Creating a Virtual Environment¶
When using Raspberry Pi or similar devices, it is recommended to install packages with pip
in a virtual environment. It offers dependency isolation, increases system security, maintains system cleanliness, and facilitates project migration and sharing, simplifying dependency management. These benefits make virtual environments an extremely important and useful tool in Python development.
Below are the steps to create a virtual environment:
1. Create a virtual environment
Firstly, you need to ensure that your system has Python installed. Python version 3.3 and later come with the venv
module to create virtual environments, eliminating the need for separate installation. If you are using Python 2 or a version before Python 3.3, you will need to install virtualenv
For Python 3:
Python 3.3 and later versions can directly use the venv
module:
python3 -m venv myenv
This will create a virtual environment named myenv
in the current directory.
For Python 2:
If you are still using Python 2, you first need to install virtualenv
pip install virtualenv
Then, create a virtual environment:
virtualenv myenv
This also creates a virtual environment named myenv
2. Activating the Virtual Environment
After creating the virtual environment, you need to activate it for use.
Each time you restart the Raspberry Pi, or open a new terminal, you will need to run the following command again to activate the virtual environment.
source myenv/bin/activate
Once the virtual environment is activated, you will see the environment name before the command line prompt, indicating you are working within the virtual environment.
3. Installing Dependencies
With the virtual environment activated, you can use pip to install the required dependencies. For example:
pip install requests
This will install the requests library into the current virtual environment, rather than the global environment. This step only needs to be done once.
4. Exiting the Virtual Environment
When you have completed your work and wish to exit the virtual environment, simply run:
deactivate
This will return you to the system’s global Python environment.
5. Deleting the Virtual Environment
If you no longer need a particular virtual environment, you can simply delete the directory containing the virtual environment:
rm -rf myenv
