicked
Args:
callback (Callable[[], None]): callback function
self.__on_click__ = callback
[Doku]
def set_on_press(self, callback: Callable[[], None]) -> None:
""" Set the callback function when the user button is pressed
Args:
self.__on_press__ = callback
[Doku]
def set_on_release(self, callback: Callable[[], None]) -> None:
""" Set the callback function when the user button is released
Args:
self.__on_release__ = callback
[Doku]
def set_on_press_released(self, callback: Callable[[], None]) -> None:
""" Set the callback function when the user button is pressed and released
Args:
self.__on_press_released__ = callback
[Doku]
def set_on_long_press(self, callback: Callable[[], None], duration: float=2.0) -> None:
""" [Deprecated] Set the callback function when the user button is pressed for a long time
Args:
[Doku]
def set_on_long_press_released(self, callback: Callable[[], None], duration: float=2.0) -> None:
""" [Deprecated] Set the callback function when the user button is pressed for a long time and released
Args:
duration (float, optional): long press duration(2.0~5.0)
[Doku]
def _find_button_device(self) -> None:
""" Find the Fusion HAT USR button device """
# 查找名称包含"Fusion HAT USR"的输入设备
devices = [InputDevice(path) for path in evdev.list_devices()]
for device in devices:
if "Fusion HAT USR" in device.name:
self._device = device
self._device_path = device.path
break
except Exception:
# 如果找不到设备,后续通过get_state时会尝试再次查找
[Doku]
def get_state(self) -> bool:
""" Get the state of the user button
Returns:
bool: True if pressed, False if released
# 如果设备未找到,尝试再次查找
if not self._device and not self._device_path:
# 如果仍然没有设备,返回默认状态(未按下)
return False
# 如果设备已经初始化,直接返回当前状态
if self._is_task_running:
return self.pressed
# 否则尝试通过sysfs文件直接读取状态
# 通常在/sys/class/input下可以找到对应的event设备
# 这里我们尝试读取sysfs接口(如果可用)
# 作为备选方案,我们使用轮询检查最新状态
# 临时打开设备并读取最新事件
temp_device = InputDevice(self._device_path)
# 非阻塞方式检查是否有新事件
for event in temp_device.read_loop():
if event.type == ecodes.EV_KEY and event.code == ecodes.BTN_0:
return event.value == 1
# 只读取少量事件就退出
break
temp_device.close()
return self.pressed
except Exception:
return False
[Doku]
def is_pressed(self) -> bool:
Check if the user button is pressed
Returns:
return self.pressed
return self.get_state()
[Doku]
def get_pressed_for(self) -> float:
Get the time the user button has been pressed for
Returns:
float: time in seconds
if self.is_pressed():
return time.time() - self.pressed_at
return self.pressed_for
[Doku]
def _setup_event_listener(self) -> None:
""" 设置事件监听器,在独立线程中处理输入事件 """
def event_handler():
# 确保设备已打开
if not self._device and self._device_path:
self._device = InputDevice(self._device_path)
# 读取输入事件 - 这是一个阻塞调用,直到有事件发生
for event in self._device.read_loop():
# 处理按键事件
pressed = event.value == 1
if pressed:
if not self.pressed:
self.pressed = True
# 触发按下回调
if self.__on_press__ is not None:
self.__on_press__()
except Exception:
# 触发press_released回调(按下状态)
if self.__on_press_released__ is not None:
self.__on_press_released__(True)
except Exception:
if self.pressed:
self.pressed_for = time.time() - self.pressed_at
# 触发释放回调
if self.__on_release__ is not None:
self.__on_release__()
except Exception:
# 触发press_released回调(释放状态)
self.__on_press_released__(False)
except Exception:
# 触发点击回调
if self.__on_click__ is not None:
self.__on_click__()
except Exception:
except Exception:
# 如果发生错误,关闭设备并尝试重新打开
if self._device:
self._device.close()
except Exception:
self._device = None
# 短暂等待后重试
time.sleep(0.1)
# 在守护线程中启动事件处理器
listener_thread = threading.Thread(target=event_handler, daemon=True)
listener_thread.start()
[Doku]
def start(self) -> None:
""" 此方法已弃用,不再需要调用
由于使用了Linux输入事件系统,按钮事件会自动被监听和处理,无需手动启动轮询循环。
warnings.warn(
"UserButton.start() 方法已弃用。由于使用了Linux输入事件系统,按钮事件会自动被监听和处理。",
DeprecationWarning,
stacklevel=2
[Doku]
def stop(self) -> None:
""" 关闭按钮设备连接 """
# 关闭设备
if self._device:
except Exception:
self._device = None
