1.4 Upload the Libraries to Pico
In some projects, you will need additional libraries. So here we upload these libraries to Raspberry Pi Pico 2 W first, and then we can run the code directly later.
  1. Download the relevant code from the link below.
  2. Open Thonny IDE and plug the Pico into your computer with a micro USB cable and click on the “MicroPython (Raspberry Pi Pico).COMXX” interpreter in the bottom right corner.
    ../../_images/sec_inter1.png
  3. In the top navigation bar, click View -> Files.
    ../../_images/th_files1.png
  4. Switch the path to the folder where you downloaded the code package before, and then go to the pico-2w-kit-main/micropython/libs folder.
    ../../_images/th_path1.png
  5. Select all the files or folders in the libs/ folder, right-click and click Upload to, it will take a while to upload.
    ../../_images/th_upload1.png
  6. Now you will see the files you just uploaded inside your drive Raspberry Pi Pico.
    ../../_images/th_done1.png
