👉 Join us here: [here]
Control with Commands
In addition to viewing data from the Pironman 5 Mini and controlling various devices through the Dashboard, you can also use commands to control them.
  • For the Home Assistant system, you can only monitor and control the Pironman 5 Mini through the dashboard by opening the webpage at http://<ip>:34001.
  • It is important to note that any changes to the configuration require a restart of the service using pironman5 restart to take effect.
View the Basic Configurations
The pironman5 module offers basic configurations for Pironman, which you can review with the following command.
sudo pironman5 -c
The standard configurations appear as follows:
    "system": {
        "rgb_color": "feff00",
        "rgb_brightness": 30,
        "rgb_style": "hue_cycle",
        "rgb_speed": 50,
        "rgb_enable": true,
        "rgb_led_count": 12,
        "temperature_unit": "C",
        "gpio_fan_pin": 5,
        "gpio_fan_mode": 0,
        "gpio_fan_led": "follow",
        "gpio_fan_led_pin": 6
Customize these configurations to fit your needs.
Use pironman5 or pironman5 -h for instructions.
usage: pironman5-service [-h] [-v] [-c] [-dl {debug,info,warning,error,critical}] [--background [BACKGROUND]] [-rd]
                        [-cp [CONFIG_PATH]] [-u [{C,F}]] [-gm [GPIO_FAN_MODE]] [-gp [GPIO_FAN_PIN]]
                        [-fl [GPIO_FAN_LED]] [-fp [GPIO_FAN_LED_PIN]]
                        [{start,restart,stop}]
Pironman 5 command line interface
positional arguments:
  {start,restart,stop}  Command
options:
  -h, --help            show this help message and exit
  -v, --version         Show version
  -c, --config          Show config
  -dl {debug,info,warning,error,critical}, --debug-level {debug,info,warning,error,critical}
                        Debug level
                        Run in background
  -rd, --remove-dashboard
                        Remove dashboard
  -cp [CONFIG_PATH], --config-path [CONFIG_PATH]
                        Config path
  -u [{C,F}], --temperature-unit [{C,F}]
                        Temperature unit
  -gm [GPIO_FAN_MODE], --gpio-fan-mode [GPIO_FAN_MODE]
                        GPIO fan mode, 0: Always On, 1: Performance, 2: Cool, 3: Balanced, 4: Quiet
  -gp [GPIO_FAN_PIN], --gpio-fan-pin [GPIO_FAN_PIN]
                        GPIO fan pin
  -fl [GPIO_FAN_LED], --gpio-fan-led [GPIO_FAN_LED]
                        GPIO fan LED state on/off/follow
  -fp [GPIO_FAN_LED_PIN], --gpio-fan-led-pin [GPIO_FAN_LED_PIN]
                        GPIO fan LED pin
Each time you modify the status of pironman5.service, you need to use the following command to make the configuration changes take effect.
  • Verify the pironman5 program status using the systemctl tool.
    sudo systemctl status pironman5.service
  • Alternatively, inspect the program-generated log files.
    ls /var/log/pironman5/
    cat /var/log/pironman5/main.log
Control RGB LEDs
The board features 4 WS2812 RGB LEDs, offering customizable control. Users can turn them on or off, change the color, adjust the brightness, switch RGB LED display modes, and set the speed of changes.
  • To modify the on and off state of the RGB LEDs, true to turn on the RGB LEDs, false to turn them off.
sudo pironman5 -re true
  • To change their color, input the desired hexadecimal color values, such as fe1a1a.
sudo pironman5 -rc fe1a1a
  • To change the brightness of the RGB LED (range: 0 ~ 100%):
sudo pironman5 -rb 100
  • To switch RGB LED display modes, choose from options: solid/breathing/flow/flow_reverse/rainbow/rainbow_reverse/hue_cycle:
If you set the RGB LED display mode to rainbow, rainbow_reverse, or hue_cycle, you will not be able to set the color using pironman5 -rc.
sudo pironman5 -rs breathing
  • To modify the speed of change (range: 0 ~ 100%):
sudo pironman5 -rp 80
  • The default setup includes 4 RGB LEDs. Connect additional LEDs and update the count using:
sudo pironman5 -rl 12
Control RGB Fan
The IO expansion board supports to a 5V non-PWM fan.
  • You can use command to configure the operating mode of the RGB fan. These modes determine the conditions under which the RGB fan will activate.
For instance, if set to 1: Performance mode, the RGB fan will activate at 50°C.
sudo pironman5 -gm 3
  • 4: Quiet: The RGB fan will activate at 70°C.
  • 3: Balanced: The RGB fan will activate at 67.5°C.
  • 2: Cool: The RGB fan will activate at 60°C.
  • 1: Performance: The RGB fan will activate at 50°C.
  • 0: Always On: The RGB fan will always on.
  • If you connect the control pin of the RGB fan to different pins on the Raspberry Pi, you can use the following command to change the pin number.
sudo pironman5 -gp 18
About Core Fan
The core fan connects to a dedicated 4-pin PWM fan port on the Raspberry Pi 5. Its default control strategy is a firmware-managed, multi-level intelligent speed adjustment scheme based on CPU temperature. This means that when you use an official or compatible PWM fan and connect it correctly, the system will automatically adjust the fan speed according to changes in CPU temperature (starting to operate above 50°C) without any manual intervention from you.
