2.1.9 Joystick(MCP3008)ο
Introductionο
In this project, Weβre going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use MCP3008 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
T-Board Name |
physical |
WiringPi |
BCM |
SPICE0 |
pin24 |
10 |
8 |
SPIMOSI |
pin19 |
12 |
10 |
SPIMISO |
pin21 |
13 |
9 |
SPISCLK |
pin23 |
14 |
11 |
GPIO22 |
pin15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python-pi5
Step 4: Run.
sudo python3 2.1.9-2_Joystick_zero.py
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnβt work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import Button
import spidev
# Initialize the button connected to GPIO pin 22 (joystick SW pin)
BtnPin = Button(22)
# Initialize SPI communication with MCP3008
spi = spidev.SpiDev()
spi.open(0, 0) # Open SPI bus 0, device CE0
spi.max_speed_hz = 1000000 # Set SPI speed to 1 MHz
def read_adc(channel):
Reads analog value from the specified MCP3008 channel (0β7)
:param channel: ADC channel number (0β7)
:return: 10-bit integer value (0β1023)
return -1
return value
# Main loop to read and print joystick values and button state
# Read X and Y values from MCP3008 channels 0 and 1
x_val = read_adc(0) # Joystick VRX connected to CH0
y_val = read_adc(1) # Joystick VRY connected to CH1
# Read the state of the joystick button (SW)
Btn_val = BtnPin.value # 0 = pressed, 1 = released
# Print the read values
print('X: %d Y: %d Btn: %d' % (x_val, y_val, Btn_val))
# Wait 0.2 seconds before the next reading
time.sleep(0.2)
# Gracefully handle Ctrl+C interruption
spi.close()
Code Explanation
This section imports the required libraries:
gpiozero.Buttonis used to read the digital state of the joystick button (SW pin).spidevis used for SPI communication with the MCP3008 ADC chip.timeis used for timing delays between readings.
#!/usr/bin/env python3 from gpiozero import Button import spidev import time
Initializes the button connected to GPIO22 (joystick SW pin), and sets up the SPI interface on bus 0, chip select 0 (CE0). The SPI speed is configured to 1 MHz.
# Initialize the button connected to GPIO pin 22 (joystick SW pin) BtnPin = Button(22) # Initialize SPI communication with MCP3008 spi = spidev.SpiDev() spi.open(0, 0) # Open SPI bus 0, device CE0 spi.max_speed_hz = 1000000 # Set SPI speed to 1 MHz
Defines a function
read_adc(channel)to read the analog value from a specific MCP3008 channel (0β7). It sends three bytes using SPI protocol and returns a 10-bit value (0β1023).def read_adc(channel): """ Reads analog value from the specified MCP3008 channel (0β7) :param channel: ADC channel number (0β7) :return: 10-bit integer value (0β1023) """ if channel < 0 or channel > 7: return -1 adc = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((adc[1] & 0x03) << 8) | adc[2] return value
In the main loop, it reads the analog values from VRX (connected to CH0) and VRY (connected to CH1), as well as the joystick button state. The values are printed to the console every 0.2 seconds. When Ctrl+C is pressed, the SPI interface is cleanly closed.
try: # Main loop to read and print joystick values and button state while True: # Read X and Y values from MCP3008 channels 0 and 1 x_val = read_adc(0) # Joystick VRX connected to CH0 y_val = read_adc(1) # Joystick VRY connected to CH1 # Read the state of the joystick button (SW) Btn_val = BtnPin.value # 0 = pressed, 1 = released # Print the read values print('X: %d Y: %d Btn: %d' % (x_val, y_val, Btn_val)) # Wait 0.2 seconds before the next reading time.sleep(0.2) # Gracefully handle Ctrl+C interruption except KeyboardInterrupt: spi.close()
