1.1 Hello, LED!¶
Just as printing “Hello, world!” is the first step in learning to program, using a program to drive an LED is the traditional introduction to learning physical programming.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
The principle of this circuit is simple and the current direction is shown in the figure. When pin 9 outputs high level(5V), the LED will light up after the 1kohm current limiting resistor. When pin 9 outputs low level (0v), the LED will turn off.
You can open the file
1.1.hello_led.inounder the path of3in1-kit\learning_project\1.1.hello_led.Or copy this code into Arduino IDE.
After the code is uploaded successfully, you will see the LED blinking.
How it works?
Here, we connect the LED to the digital pin 9, so we need to declare an int variable called ledpin at the beginning of the program and assign a value of 9.
const int ledPin = 9;
Now, initialize the pin in the setup() function, where you need to initialize the pin to OUTPUT mode.
pinMode(ledPin, OUTPUT);
In loop(), digitalWrite() is used to provide 5V high level signal for ledpin, which will cause voltage difference between LED pins and light LED up.
digitalWrite(ledPin, HIGH);
If the level signal is changed to LOW, the ledPin’s signal will be returned to 0 V to turn LED off.
digitalWrite(ledPin, LOW);
An interval between on and off is required to allow people to see the change,
so we use a delay(1000) code to let the controller do nothing for 1000 ms.
delay(1000);
