fusion_hat._cli のソースコード
# PYTHON_ARGCOMPLETE_OK
import argparse
[ドキュメント] def enable_speaker(): print(f"Enable Fusion-HAT speaker.") from .device import enable_speaker enable_speaker()
[ドキュメント] def disable_speaker(): print(f"Disable Fusion-HAT speaker.") from .device import disable_speaker disable_speaker()
[ドキュメント] def _get_pa_volume(): """Get current PulseAudio sink volume (first percentage), or None.""" import re as _re import os as _os try: raw = _os.popen("pactl get-sink-volume @DEFAULT_SINK@ 2>/dev/null").read() m = _re.search(r"(\d+)%", raw) if m: return m.group(1) except Exception: pass return None
[ドキュメント] def test_speaker(): print(f"Test Fusion-HAT speaker.") import os as _os from .device import enable_speaker, disable_speaker saved = _get_pa_volume() try: enable_speaker() if saved: _os.system("pactl set-sink-volume @DEFAULT_SINK@ 80% >/dev/null 2>/dev/null") _os.system("aplay -q /usr/share/sounds/alsa/Front_Center.wav 2>/dev/null") finally: if saved: _os.system(f"pactl set-sink-volume @DEFAULT_SINK@ {saved}% >/dev/null 2>/dev/null") disable_speaker()
[ドキュメント] def update(): """Update fusion-hat by running the installer script.""" import os as _os from ._version import __version__ URL = "https://raw.githubusercontent.com/sunfounder/sunfounder-installer-scripts/main/install-fusion-hat.sh" print("") print(f" Current version: {__version__}") print(f" Running installer: {URL}") print("") ret = _os.system(f"curl -fsSL {URL} | sudo bash") if ret != 0: print(f"\n [FAIL] Installer exited with code {ret}")
[ドキュメント] def scan_i2c(): print(f"Scan I2C bus.") from ._i2c import I2C i2c = I2C() devices = i2c.scan() devices = ["0x{:02X}".format(device) for device in devices] print(f"Found devices: {devices}")
[ドキュメント] def setup_speaker(skip_test: bool = False): import os as _os script = _os.path.join(_os.path.dirname(__file__), "scripts", "setup_fusion_hat_audio.sh") if not _os.path.isfile(script): print(f"Script not found: {script}") return print("Setting up speaker...") args = "--skip-test" if skip_test else "" status = _os.system(f"sudo bash {script} {args}") if status is not None and status != 0: print(f"Setup speaker failed with exit code {status}.") else: print("Speaker setup complete.")
[ドキュメント] def _deprecated(old, new): import sys print(f"[WARN] '{old}' is deprecated, use '{new}' instead.", file=sys.stderr)
[ドキュメント] def main(): """ fusion_hat command line interface """ parser = argparse.ArgumentParser(description='fusion_hat command line interface') sub = parser.add_subparsers(dest='option') # ── speaker subcommand group ── speaker_parser = sub.add_parser('speaker', help='Speaker control') speaker_sub = speaker_parser.add_subparsers(dest='speaker_action') sp = speaker_sub.add_parser('enable', help='Enable speaker') sp.set_defaults(_func=lambda a: enable_speaker()) sp = speaker_sub.add_parser('disable', help='Disable speaker') sp.set_defaults(_func=lambda a: disable_speaker()) sp = speaker_sub.add_parser('test', help='Test speaker') sp.set_defaults(_func=lambda a: test_speaker()) sp = speaker_sub.add_parser('setup', help='Run audio setup') sp.add_argument('--skip-test', action='store_true', help='skip speaker test') sp.set_defaults(_func=lambda a: setup_speaker(skip_test=a.skip_test)) # ── deprecated speaker commands (top-level) ── p = sub.add_parser('enable_speaker', help='[deprecated] use "speaker enable"') p.set_defaults(_func=lambda a: ( _deprecated('enable_speaker', 'speaker enable'), enable_speaker() )) p = sub.add_parser('disable_speaker', help='[deprecated] use "speaker disable"') p.set_defaults(_func=lambda a: ( _deprecated('disable_speaker', 'speaker disable'), disable_speaker() )) p = sub.add_parser('test_speaker', help='[deprecated] use "speaker test"') p.set_defaults(_func=lambda a: ( _deprecated('test_speaker', 'speaker test'), test_speaker() )) p = sub.add_parser('setup_speaker', help='[deprecated] use "speaker setup"') p.add_argument('--skip-test', action='store_true', help='skip speaker test') p.set_defaults(_func=lambda a: ( _deprecated('setup_speaker', 'speaker setup'), setup_speaker(skip_test=a.skip_test) )) p = sub.add_parser('version', help='Print library version') p.set_defaults(_func=lambda a: print_version()) p = sub.add_parser('update', help='Self-update from git') p.set_defaults(_func=lambda a: update()) p = sub.add_parser('scan_i2c', help='Scan I2C bus') p.set_defaults(_func=lambda a: scan_i2c()) p = sub.add_parser('info', help='Show device info') p.set_defaults(_func=lambda a: print_info()) p = sub.add_parser('doctor', help='Run hardware health checks') p.add_argument('--fix', action='store_true', help='auto fix driver issues') p.set_defaults(_func=lambda a: print_doctor(fix=a.fix)) p = sub.add_parser('force_dt_overlay', help='Force device-tree overlay') p.set_defaults(_func=lambda a: print_force_dt_overlay()) p = sub.add_parser('remove_dt_overlay', help='Remove device-tree overlay') p.set_defaults(_func=lambda a: print_remove_dt_overlay()) p = sub.add_parser('uninstall', help='Uninstall fusion-hat') p.set_defaults(_func=lambda a: print_uninstall()) try: import argcomplete argcomplete.autocomplete(parser) except ImportError: pass args = parser.parse_args() if args.option is None: parser.print_help() return if args.option == 'speaker' and getattr(args, 'speaker_action', None) is None: speaker_parser.print_help() return args._func(args)
