👉 Join us here: [here]
Pironman 5 Mini HAT
../../_images/pironman5mini_hat.png
RGB LEDs
../../_images/io_board_rgb2.png
The board features 4 WS2812 RGB LEDs, offering customizable control. Users can turn them on or off, change the color, adjust the brightness, switch display modes, and set the speed of changes.
  • To modify the on and off state of the RGB LEDs, true to turn on the RGB LEDs, false to turn them off.
sudo pironman5 -re true
  • To change their color, input the desired hexadecimal color values, such as fe1a1a.
sudo pironman5 -rc fe1a1a
  • To change the brightness of the RGB LED (range: 0 ~ 100%):
sudo pironman5 -rb 100
  • To switch RGB LED display modes, choose from options: solid/breathing/flow/flow_reverse/rainbow/rainbow_reverse/hue_cycle:
If you set the RGB LED display mode to rainbow, rainbow_reverse, or hue_cycle, you will not be able to set the color using pironman5 -rc.
sudo pironman5 -rs breathing
  • To modify the speed of change (range: 0 ~ 100%):
sudo pironman5 -rp 80
RGB Control Pin
The RGB LED is driven by SPI and connected to GPIO10, which is also the SPI MOSI pin. The two pins are used to connect the RGB to GPIO10. If not needed, the jumper can be removed.
../../_images/io_board_rgb_pin2.png
RGB OUT Pins
../../_images/io_board_rgb_out2.png
The WS2812 RGB LEDs support serial connection, allowing for the attachment of an external RGB LED strip. Connect the SIG pin to the external strip’s DIN pin for expansion.
The default setup includes 4 RGB LEDs. Connect additional LEDs and update the count using:
sudo pironman5 -rl 12
RGB Fan Pins
The IO expansion board supports to a 5V non-PWM fan.
You need to connect the fan’s wire to FAN port.
../../_images/io_board_fan2.png
The two sets of pins below J9 are the enable pins for the fan and its RGB. By default, jumpers are inserted on these pins, allowing GPIO6 and GPIO5 to control the on and off states of the fan and its LED. If the fan and LED are not required to be operated, the corresponding jumpers can be removed to release GPIO6 or GPIO5.
../../_images/io_board_fan_j92.png
You can use command to configure the operating mode of the RGB fan. These modes determine the conditions under which the RGB fan will activate.
For instance, if set to 1: Performance mode, the RGB fan will activate at 50°C.
sudo pironman5 -gm 3
  • 4: Quiet: The RGB fan will activate at 70°C.
  • 3: Balanced: The RGB fan will activate at 67.5°C.
  • 2: Cool: The RGB fan will activate at 60°C.
  • 1: Performance: The RGB fan will activate at 50°C.
  • 0: Always On: The RGB fan will always on.
If you connect the control pin of the RGB fan to different pins on the Raspberry Pi, you can use the following command to change the pin number.
sudo pironman5 -gp 18
Power Switch Conventor
Adding the Power Button
  • The Raspberry Pi 5 features a J2 jumper, situated between the RTC battery connector and the board edge. This breakout enables the addition of a custom power button to the Raspberry Pi 5 by connecting a Normally Open (NO) momentary switch across the two pads. Briefly engaging this switch mimics the onboard power button’s functionality.
    ../../_images/pi5_j22.jpg
  • The Pironman 5 Mini extends the J2 jumper to an external power button using two Pogo pins.
    ../../_images/power_switch_j2.jpeg ../../_images/power_switch_j2_2.jpeg
  • Now, the Raspberry Pi 5 can be powered on and off using the Power Button.
    ../../_images/pironman_button2.JPG
Power Cycling
Upon initially powering your Raspberry Pi 5, it will automatically turn on and boot into the operating system without the need to press the button.
If running the Raspberry Pi Desktop, a brief press of the power button initiates a clean shutdown process. A menu will appear, offering options to shutdown, reboot, or logout. Selecting an option or pressing the power button again will start a clean shutdown.
../../_images/button_shutdown2.png
Shutdown
  • If you run Raspberry Pi OS Desktop system, you can press the power button twice in quick succession to shutdown.
  • If you run Raspberry Pi OS Lite system without a desktop, press the power button a single time to initiate a shutdown.
  • To force a hard shutdown, press and hold the power button.
Power on
  • If the Raspberry Pi board is shut down, but still powered, single-press to power on from a shutdown state.
If you are running a system that does not support a shutdown button, you can hold it for 5 seconds to force a hard shutdown, and single-press to power on from a shutdown state.
NVMe Module
Pironman 5 mini integrates a PCIe adapter module for NVMe SSD. It supports four different sizes of NVMe SSDs: 2230, 2242, 2260, and 2280, all fitting into an M.2 M key slot.
../../_images/nvme_p.png
  • STA: A Status LED indicator.
