2.1.5 Tilt Switch
This is a ball tilt-switch with a metal ball inside. It is used to detect inclinations of a small angle.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/c/2.1.5/
Step 3: Compile.
gcc 2.1.5_Tilt.c -lwiringPi
Step 4: Run.
Place the tilt vertically, and the green LED will turns on. If you tilt it, “Tilt!” will be printed on the screen and the red LED will lights on. Place it vertically again, and the green LED will turns on again.
#include <wiringPi.h>
#include <stdio.h>
#define TiltPin 0
#define Gpin 2
#define Rpin 3
void LED(char* color)
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if (color == "RED")
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
else if (color == "GREEN")
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
else
printf("LED Error");
int main(void)
pinMode(TiltPin, INPUT);
LED("GREEN");
if(0 == digitalRead(TiltPin)){
delay(10);
LED("RED");
printf("Tilt!\n");
else if(1 == digitalRead(TiltPin)){
delay(10);
LED("GREEN");
Code Explanation
if (color == "RED")
else
Define a function LED() to turn the two LEDs on or off. If the parameter
color is RED, the red LED lights up; similarly, if the parameter color
is GREEN, the green LED will turns on.
delay(10);
LED("RED");
printf("Tilt!\n");
delay(10);
LED("GREEN");
If the read value of tilt switch is 0, it means that the tilt switch is tilted then you write the parameter ”RED” into function LED to get the red LED lighten up; otherwise, the green LED will lit.
Phenomenon Picture
