fusion_hat._i2c のソースコード
""" I2C bus read/write functions
A simple wrap for smbus2 library.
Example:
    import I2C
    >>> from fusion_hat.i2c import I2C
    Init I2C bus with address 0x17
    >>> i2c = I2C(address=0x17)
    Write a byte 0x00
    >>> i2c.write_byte(0x00)
    Write a byte 0x01 to register 0x01
    >>> i2c.write_byte_data(0x01, 0x01)
    Write a word 0x0001 to register 0x01
    >>> i2c.write_word_data(0x01, 0x0001)
    Write a word 0x0001 to register 0x01 in LSB first
    >>> i2c.write_word_data(0x01, 0x0001, lsb=True)
    Write a block of bytes to register 0x01
    >>> i2c.write_block_data(0x01, [0x00, 0x01, 0x02])
    Read a byte
    >>> print(i2c.read_byte())
    0
    Read a byte from register 0x01
    >>> print(i2c.read_byte_data(0x01))
    Read a word from register 0x01
    >>> print(i2c.read_word_data(0x01))
    256
    Read a word from register 0x01 in LSB first
    >>> print(i2c.read_word_data(0x01, lsb=True))
    Read a block of bytes from register 0x01
    >>> print(i2c.read_block_data(0x01))
    [0, 1, 2]
from ._utils import retry
from smbus2 import SMBus
from ._base import _Base
[ドキュメント] class I2C(_Base): """ I2C bus read/write functions Args: address (int): I2C device address bus (int): I2C bus number *args: Parameters to pass to :class:`fusion_hat._base._Base`. **kwargs: Keyword arguments to pass to :class:`fusion_hat._base._Base`. """ RETRY = 5 DEFAULT_BUS = 1 def __init__(self, *args, address: int = None, bus: int = DEFAULT_BUS, **kwargs) -> None: super().__init__(*args, **kwargs) self._bus = bus self._smbus = SMBus(self._bus) if isinstance(address, list): connected_devices = self.scan() for _addr in address: if _addr in connected_devices: self.address = _addr break else: self.address = address[0] else: self.address = address @retry(RETRY) def write_byte(self, data: int) -> bool: """ Write a byte to the I2C bus Args: data (int): byte to write Returns: bool: True if the byte is written successfully, False otherwise """ self.log.debug(f"write_byte: 0x{data:02x}({data})") result = self._smbus.write_byte(self.address, data) return result @retry(RETRY) def write_byte_data(self, reg: int, data: int) -> bool: """ Write a byte to the I2C bus Args: reg (int): register address data (int): byte to write Returns: bool: True if the byte is written successfully, False otherwise """ self.log.debug(f"write_byte_data: 0x{reg:02x}({reg}), 0x{data:02x}({data})") result = self._smbus.write_byte_data(self.address, reg, data) return result @retry(RETRY) def write_word_data(self, reg: int, data: int, lsb: bool = False) -> bool: """ Write a word to the I2C bus Args: reg (int): register address data (int): word to write lsb (bool, optional): True if the word is written in little-endian, False otherwise, default is False Returns: bool: True if the word is written successfully, False otherwise """ msg = f"write_word_data: 0x{reg:02x}({reg}), 0x{data:04x}({data})" if lsb: l_byte = (data >> 0) & 0xFF h_byte = (data >> 8) & 0xFF data = (l_byte << 8) | h_byte msg += f", LSB={lsb} (sent: 0x{data:04x}({data}))" self.log.debug(msg) return self._smbus.write_word_data(self.address, reg, data) @retry(RETRY) def write_i2c_block_data(self, reg: int, data: list) -> bool: """ Write a block of data to the I2C bus Args: reg (int): register address data (list): block of data to write Returns: bool: True if the block of data is written successfully, False otherwise """ self.log.debug(f"write_i2c_block_data: 0x{reg:02x}({reg}), {data}") result = self._smbus.write_i2c_block_data(self.address, reg, data) return result @retry(RETRY) def read_byte(self) -> int: """ Read a byte from the I2C bus Returns: int: byte read from the I2C bus """ self.log.debug(f"read_byte: 0x{self.address:02x}({self.address})") result = self._smbus.read_byte(self.address) return result @retry(RETRY) def read_byte_data(self, reg: int) -> int: """ Read a byte from the I2C bus Args: reg (int): register address Returns: int: byte read from the I2C bus """ self.log.debug(f"read_byte_data: 0x{reg:02x}({reg})") result = self._smbus.read_byte_data(self.address, reg) return result @retry(RETRY) def read_word_data(self, reg: int, lsb: bool = False) -> int: """ Read a word from the I2C bus Args: reg (int): register address lsb (bool, optional): True if the word is read in little-endian, False otherwise, default is False Returns: int: word read from the I2C bus """ msg = f"read_word_data: 0x{reg:02x}({reg})" result = self._smbus.read_word_data(self.address, reg) if lsb: l_byte = (result >> 0) & 0xFF h_byte = (result >> 8) & 0xFF result = (l_byte << 8) | h_byte msg += f", LSB={lsb} (received: 0x{result:04x}({result}))" self.log.debug(msg) return result @retry(RETRY) def read_i2c_block_data(self, reg: int, num: int) -> list: """ Read a block of data from the I2C bus Args: reg (int): register address num (int): number of bytes to read Returns: list: block of data read from the I2C bus """ msg = f"read_i2c_block_data: 0x{reg:02x}({reg}), {num} bytes" result = self._smbus.read_i2c_block_data(self.address, reg, num) msg += f", {result}" self.log.debug(msg) return result @retry(RETRY) def is_ready(self) -> bool: """Check if the I2C device is ready Returns: bool: True if the I2C device is ready, False otherwise """ self.log.debug(f"Check if 0x{self.address:02x}({self.address}) is ready") addresses = self.scan() if self.address in addresses: self.log.debug(f"0x{self.address:02x}({self.address}) is ready") return True else: self.log.debug(f"0x{self.address:02x}({self.address}) is not ready") return False
