š Ready to explore and create with us? Click [here] and join today!
1.1.5 4-Digit 7-Segment Displayļ
Introductionļ
Next, follow me to try to control the 4-digit 7-segment display.
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramļ
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
SPIMOSI |
Pin 19 |
12 |
10 |
GPIO18 |
Pin 12 |
18 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
Experimental Proceduresļ
Step 1: Build the circuit.
cd ~/raphael-kit/python/
Step 3: Run the executable file.
sudo python3 1.1.5_4-Digit.py
After the code runs, the program takes a count, increasing by 1 per second, and the 4 digit display displays the count.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import threading
SDI = 24
RCLK = 23
SRCLK = 18
placePin = (10, 22, 27, 17)
counter = 0
timer1 = 0
def clearDisplay():
for i in range(8):
GPIO.output(SDI, 1)
GPIO.output(SRCLK, GPIO.HIGH)
GPIO.output(SRCLK, GPIO.LOW)
GPIO.output(RCLK, GPIO.HIGH)
GPIO.output(RCLK, GPIO.LOW)
def hc595_shift(data):
for i in range(8):
GPIO.output(SDI, 0x80 & (data << i))
def pickDigit(digit):
for i in placePin:
GPIO.output(i,GPIO.LOW)
GPIO.output(placePin[digit], GPIO.HIGH)
def timer():
global counter
global timer1
timer1 = threading.Timer(1.0, timer)
timer1.start()
counter += 1
print("%d" % counter)
def loop():
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
hc595_shift(number[counter % 100//10])
clearDisplay()
pickDigit(2)
hc595_shift(number[counter % 1000//100])
clearDisplay()
pickDigit(3)
hc595_shift(number[counter % 10000//1000])
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(SDI, GPIO.OUT)
GPIO.setup(RCLK, GPIO.OUT)
GPIO.setup(SRCLK, GPIO.OUT)
for i in placePin:
GPIO.setup(i, GPIO.OUT)
global timer1
timer1.start()
def destroy(): # When "Ctrl+C" is pressed, the function is executed.
global timer1
GPIO.cleanup()
timer1.cancel() # cancel the timer
if __name__ == '__main__':
setup()
loop()
destroy()
Code Explanation
These four pins control the common anode pins of the four-digit 7-segment displays.
A segment code array from 0 to 9 in hexadecimal (common anode).
def clearDisplay():
for i in range(8):
GPIO.output(SDI, 1)
Write ā1ā for eight times in SDI., so that the eight LEDs on the 7-segment Dispaly will turn off so as to clear the displayed content.
for i in placePin:
Select the place of the value. there is only one place that should be enable each time. The enabled place will be written high.
def loop():
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
clearDisplay()
pickDigit(2)
clearDisplay()
pickDigit(3)
The function is used to set the number displayed on the 4-digit 7-segment Dispaly.
First, start the fourth segment display,Ā write the single-digitĀ number. Then start the third segment display, and type inĀ the tensĀ digit;Ā after that,Ā start the second and the first segment display respectively,Ā and write the hundredsĀ and thousands digits respectively.Ā Because the refreshingĀ speedĀ is veryĀ fast, we see aĀ completeĀ four-digit display.
timer1.start()
The module, threading is the common threading module in Pythonļ¼and Timer is the subclass of it. The prototype of code is:
class threading.Timer(interval, function, args=[], kwargs={})
After the interval, the function will be run. Here, the interval is 1.0ļ¼and the function is timer(). start () means the Timer will start at this point.
def timer():
global counter
global timer1
timer1.start()
counter += 1
After Timer reaches 1.0s, the Timer function is called; add 1 to counter, and the Timer is used again to execute itself repeatedly every second.
Phenomenon Pictureļ
