1.3 Turn the Wheel¶
A motor is a typical digital output device, and it is used in the same way as an LED. However, the motor needs to be driven with a large current, and the large current may damage the main control board such as R4 board. Therefore, an motor driver module is used in this occasion, which is a good helper for the R4 board to control the motor safely.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
L9110S |
R4 Board |
Motor |
VCC |
5V |
GND |
GND |
B-1B(B-2A) |
9 |
B-1A |
10 |
OA |
one wire of the motor |
OB |
You can open the file
1.3.turn_the_wheel.inounder the path of3in1-kit\learning_project\1.3.turn_the_wheel.Or copy this code into Arduino IDE.
