DIY Monitor Device¶
Description¶
You can turn this screen into a game screen playing with your friends, a smart alarm showing the weather and time, a display monitoring your robot’s action and many other things.
This article will show you how to DIY a Monitor Device. Let’s take a look!
Required Components¶
A Screen
8G+ SD Card
Scratch 3 (either online or offline)
Micro SD Card Reader
40P Ribbon Cable
T-Type GPIO Extension Board
PIR Module
Camera Module
FFC Cable
Jump Wire F/M
You Will Learn¶
Use Raspberry Pi extensions on Scratch.
Use audio functions on Scratch.
Use PIR module.
Lesson Guide¶
Build the Circuit¶
First connect the GPIO Extension Board, please read GPIO Extension Board for specific steps.
Plug the T-type GPIO extension board into the breadboard and build the circuit.
For the camera installation tutorial, please refer to Assemble the Camera Module.
Programming with Scratch 3¶
In this step you will learn how to upload the prepared music to the Scratch. Tap the “Sounds”option on the left upper corner,then tap the “speaker” icon and choose “Upload Sound” icon to upload the prepared music file - hello, finally tap“Open” to confirm.
Tap Add icon at lower left corner and choose“Video Sensing”and“Raspberry Pi GPIO”to add two functions.
Back to the main page, drag a“when gpio 0 is high”from Raspberry Pi GPIO function and a “play sound (hello) until done”to the coding area.
Stick the pir module and camera to the wall outside the door, and stick the screen to the wall inside the door or anywhere. When the door is opened, you will hear music and then see who is there.
