👉 Join us here: [here]
6. Local Voice Chatbot
In this lesson, you will combine everything you’ve learned — speech recognition (STT), text-to-speech (TTS), and a local LLM (Ollama) — to build a fully offline voice chatbot that runs on your Pironman 5 Pro MAX.
The workflow is simple:
  1. Listen — The microphone captures your speech and transcribes it with Vosk.
  2. Think — The text is sent to a local LLM running on Ollama (e.g., llama3.2:3b).
  3. Speak — The chatbot answers aloud using Piper TTS.
This creates a hands-free conversational robot that can understand and respond in real time.
Before You Start
Make sure you have prepared the following:
  • Tested Piper TTS (1. Testing Piper) and chosen a working voice model.
  • Tested Vosk STT (Test Vosk) and chosen the right language pack (e.g., en-us).
  • Installed Ollama (1. Install Ollama (LLM) and Download Model) on your Pi or another computer, and downloaded a model such as llama3.2:3b (or a smaller one like moondream:1.8b if memory is limited).
Run the Code
  1. Open the example script:
    cd ~/sunfounder-voice-assistant/examples/
    sudo nano local_voice_chatbot.py
  2. Update the parameters as needed:
    • stt = Vosk(language="en-us"): Change this to match your accent/language package (e.g., en-us, zh-cn, es).
    • tts.set_model("en_US-amy-low"): Replace with the Piper voice model you verified in 1. Testing Piper.
    • llm = Ollama(ip="localhost", model="llama3.2:3b"): Update both ip and model to your own setup.
      • ip: If Ollama runs on the same Pi, use localhost. If Ollama runs on another computer in your LAN, enable Expose to network in Ollama and set ip to that computer’s LAN IP.
      • model: Must exactly match the model name you downloaded/activated in Ollama.
  3. Run the script:
    sudo python3 local_voice_chatbot.py
  4. After running, you should see:
    • The bot greets you with a spoken welcome message.
    • It waits for speech input.
    • Vosk transcribes your speech into text.
    • The text is sent to Ollama, which streams back a reply.
    • The reply is cleaned (removing hidden reasoning) and spoken aloud by Piper.
    • Stop the program anytime with Ctrl+C.
import re
from sunfounder_voice_assistant.llm import Ollama
from sunfounder_voice_assistant.stt import Vosk
from sunfounder_voice_assistant.tts import Piper
# Initialize speech recognition
# Initialize TTS
tts = Piper()
# Instructions for the LLM
INSTRUCTIONS = (
    "You are a helpful assistant. Answer directly in plain English. "
    "Do NOT include any hidden thinking, analysis, or tags like <think>."
WELCOME = "Hello! I'm your voice chatbot. Speak when you're ready."
# Initialize Ollama connection
llm.set_max_messages(20)
llm.set_instructions(INSTRUCTIONS)
# Utility: clean hidden reasoning
def strip_thinking(text: str) -> str:
    if not text:
        return ""
    text = re.sub(r"<\s*think[^>]*>.*?<\s*/\s*think\s*>", "", text, flags=re.DOTALL|re.IGNORECASE)
    text = re.sub(r"<\s*thinking[^>]*>.*?<\s*/\s*thinking\s*>", "", text, flags=re.DOTALL|re.IGNORECASE)
    text = re.sub(r"```(?:\s*thinking)?\s*.*?```", "", text, flags=re.DOTALL|re.IGNORECASE)
    text = re.sub(r"\[/?thinking\]", "", text, flags=re.IGNORECASE)
    return re.sub(r"\s+\n", "\n", text).strip()
def main():
    print(WELCOME)
    tts.say(WELCOME)
            print("\n🎤 Listening... (Press Ctrl+C to stop)")
            # Collect final transcript from Vosk
            text = ""
            for result in stt.listen(stream=True):
                if result["done"]:
                    text = result["final"].strip()
                    print(f"[YOU] {text}")
                    print(f"[YOU] {result['partial']}", end="\r", flush=True)
            if not text:
                print("[INFO] Nothing recognized. Try again.")
