2.2.2 Thermistor(MCP3008)
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
../_images/list2_2.2.2_thermistor1.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Thermistor
MCP3008
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
../_images/schematic_2.2.2_thermistor_mcp30081.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_2.2.2_thermistor_mcp30081.png
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python-pi5
Step 4: Run the executable file
sudo python3 2.2.2-2_Thermistor_zero.py
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
# -*- coding: utf-8 -*-
import spidev
import math
# Initialize SPI for MCP3008 (Bus 0, CE0)
spi = spidev.SpiDev()
spi.open(0, 0)  # Bus 0, Device 0 (CE0)
def read_adc(channel):
    Read analog value from MCP3008 channel (0–7)
        return -1
    # MCP3008 communication format
    return value
        # Read analog value from CH0 of MCP3008
        analogVal = read_adc(0)
        # Convert to voltage (3.3V reference)
        Vr = 3.3 * analogVal / 1023.0
        # Calculate thermistor resistance
        Rt = 10000.0 * Vr / (3.3 - Vr)
        # Calculate temperature in Kelvin using the Steinhart–Hart approximation
        tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0)))
        # Convert to Celsius and Fahrenheit
        Cel = tempK - 273.15
        Fah = Cel * 1.8 + 32
        # Print the temperature
        print('Celsius: %.2f °C  Fahrenheit: %.2f °F' % (Cel, Fah))
        # Wait before next reading
        time.sleep(0.2)
    spi.close()
Code Explanation
  1. This section imports the spidev module for communicating with the MCP3008 ADC via SPI, the time module for delays, and the math module for logarithmic calculations needed in temperature conversion.
    import spidev
    import math
  2. Initializes the SPI interface for MCP3008 on bus 0 and device 0 (CE0), setting the maximum SPI clock speed to 1 MHz.
  3. Defines a function to read analog values from a specified MCP3008 channel (0–7). The SPI protocol is used to communicate with the MCP3008, and a 10-bit integer (0–1023) is returned.
            return -1
        return value
  4. Implements a loop to continuously read analog values from a thermistor connected to CH0 of MCP3008. It converts the raw reading into a voltage (based on 3.3V reference), then into resistance, and finally into temperature using the Steinhart–Hart equation. Temperature is output in both Celsius and Fahrenheit. A short delay is inserted between readings.
            time.sleep(0.2)
  5. Captures a KeyboardInterrupt (Ctrl+C) for graceful program termination. It closes the SPI interface to release the resource.
        spi.close()
