1. TTS with Espeak and Pico2Wave
In this lesson, we’ll use two built-in text-to-speech (TTS) engines on Raspberry Pi — Espeak and Pico2Wave — to make the Fusion HAT+ talk.
These two engines are both simple and run offline, but they sound quite different:
Espeak: very lightweight and fast, but the voice is robotic. You can adjust speed, pitch, and volume.
Pico2Wave: produces a smoother and more natural voice than Espeak, but has fewer options to configure.
You’ll hear the difference in voice quality and features.
1. Testing Espeak
Espeak is a lightweight TTS engine included in Raspberry Pi OS. Its voice sounds robotic, but it is highly configurable: you can adjust volume, pitch, speed, and more.
Run the program
cd ~/fusion-hat/examples sudo python3 tts_espeak.py
You should hear the Fusion HAT+ say: “Hello! I’m Espeak TTS.”
Try changing the tuning parameters in the code to experiment with how
amp,speed,gap, andpitchaffect the sound.
from fusion_hat.tts import Espeak
# Create Espeak TTS instance
tts = Espeak()
# Set amplitude 0-200, default 100
tts.set_amp(200)
# Set speed 80-260, default 150
tts.set_speed(150)
# Set gap 0-200, default 1
tts.set_gap(1)
# Set pitch 0-99, default 80
tts.set_pitch(80)
tts.say("Hello! I’m Espeak TTS.")
Code explanation:
tts.set_amp()— Controls the volume (0–200).tts.set_speed()— Adjusts the speaking speed (80–260).tts.set_gap()— Sets the word gap (0–200).tts.set_pitch()— Sets the pitch (0–99).tts.say()— Converts text to speech and plays it.
💡 Tip: Try increasing the pitch and speed to make the robot sound cheerful, or lowering them to make it sound serious.
2. Testing Pico2Wave
Pico2Wave produces a more natural and human-like voice compared to Espeak. It’s very easy to use, but less flexible — you can only change the language, not the pitch, speed, or volume. This makes Pico2Wave a great choice when you want clear and smooth speech without too much configuration.
Run the program
cd ~/fusion-hat/examples sudo python3 tts_pico2wave.py
You should hear the Fusion HAT+ say: “Hello! I’m Pico2Wave TTS.”
Try changing the language (for example,
es-ESfor Spanish) and listen to how the voice changes.
from fusion_hat.tts import Pico2Wave
# Create Pico2Wave TTS instance
tts = Pico2Wave()
# Set the language
tts.set_lang('en-US') # en-US, en-GB, de-DE, es-ES, fr-FR, it-IT
# Quick hello (sanity check)
tts.say("Hello! I'm Pico2Wave TTS.")
Code explanation:
tts.set_lang()— Sets the output language for speech synthesis.en-US(default)en-GBde-DEes-ESfr-FRit-IT
tts.say()— Converts the text to speech and plays it immediately.
Troubleshooting
No sound when running Espeak or Pico2Wave
Check that your speakers/headphones are connected and volume is not muted.
Run a quick test in terminal:
espeak "Hello world" pico2wave -w test.wav "Hello world" && aplay test.wav
If you hear nothing, the issue is with audio output, not your Python code.
Espeak voice sounds too fast or too robotic
Try adjusting the parameters in your code:
tts.set_speed(120) # slower tts.set_pitch(60) # different pitch
Permission denied when running code
Try running with
sudo:sudo python3 test_tts_espeak.py
Comparison: Espeak vs Pico2Wave
Feature |
Espeak |
Pico2Wave |
Voice quality |
Robotic, synthetic |
More natural, human-like |
Languages |
Default English |
Fewer, but common ones |
Adjustable |
Yes (speed, pitch, etc.) |
No (only language) |
Performance |
Very fast, lightweight |
Slightly slower, heavier |