                time.sleep(0.1)
                continue
            # Query Ollama with streaming
            reply_accum = ""
            response = llm.prompt(text, stream=True)
            for next_word in response:
                if next_word:
                    print(next_word, end="", flush=True)
                    reply_accum += next_word
            print("")
            # Clean and speak
            clean = strip_thinking(reply_accum)
            if clean:
                tts.say(clean)
                tts.say("Sorry, I didn't catch that.")
            time.sleep(0.05)
        print("\n[INFO] Stopping...")
    finally:
        tts.say("Goodbye!")
        print("Bye.")
if __name__ == "__main__":
    main()
Code Analysis
Imports and global setup
import re
Brings in the three subsystems you built earlier: Vosk for speech-to-text (STT), Ollama for the LLM, and Piper for text-to-speech (TTS).
Initialize STT (Vosk)
Loads the Vosk model for US English. Change the language code (e.g., zh-cn, es) to match your voice pack for better accuracy.
Initialize TTS (Piper)
tts = Piper()
Creates a Piper engine and selects a specific voice. Pick a model you’ve tested in 1. Testing Piper. Lower-quality voices are faster and use less CPU.
LLM instructions and welcome line
INSTRUCTIONS = (
Two key UX choices:
  • Keep answers short and direct (helps with TTS clarity).
  • Explicitly forbid hidden “chain-of-thought” tags to reduce noisy outputs.
Connect to Ollama and set conversation scope
  • ip="localhost" assumes the Ollama server runs on the same Pi. If it runs on another LAN machine, put that computer’s LAN IP and enable Expose to network in Ollama.
  • set_max_messages(20) keeps a short conversational history. Lower this if memory/latency is tight.
Strip hidden reasoning / tags before speaking
    if not text:
        return ""
Some models may emit internal-style tags (e.g., <think>…). This function removes those so your TTS only speaks the final answer.
Tip: If you see other artifacts on screen (because you stream raw tokens), this function already ensures spoken output stays clean.
Main loop: greet once, then listen → think → speak
print(WELCOME)
tts.say(WELCOME)
Greets the user via terminal and speaker. Happens once at startup.
Listen (streaming STT with live partials)
text = ""
    if result["done"]:
  • stream=True yields partial transcripts for immediate feedback and a final transcript when the utterance ends.
  • The final recognized text is stored in text and printed once.
Guard: If nothing was recognized, you skip the LLM call:
if not text:
    time.sleep(0.1)
    continue
This avoids sending empty prompts to the model (saves time and tokens).
Think (LLM) with streamed printing
reply_accum = ""
    if next_word:
print("")
  • Sends the final transcript to the local LLM and prints tokens as they arrive for low latency.
  • Meanwhile, you accumulate the full reply in reply_accum for post-processing.
Note: If you’d rather not show raw tokens, set stream=False and just print the final string.
Speak (clean first, then TTS once)
if clean:
    tts.say(clean)
  • Cleans the final text to remove hidden tags, then speaks exactly once.
  • Keeping TTS to a single pass avoids repeated prompts like “[LLM] / [SAY]”.
Exit and teardown
finally:
    tts.say("Goodbye!")
    print("Bye.")
Use Ctrl+C to stop. The bot says a short goodbye to signal a clean exit.
Troubleshooting & FAQ
  • Model is too large (memory error)
    Use a smaller model like moondream:1.8b or run Ollama on a more powerful computer.
  • No response from Ollama
    Make sure Ollama is running (ollama serve or desktop app open). If remote, enable Expose to network and check IP address.
  • Vosk not recognizing speech
    Verify your microphone works. Try another language pack (zh-cn, es etc.) if needed.
  • Piper silent or errors
    Confirm the chosen voice model is downloaded and tested in 1. Testing Piper.
  • Answers too long or off-topic
    Edit INSTRUCTIONS to add: “Keep answers short and to the point.”
