πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.7 Potentiometer
Introduction
The ADC function can be used to convert analog signals to digital signals, and in this experiment, ADC0834 is used to get the function involving ADC. Here, we implement this process by using potentiometer. Potentiometer changes the physical quantity – voltage, which is converted by the ADC function.
Required Components
../_images/list_2.1.4_potentiometer.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
Potentiometer
ADC0834
Schematic Diagram
../_images/image311.png ../_images/image312.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image180.png
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Open the code file
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 2.1.7_Potentiometer.py
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import ADC0834
LedPin = 22
def setup():
    global led_val
    GPIO.setmode(GPIO.BCM)
    # Set all LedPin's mode to output and initial level to High(3.3v)
    ADC0834.setup()
    # Set led as pwm channel and frequece to 2KHz
    # Set all begin with value 0
    led_val.start(0)
# Define a MAP function for mapping values.  Like from 0~255 to 0~100
def destroy():
    # Stop all pwm channel
    led_val.stop()
    # Release resource
    GPIO.cleanup()
def loop():
        res = ADC0834.getResult()
        print ('res = %d' % res)
        R_val = MAP(res, 0, 255, 0, 100)
        led_val.ChangeDutyCycle(R_val)
        time.sleep(0.2)
if __name__ == '__main__':
    setup()
        loop()
        destroy()
Code Explanation
import ADC0834
import ADC0834 library. You can check the content of the library by calling the command nano ADC0834.py.
def setup():
    global led_val
    ADC0834.setup()
    led_val.start(0)
In setup(), define the naming method as BCM, set LedPin as PWM channel and render it a frequency of 2Khz.
ADC0834.setup(): Initialize ADC0834, and connect the defined CS, CLK, DIO of ADC0834 to GPIO17, GPIO18 and GPIO27 respectively.
def loop():
        time.sleep(0.2)
The function getResult() is used to read the analog values of the four channels of ADC0834. By default, the function reads the value of CH0, and if you want to read other channels, please input the channel number in ( ), ex. getResult(1).
The function loop() first reads the value of CH0, then assign the value to the variable res. After that, call the function MAP to map the read value of potentiometer to 0~100. This step is used to control the duty cycle of LedPin. Now, you may see that the brightness of LED is changing with the value of potentiometer.
Phenomenon Picture
../_images/image181.jpeg
