👉 Ready to explore and create with us? Click [here ] and join today!
Installing Raspberry Pi OS
In this chapter, you will learn how to install the operating systems. All the installation steps depend on the Raspberry Pi Imager, which you need to install first.
You can choose an installation method based on whether you have a Micro SD card or an NVMe SSD available.
Using a Micro SD Card Only
If you are only using a Micro SD card, you can simply follow the first method below.
Using an M.2 NVMe SSD
If you have an M.2 NVMe SSD Enclosure Adapter, you can connect your SSD to your computer using the adapter and follow the second method to install the OS.
If you do not have the adapter shown above, you can first install the OS on a Micro SD card using the first method, then use the third method to copy the system from the Micro SD card to your M.2 NVMe SSD.
