HARDWARE DESCRIPTION
Below is the dimension diagram for the TS-10 touchscreen.
_images/ts10_size.png
Specifications
  • Screen Size: 10.1 inches
  • Display Type: IPS HD
  • Resolution: 1280 x 800 pixels
  • Touch Technology: 10-point capacitive touch
  • Viewing Angle: 178° wide view
  • Audio: Dual audio output
  • Dimensions: 255.4 x 167.4 x 39.4mm (L x W x H)
  • Power Supply:
    • Input: DC 12V / 5A
    • USB Output: Built-In 5.1V / 5A Type-C for Raspberry Pi 5
  • Connectivity:
    • Video Input: Mini HDMI to HDMI cable included
    • Power Cables: Type-C power cable and DC adapter included
  • Compatibility:
    • Raspberry Pi Models: Pi 5, Pi 4, Pi 3B+, Pi 3B, Pi Zero 2W, Pi 400
    • Other SBCs: Banana Pi, Libre Computer Board, Orange Pi
  • Operating Systems Supported:
    • Raspberry Pi OS
    • Windows
    • Ubuntu
    • Chrome OS
    • Android
    • macOS
    • Twister OS
Hardware Overview
_images/hardware_back.png
  • Main Board: It is mounted on top to control the display.
  • Control Board: It is a cross slot structure with one side movable, so you can mount different size of control board.
  • Touch Module: This is the module used to let the display get the touch function, you need to connect it to the USB port of the control board through the USB cable provided by us.
Touch Module
_images/hardware_touch_module.png
There are two types of 4pin connector on the touch module, with the pin serial number shown on the figure.
Here are the definitions of the pins:
  • Pin 1: VDD(5V)
  • Pin 2: D-
  • Pin 3: D+
  • Pin 4: GND
LED Indicators
_images/hardware_leds.png
There are 2 LED indicators on the main board of the screen to show different signals:
  • Power on the screen, after the Signal LED flashes one time, it lights on continuously; and the Power LED lights on immediately.
  • If there’s no HDMI signal, only the Power LED will turn on.
  • If there’s an HDMI signal, these two LEDs will turn on.
  • If you press the power button, the Signal LED will turn off and the Power LED will keep turning on.
  • If you remove the power adapter, both of the two LEDs will turn off.
Buttons
Buttons on the main board and their functions:
_images/hardware_buttons.png _images/hardware_buttons_func.png
Interfaces
On one side of the Driver Board there are ports of HDMI input, 12V power input, and 5V/5A USB power output and Speaker Port.
_images/hardware_interfaces.png
