.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.1.9_c_pi5_mcp3008:
2.1.9 Joystick(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, We're going to learn how joystick works. We manipulate
the Joystick and display the results on the screen.
.. image:: ../img/image317-copy.png
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - Raphael Kit
- 337
- |link_Raphael_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_gpio_board`
- |link_gpio_board_buy|
* - :ref:`cpn_breadboard`
- |link_breadboard_buy|
* - :ref:`cpn_wires`
- |link_wires_buy|
* - :ref:`cpn_resistor`
- |link_resistor_buy|
* - :ref:`cpn_joystick`
* - :ref:`cpn_mcp3008`
Schematic Diagram
When the data of joystick is read, there are some differents between
axis: data of X and Y axis is analog, which need to use MCP3008 to
convert the analog value to digital value. Data of Z axis is digital, so
you can directly use the GPIO to read, or you can also use ADC to read.
.. .. image:: ../img/image319.png
* - T-Board Name
- physical
- WiringPi
- BCM
* - SPICE0
- pin24
- 10
- 8
* - SPIMOSI
- pin19
- 12
- 10
* - SPIMISO
- pin21
- 13
- 9
* - SPISCLK
- pin23
- 14
- 11
* - GPIO22
- pin15
- 3
- 22
.. image:: ../img/schematic_2.1.9_joystick_mcp3008.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/july24_2.1.9_joystick_mcp3008.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/raphael-kit/c/2.1.9-2/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.1.9_Joystick.c -o joystick -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
./joystick
After the code runs, turn the Joystick, then the corresponding values of
x, y, Btn are displayed on screen.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000 // 1 MHz
#define BtnPin 3 // WiringPi 3 = BCM GPIO22
// Read from MCP3008 channel (0–7)
int read_ADC(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Channel config
buffer[2] = 0;
int result = ((buffer[1] & 0x03) << 8) | buffer[2];
return result;
int main(void) {
if (wiringPiSetup() == -1) {
printf("WiringPi setup failed!\n");
printf("SPI setup failed!\n");
pinMode(BtnPin, INPUT);
pullUpDnControl(BtnPin, PUD_UP);
while (1) {
int x_val = read_ADC(0); // VRX on CH0
int y_val = read_ADC(1); // VRY on CH1
int btn_val = digitalRead(BtnPin); // SW button
printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
delay(100);
**Code Explanation**
#. This section initializes the libraries needed for GPIO and SPI communication.
.. code-block:: c
#include
#include
#include
#. Defines a function ``read_ADC()`` to read analog data from MCP3008. It communicates over SPI to request data from a given channel (0–7), then parses the response to get a 10-bit ADC result.
.. code-block:: c
buffer[0] = 1;
buffer[2] = 0;
return result;
#. The main function initializes the WiringPi and SPI interfaces, configures the joystick's button pin, and continuously reads joystick values and prints them to the console.
.. code-block:: c
int main(void) {
while (1) {
int x_val = read_ADC(0); // VRX to CH0
int y_val = read_ADC(1); // VRY to CH1
int btn_val = digitalRead(BtnPin); // SW to GPIO22
delay(100);
#. In this program:
- The joystick's VRX is connected to CH0 of MCP3008.
- The VRY is connected to CH1.
- The button (SW) is connected to GPIO22 (WiringPi pin 3).
- The ``read_ADC()`` function is used to read analog values from VRX and VRY.
- The digital value of the joystick button is read using ``digitalRead()``.
- All values are printed continuously every 100 milliseconds.
.. Phenomenon Picture
.. .. image:: ../img/image194.jpeg
