""" I2C bus read/write functions
A simple wrap for smbus2 library.
Example:
import I2C
>>> from fusion_hat.i2c import I2C
Init I2C bus with address 0x17
>>> i2c = I2C(address=0x17)
Write a byte 0x00
>>> i2c.write_byte(0x00)
Write a byte 0x01 to register 0x01
>>> i2c.write_byte_data(0x01, 0x01)
Write a word 0x0001 to register 0x01
>>> i2c.write_word_data(0x01, 0x0001)
Write a word 0x0001 to register 0x01 in LSB first
>>> i2c.write_word_data(0x01, 0x0001, lsb=True)
Write a block of bytes to register 0x01
>>> i2c.write_block_data(0x01, [0x00, 0x01, 0x02])
Read a byte
>>> print(i2c.read_byte())
0
Read a byte from register 0x01
>>> print(i2c.read_byte_data(0x01))
Read a word from register 0x01
>>> print(i2c.read_word_data(0x01))
256
Read a word from register 0x01 in LSB first
>>> print(i2c.read_word_data(0x01, lsb=True))
Read a block of bytes from register 0x01
>>> print(i2c.read_block_data(0x01))
[0, 1, 2]
from ._utils import retry
from smbus2 import SMBus
from ._base import _Base
[Doku]
class I2C(_Base):
Args:
address (int): I2C device address
bus (int): I2C bus number
*args: Parameters to pass to :class:`fusion_hat._base._Base`.
**kwargs: Keyword arguments to pass to :class:`fusion_hat._base._Base`.
RETRY = 5
DEFAULT_BUS = 1
def __init__(self, *args, address: int = None, bus: int = DEFAULT_BUS, **kwargs) -> None:
super().__init__(*args, **kwargs)
self._bus = bus
self._smbus = SMBus(self._bus)
if isinstance(address, list):
connected_devices = self.scan()
for _addr in address:
if _addr in connected_devices:
self.address = _addr
break
self.address = address[0]
@retry(RETRY)
def write_byte(self, data: int) -> bool:
""" Write a byte to the I2C bus
Args:
data (int): byte to write
Returns:
bool: True if the byte is written successfully, False otherwise
self.log.debug(f"write_byte: 0x{data:02x}({data})")
result = self._smbus.write_byte(self.address, data)
return result
@retry(RETRY)
def write_byte_data(self, reg: int, data: int) -> bool:
Args:
reg (int): register address
Returns:
self.log.debug(f"write_byte_data: 0x{reg:02x}({reg}), 0x{data:02x}({data})")
result = self._smbus.write_byte_data(self.address, reg, data)
return result
@retry(RETRY)
def write_word_data(self, reg: int, data: int, lsb: bool = False) -> bool:
""" Write a word to the I2C bus
Args:
data (int): word to write
lsb (bool, optional): True if the word is written in little-endian, False otherwise, default is False
Returns:
bool: True if the word is written successfully, False otherwise
msg = f"write_word_data: 0x{reg:02x}({reg}), 0x{data:04x}({data})"
if lsb:
l_byte = (data >> 0) & 0xFF
h_byte = (data >> 8) & 0xFF
data = (l_byte << 8) | h_byte
msg += f", LSB={lsb} (sent: 0x{data:04x}({data}))"
self.log.debug(msg)
return self._smbus.write_word_data(self.address, reg, data)
@retry(RETRY)
def write_i2c_block_data(self, reg: int, data: list) -> bool:
""" Write a block of data to the I2C bus
Args:
data (list): block of data to write
Returns:
bool: True if the block of data is written successfully, False otherwise
self.log.debug(f"write_i2c_block_data: 0x{reg:02x}({reg}), {data}")
result = self._smbus.write_i2c_block_data(self.address, reg, data)
return result
@retry(RETRY)
def read_byte(self) -> int:
""" Read a byte from the I2C bus
Returns:
int: byte read from the I2C bus
self.log.debug(f"read_byte: 0x{self.address:02x}({self.address})")
result = self._smbus.read_byte(self.address)
return result
@retry(RETRY)
def read_byte_data(self, reg: int) -> int:
Args:
Returns:
self.log.debug(f"read_byte_data: 0x{reg:02x}({reg})")
result = self._smbus.read_byte_data(self.address, reg)
return result
@retry(RETRY)
def read_word_data(self, reg: int, lsb: bool = False) -> int:
""" Read a word from the I2C bus
Args:
lsb (bool, optional): True if the word is read in little-endian, False otherwise, default is False
Returns:
int: word read from the I2C bus
msg = f"read_word_data: 0x{reg:02x}({reg})"
result = self._smbus.read_word_data(self.address, reg)
if lsb:
l_byte = (result >> 0) & 0xFF
h_byte = (result >> 8) & 0xFF
result = (l_byte << 8) | h_byte
msg += f", LSB={lsb} (received: 0x{result:04x}({result}))"
self.log.debug(msg)
return result
@retry(RETRY)
def read_i2c_block_data(self, reg: int, num: int) -> list:
""" Read a block of data from the I2C bus
Args:
num (int): number of bytes to read
Returns:
list: block of data read from the I2C bus
msg = f"read_i2c_block_data: 0x{reg:02x}({reg}), {num} bytes"
result = self._smbus.read_i2c_block_data(self.address, reg, num)
msg += f", {result}"
self.log.debug(msg)
return result
@retry(RETRY)
def is_ready(self) -> bool:
"""Check if the I2C device is ready
Returns:
bool: True if the I2C device is ready, False otherwise
