Security System¶
In this project, we’ve created a simple security system. The PIR sensor detects if someone passes by, and then the camera activates. If a face is detected, it takes a picture and simultaneously delivers a warning message.
Steps
Install the
vilib
library for face detection.cd ~/ git clone -b picamera2 https://github.com/sunfounder/vilib.git cd vilib sudo python3 install.py
Save the following code to your Raspberry Pi and give it a name, for example,
security.ty
.import os from time import sleep, time, strftime, localtime from vilib import Vilib from robot_hat import Pin, TTS # Initialize the TTS class tts = TTS(lang='en-US') # Display all supported languages print(tts.supported_lang()) # Initialize the PIR sensor pir = Pin('D0') def camera_start(): Vilib.camera_start() Vilib.display() Vilib.face_detect_switch(True) def take_photo(): _time = strftime('%Y-%m-%d-%H-%M-%S', localtime(time())) name = f'photo_{_time}' username = os.getlogin() path = f"/home/{username}/Pictures/" Vilib.take_photo(name, path) print(f'Photo saved as {path}{name}.jpg') def main(): motion_detected = False while True: # Check for motion if pir.value() == 1: if not motion_detected: print("Motion detected! Initializing camera...") camera_start() motion_detected = True sleep(2) # Stabilization delay to confirm motion # Check for human face and take a photo if Vilib.detect_obj_parameter['human_n'] != 0: take_photo() # Read the text tts.say("Security alert: Unrecognized Individual detected. Please verify identity") sleep(2) # Delay after taking a photo # If no motion is detected, turn off the camera elif motion_detected: print("No motion detected. Finalizing camera...") Vilib.camera_close() motion_detected = False sleep(2) # Delay before re-enabling motion detection sleep(0.1) # Short delay to prevent CPU overuse def destroy(): Vilib.camera_close() print("Camera and face detection stopped.") if __name__ == '__main__': try: main() except KeyboardInterrupt: destroy()
- Use the command
sudo python3 security.py
to run this code.
- Use the command
Open a web browser and enter
http://rpi_ip:9000/mjpg
to view the captured footage. Additionally, you can find the captured face images in/home/{username}/Pictures/
