2.5 Doorbell
Here, we will use the button and the bell on the stage to make a doorbell.
After the green flag is clicked, you can press the button and the bell on the stage will make a sound.
../_images/7_doorbell.png
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
Button
You Will Learn
  • How the button work
  • Reading digital pin and ranges
  • Creating a conditional loop
  • Adding a backdrop
  • Playing sound
Build the Circuit
The button is a 4-pin device, since the pin 1 is connected to pin 2, and pin 3 to pin 4, when the button is pressed, the 4 pins are connected, thus closing the circuit.
../_images/5_buttonc.png
Build the circuit according to the following diagram.
  • Connect one of the pins on the left side of the button to pin14, which is connected to a pull-down resistor and a 0.1uF (104) capacitor (to eliminate jitter and output a stable level when the button is working).
  • Connect the other end of the resistor and capacitor to GND, and one of the pins on the right side of the button to 5V.
../_images/6_doorbel_bb.png
Programming
1. Add a Backdrop
Click the Choose a Backdrop button in the lower right corner.
../_images/7_backdrop.png
Choose Bedroom 1.
../_images/7_bedroom2.png
2. Select the sprite
Delete the default sprite, click the Choose a Sprite button in the lower right corner of the sprite area, enter bell in the search box, and then click to add it.
../_images/7_sprite.png
Then select the bell sprite on the stage and move it to the right position.
3. Press the button and the bell makes a sound
Use [if then] to make a conditional statement that when the value of the pin14 read is equal to 1 (the key is pressed), the sound xylo1 will be played.
  • [read status of digital pin]: This block is from the ESP32 palette and used to read the value of a digital pin, the result is 0 or 1.
  • [if then]: This block is a control block and from Control palette. If its boolean condition is true, the blocks held inside it will run, and then the script involved will continue. If the condition is false, the scripts inside the block will be ignored. The condition is only checked once; if the condition turns to false while the script inside the block is running, it will keep running until it has finished.
  • [play sound until done]: This block is from the Sound palette, used to play specific sounds.
../_images/7_bell.png