self.log.debug(f"Check if 0x{self.address:02x}({self.address}) is ready")
addresses = self.scan()
if self.address in addresses:
self.log.debug(f"0x{self.address:02x}({self.address}) is ready")
return True
self.log.debug(f"0x{self.address:02x}({self.address}) is not ready")
return False
[Doku]
@staticmethod
def scan(bus: int = 1, force: bool = False) -> list:
"""Scan the I2C bus for devices
Args:
bus (int, optional): I2C bus number, default is 1
force (bool, optional): True if force to access the I2C bus, False otherwise, default is False
Returns:
list: List of I2C addresses of devices found
devices = []
for addr in range(0x03, 0x77 + 1):
with SMBus(bus) as smbus:
# Read a byte from the address
smbus.read_byte(addr, force=force)
devices.append(addr)
except OSError as expt:
# Ignore device busy or unresponsive errors
if expt.errno == 16: # Device or resource busy
# print(f"Address 0x{addr:02X} busy")
# Other errors continue to try
continue
return devices
[Doku]
def write(self, data: int | list | bytearray) -> None:
""" Write data to the I2C device
Args:
data (int | list | bytearray): Data to write
Raises:
ValueError: if write is not an int, list or bytearray
if isinstance(data, bytearray):
data_all = list(data)
elif isinstance(data, int):
if data == 0:
data_all = [0]
data_all = []
while data > 0:
data_all.append(data & 0xFF)
data >>= 8
elif isinstance(data, list):
data_all = data
# Write data
if len(data_all) == 1:
data = data_all[0]
self.write_byte(data)
elif len(data_all) == 2:
reg = data_all[0]
data = data_all[1]
self.write_byte_data(reg, data)
elif len(data_all) == 3:
reg = data_all[0]
data = (data_all[2] << 8) + data_all[1]
print(f"I2C write_word_data 0x{reg:02X} data: 0x{data:04X}")
self.write_word_data(reg, data)
reg = data_all[0]
data = list(data_all[1:])
self.write_i2c_block_data(reg, data)
[Doku]
def read(self, length: int = 1) -> list:
""" Read data from I2C device
Args:
length (int): Number of bytes to receive
Returns:
list: Received data
result = []
for _ in range(length):
result.append(self.read_byte())
return result
[Doku]
def mem_write(self, data: int | list | bytearray, memaddr: int) -> None:
""" Write data to specific register address
Args:
data (int | list | bytearray): Data to send
memaddr (int): Register address
Raises:
ValueError: If data is not int, list, or bytearray
data_all = data
data_all = []
if data == 0:
data_all = [0]
while data > 0:
data >>= 8
self.write_i2c_block_data(memaddr, data_all)
[Doku]
def mem_read(self, length: int, memaddr: int) -> list:
""" Read data from specific register address
Args:
Returns:
list: Received bytearray data or False if error
result = self.read_i2c_block_data(memaddr, length)
return result
[Doku]
def is_avaliable(self) -> bool:
""" Check if the I2C device is avaliable
Returns:
bool: True if the I2C device is avaliable, False otherwise
return self.address in self.scan()
[Doku]
def _write_byte(self, data: int) -> None:
""" [DEPRECATED] Write a byte to I2C register
Args:
data (int): Data to write
print(f"[WARNING] _write_byte is deprecated, use write_byte instead")
[Doku]
def _write_byte_data(self, reg: int, data: int) -> None:
""" [DEPRECATED] Write a byte data to I2C register
Args:
reg (int): Register address
print(f"[WARNING] _write_byte_data is deprecated, use write_byte_data instead")
[Doku]
def _write_word_data(self, reg: int, data: int) -> None:
""" [DEPRECATED] Write word data to I2C register
Args:
print(f"[WARNING] _write_word_data is deprecated, use write_word_data instead")
[Doku]
def _write_i2c_block_data(self, reg: int, data: list) -> None:
""" [DEPRECATED] Write block data to I2C register
Args:
data (list): Data to write
print(f"[WARNING] _write_i2c_block_data is deprecated, use write_i2c_block_data instead")
[Doku]
def _read_byte(self) -> int:
""" [DEPRECATED] Read a byte from the I2C bus
Returns:
print(f"[WARNING] _read_byte is deprecated, use read_byte instead")
return self.read_byte()
[Doku]
def _read_byte_data(self, reg: int) -> int:
Args:
Returns:
print(f"[WARNING] _read_byte_data is deprecated, use read_byte_data instead")
return self.read_byte_data(reg)
[Doku]
def _read_word_data(self, reg: int) -> list:
""" [DEPRECATED] Read a word from the I2C bus
Args:
Returns:
list: word read from the I2C bus
print(f"[WARNING] _read_word_data is deprecated, use read_word_data instead")
return self.read_word_data(reg)
[Doku]
def _read_i2c_block_data(self, reg: int, length: int) -> list:
""" [DEPRECATED] Read block data from I2C register
Args:
Returns:
print(f"[WARNING] _read_i2c_block_data is deprecated, use read_i2c_block_data instead")
return self.read_i2c_block_data(reg, length)