[ドキュメント] @staticmethod def scan(bus: int = 1, force: bool = False) -> list: """Scan the I2C bus for devices Args: bus (int, optional): I2C bus number, default is 1 force (bool, optional): True if force to access the I2C bus, False otherwise, default is False Returns: list: List of I2C addresses of devices found """ devices = [] for addr in range(0x03, 0x77 + 1): try: with SMBus(bus) as smbus: # Read a byte from the address smbus.read_byte(addr, force=force) devices.append(addr) except OSError as expt: # Ignore device busy or unresponsive errors if expt.errno == 16: # Device or resource busy # print(f"Address 0x{addr:02X} busy") pass # Other errors continue to try continue return devices
[ドキュメント] def write(self, data: int | list | bytearray) -> None: """ Write data to the I2C device Args: data (int | list | bytearray): Data to write Raises: ValueError: if write is not an int, list or bytearray """ if isinstance(data, bytearray): data_all = list(data) elif isinstance(data, int): if data == 0: data_all = [0] else: data_all = [] while data > 0: data_all.append(data & 0xFF) data >>= 8 elif isinstance(data, list): data_all = data # Write data if len(data_all) == 1: data = data_all[0] self.write_byte(data) elif len(data_all) == 2: reg = data_all[0] data = data_all[1] self.write_byte_data(reg, data) elif len(data_all) == 3: reg = data_all[0] data = (data_all[2] << 8) + data_all[1] print(f"I2C write_word_data 0x{reg:02X} data: 0x{data:04X}") self.write_word_data(reg, data) else: reg = data_all[0] data = list(data_all[1:]) self.write_i2c_block_data(reg, data)
[ドキュメント] def read(self, length: int = 1) -> list: """ Read data from I2C device Args: length (int): Number of bytes to receive Returns: list: Received data """ result = [] for _ in range(length): result.append(self.read_byte()) return result
[ドキュメント] def mem_write(self, data: int | list | bytearray, memaddr: int) -> None: """ Write data to specific register address Args: data (int | list | bytearray): Data to send memaddr (int): Register address Raises: ValueError: If data is not int, list, or bytearray """ if isinstance(data, bytearray): data_all = list(data) elif isinstance(data, list): data_all = data elif isinstance(data, int): data_all = [] if data == 0: data_all = [0] else: while data > 0: data_all.append(data & 0xFF) data >>= 8 self.write_i2c_block_data(memaddr, data_all)
[ドキュメント] def mem_read(self, length: int, memaddr: int) -> list: """ Read data from specific register address Args: length (int): Number of bytes to receive memaddr (int): Register address Returns: list: Received bytearray data or False if error """ result = self.read_i2c_block_data(memaddr, length) return result
[ドキュメント] def is_avaliable(self) -> bool: """ Check if the I2C device is avaliable Returns: bool: True if the I2C device is avaliable, False otherwise """ return self.address in self.scan()
[ドキュメント] def _write_byte(self, data: int) -> None: """ [DEPRECATED] Write a byte to I2C register Args: data (int): Data to write """ print(f"[WARNING] _write_byte is deprecated, use write_byte instead") self.write_byte(data)
[ドキュメント] def _write_byte_data(self, reg: int, data: int) -> None: """ [DEPRECATED] Write a byte data to I2C register Args: reg (int): Register address data (int): Data to write """ print(f"[WARNING] _write_byte_data is deprecated, use write_byte_data instead") self.write_byte_data(reg, data)
[ドキュメント] def _write_word_data(self, reg: int, data: int) -> None: """ [DEPRECATED] Write word data to I2C register Args: reg (int): Register address data (int): Data to write """ print(f"[WARNING] _write_word_data is deprecated, use write_word_data instead") self.write_word_data(reg, data)
[ドキュメント] def _write_i2c_block_data(self, reg: int, data: list) -> None: """ [DEPRECATED] Write block data to I2C register Args: reg (int): Register address data (list): Data to write """ print(f"[WARNING] _write_i2c_block_data is deprecated, use write_i2c_block_data instead") self.write_i2c_block_data(reg, data)
[ドキュメント] def _read_byte(self) -> int: """ [DEPRECATED] Read a byte from the I2C bus Returns: int: byte read from the I2C bus """ print(f"[WARNING] _read_byte is deprecated, use read_byte instead") return self.read_byte()
[ドキュメント] def _read_byte_data(self, reg: int) -> int: """ [DEPRECATED] Read a byte from the I2C bus Args: reg (int): register address Returns: int: byte read from the I2C bus """ print(f"[WARNING] _read_byte_data is deprecated, use read_byte_data instead") return self.read_byte_data(reg)
[ドキュメント] def _read_word_data(self, reg: int) -> list: """ [DEPRECATED] Read a word from the I2C bus Args: reg (int): register address Returns: list: word read from the I2C bus """ print(f"[WARNING] _read_word_data is deprecated, use read_word_data instead") return self.read_word_data(reg)
[ドキュメント] def _read_i2c_block_data(self, reg: int, length: int) -> list: """ [DEPRECATED] Read block data from I2C register Args: reg (int): Register address length (int): Number of bytes to receive Returns: list: Received bytearray data or False if error """ print(f"[WARNING] _read_i2c_block_data is deprecated, use read_i2c_block_data instead") return self.read_i2c_block_data(reg, length)