  • PWR: A Power LED indicator.
    ../../_images/nvme_led.png
  • The module connects through a 16P 0.5mm reverse FFC (Flexible Flat Cable) or a custom impedance-matched FPC (Flexible Printed Circuit) cable.
    ../../_images/nvme_pcie.png
  • FORCE ENABLE: The onboard power supply is activated by the switch signal from the PCIe interface. After the Raspberry Pi is powered on, it sends a signal to turn on the 3.3V power supply. If some systems do not support the switch signal or for other reasons, you can short-circuit J2 FORCE ENABLE by soldering a wire between the two floating pads to force the onboard 3.3V power supply to power the NVMe.
    ../../_images/nvme_j2.png
About the Model
M.2 SSDs, known for their compact size, come in various types mainly differentiated by their keying (notch design on the connector) and the interface they use. Here are the primary types:
  • M.2 SATA SSDs: These use the SATA interface, similar to 2.5-inch SATA SSDs but in the smaller M.2 form factor. They are limited by the SATA III maximum speeds of around 600 MB/s. These SSDs are compatible with M.2 slots keyed for B and M keys.
  • M.2 NVMe SSDs: These SSDs use the NVMe protocol over PCIe lanes and are significantly faster than M.2 SATA SSDs. They are suitable for applications requiring high read/write speeds like gaming, video editing, and data-intensive tasks. These SSDs typically require M-keyed slots. These drives utilize the PCIe (Peripheral Component Interconnect Express) interface, with different versions like 3.0, 4.0, and 5.0. Each new version of PCIe effectively doubles the data transfer speed of its predecessor. However, the Raspberry Pi 5 uses a PCIe 3.0 interface, capable of delivering transfer speeds up to 3,500 MB/s.
M.2 SSDs come in three key types: B key, M key, and B+M key. However, later on, the B+M key was introduced, combining the functionalities of the B key and M key. As a result, it replaced the standalone B key. Please refer to the image below.
../../_images/ssd_key2.png
In general, M.2 SATA SSDs are B+M-keyed (can fit in sockets for B-keyed and M-keyed modules), while M.2 NVMe SSDs for PCIe 3.0 x4 lane are M-keyed.
../../_images/ssd_model22.png
About the Length
M.2 modules come in different sizes and can also be utilized for Wi-Fi, WWAN, Bluetooth, GPS, and NFC.
Pironman 5 supports four (PCIe Gen 2.0 / PCIe Gen 3.0) NVMe M.2 SSD sizes based on their names: 2230, 2242, 2260, and 2280. The “22” is the width in millimeters (mm), and the two following numbers are the length. The longer the drive, the more NAND flash chips can be mounted; therefore, the more capacity.
../../_images/m2_ssd_size2.png
1220RTC Battery Holder
../../_images/battery_holder.png
A 1220RTC battery holder is incorporated for convenient installation of an RTC battery. It connects to the Raspberry Pi’s RTC interface via an SH1.0 2P reverse cable.
The battery holder is compatible with both CR1220 and ML1220 batteries. If using an ML1220 (Lithium Manganese Dioxide battery), charging can be configured directly on the Raspberry Pi. Note that the CR1220 is not rechargeable.
Enabling Trickle Charging
Warning
If you’re using a CR1220 battery, do not enable trickle charging as it can cause irreparable damage to the battery and risk damaging the board.
By default, the trickle charging feature for the battery is disabled. The sysfs files indicate the current trickle charging voltage and limits:
pi@raspberrypi:~ $ cat /sys/devices/platform/soc/soc:rpi_rtc/rtc/rtc0/charging_voltage
0
pi@raspberrypi:~ $ cat /sys/devices/platform/soc/soc:rpi_rtc/rtc/rtc0/charging_voltage_max
4400000
pi@raspberrypi:~ $ cat /sys/devices/platform/soc/soc:rpi_rtc/rtc/rtc0/charging_voltage_min
1300000
To enable trickle charging, add rtc_bbat_vchg to /boot/firmware/config.txt:
  • Open the /boot/firmware/config.txt.
  • Add rtc_bbat_vchg to /boot/firmware/config.txt.
    dtparam=rtc_bbat_vchg=3000000
After rebooting, the system will display:
3000000
4400000
1300000
This confirms the battery is now under trickle charging. To disable this feature, simply remove the dtparam line from config.txt.
Pin Headers
../../_images/io_board_pin_header2.png
Two right-angle header connectors extend the Raspberry Pi’s GPIO, but note that the IR receiver, RGB LED, and fan occupy some pins. Remove the corresponding jumper caps to utilize these pins for other functions.
Pironman 5 Mini
Raspberry Pi 5
FAN(Optional)
GPIO6
FAN RGB(Optional)
GPIO5
RGB(Optional)
GPIO10
