2.10 Light Sensitive Ball
In this project, we use Photoresistor to make the ball on the stage fly upwards. Place your hand on top of the photoresistor to control the light intensity it receives. The closer your hand is to the photoresistor, the smaller its value and the higher the ball flies on the stage, otherwise it will fall. When the ball touches the string, it makes a nice sound as well as a twinkling starlight.
../_images/18_ball.png
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
Photoresistor
You Will Learn
  • Fill the sprite with colors
  • Touch between the sprites
Build the Circuit
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity.
Build the circuit according to the following diagram.
Connect one end of the photoresistor to 5V, the other end to pin35, and connect a 10K resistor in series with GND at this end.
So when the light intensity increases, the resistance of a photoresistor decreases, the voltage division of the 10K resistor increases, and the value obtained by pin35 becomes larger.
../_images/8_light_alarm_bb.png
Programming
The effect we want to get is that the closer your hand is to the photoresistor, the ball sprite on the stage keeps going up, otherwise it will fall on the bowl sprite. If it touches the Line sprite while walking up or falling down, it will make a musical sound and emit star sprites in all directions.
1. Select sprite and backdrop
Delete the default sprite, select the Ball, Bowl and Star sprite.
../_images/18_ball1.png
Move the Bowl sprite to the bottom center of the stage and enlarge its size.
../_images/18_ball3.png
Because we need to move it upwards, so set direction of Ball sprite to 0.
../_images/18_ball4.png
Set the size and direction of the Star sprite to 180 because we need it to fall down, or you can change it to another angle.
../_images/18_ball12.png
Now add the Stars backdrop.
../_images/18_ball2.png
2. Draw a Line sprite
Add a Line sprite.
../_images/18_ball7.png
Go to the Costumes page of the Line sprite, reduce the width of the red line on the canvas slightly, then copy it 5 times and align the lines.
../_images/18_ball8.png
Now fill the lines with different colors. First choose a color you like, then click on the Fill tool and move the mouse over the line to fill it with color.
../_images/18_ball9.png
Follow the same method to change the color of the other lines.
../_images/18_ball10.png
3. Scripting the Ball sprite
Set the initial position of the Ball sprite, then when the light value is less than 1500 (it can be any other value, depending on your current environment.), let the Ball move up.
You can make the variable light_value show up on the stage to observe the change of light intensity at any time.
../_images/18_ball5.png
Otherwise, the Ball sprite will fall and limit its Y coordinate to a minimum of -100. This can be modified to make it look like it is falling on the Bowl sprite.
../_images/18_ball6.png
When the Line sprite is hit, the current Y coordinate is saved to the variable ball_coor and a Bling message is broadcast.
../_images/18_ball11.png
4. Scripting the Star sprite
When the script starts, first hide the Star sprite. When the Bling message is received, clone the Star sprite.
../_images/18_ball13.png
When the Star sprite appears as a clone, play the sound effect and set its coordinates to be in sync with the Ball sprite.
../_images/18_ball14.png
Create the effect of the Star sprite appearing, and adjust it as needed.
../_images/18_ball15.png
