7. AI Voice Assistant
This lesson turns your Fusion HAT+ into a voice-first AI assistant. With the provided code, the robot will: wait for a wake word, transcribe your speech with Vosk, send it to an OpenAI LLM, and speak back using Piper TTS.
Before You Start
Make sure you have:
  • 1. Testing Piper — Piper voice works (e.g., you can play “Hello”).
  • 2. Test Vosk — Vosk STT works for your language (e.g., en-us).
  • 5. Connecting to Online LLMs — Your OpenAI API key saved in secret.py as OPENAI_API_KEY.
  • A working microphone and speaker on Fusion HAT.
  • A stable network connection (LLM is online).
Run the Example
cd ~/fusion-hat/examples/
sudo python3 voice_assistant.py
Configuration used by the code:
  • LLM: OpenAI (gpt-4o-mini)
  • TTS: Piper (en_US-ryan-low)
  • STT: Vosk (en-us)
  • Wake word: "hey buddy"
  • Keyboard input: enabled (optional manual input)
  • Image mode: enabled (WITH_IMAGE=True) — requires a multimodal-capable LLM if you decide to use images later
What happens:
  1. The assistant shows a welcome message with the wake phrase.
  2. It listens for “hey buddy”.
  3. After wake, your speech is transcribed (Vosk → text).
  4. The text is sent to OpenAI (gpt-4o-mini) for a response.
  5. The answer is spoken with Piper (en_US-ryan-low).
Example interaction
You: Hey Buddy
Robot: Hi there!
You: What’s the capital of Italy?
Robot: The capital of Italy is Rome.
from fusion_hat.voice_assistant import VoiceAssistant
from fusion_hat.llm import OpenAI as LLM
from secret import OPENAI_API_KEY as API_KEY
llm = LLM(
    api_key=API_KEY,
    model="gpt-4o-mini",
# Robot name
NAME = "Buddy"
# Enable image, need to set up a multimodal language model
WITH_IMAGE = True
# Set models and languages
LLM_MODEL = "gpt-4o-mini"
TTS_MODEL = "en_US-ryan-low"
STT_LANGUAGE = "en-us"
# Enable keyboard input
KEYBOARD_ENABLE = True
# Enable wake word
WAKE_ENABLE = True
WAKE_WORD = [f"hey {NAME.lower()}"]
# Set wake word answer, set empty to disable
ANSWER_ON_WAKE = "Hi there"
# Welcome message
WELCOME = f"Hi, I'm {NAME}. Wake me up with: " + ", ".join(WAKE_WORD)
# Set instructions
INSTRUCTIONS = f"""
You are a helpful assistant, named {NAME}.
va = VoiceAssistant(
    llm,
    name=NAME,
    with_image=WITH_IMAGE,
    tts_model=TTS_MODEL,
    stt_language=STT_LANGUAGE,
    keyboard_enable=KEYBOARD_ENABLE,
    wake_enable=WAKE_ENABLE,
    wake_word=WAKE_WORD,
    answer_on_wake=ANSWER_ON_WAKE,
    welcome=WELCOME,
    instructions=INSTRUCTIONS,
if __name__ == "__main__":
    va.run()
Code explanation:
  • OpenAI(..., model="gpt-4o-mini") — Uses OpenAI as the only LLM in this lesson.
  • NAME / WAKE_WORD — Personalize the assistant (“Buddy”, “hey buddy”).
  • WITH_IMAGE=True — Enables image mode in the assistant (no image I/O logic included here).
  • TTS_MODEL="en_US-ryan-low" — Piper voice used for replies.
  • STT_LANGUAGE="en-us" — Vosk language for recognition.
  • KEYBOARD_ENABLE=True — Allows optional manual text input during debugging.
  • WELCOME / INSTRUCTIONS — Startup message and assistant persona/system prompt.
  • va.run() — Starts the loop: wake → listen → LLM → speak.
Switching to Other LLMs or TTS
You can easily switch to other LLMs, TTS, or STT languages with just a few edits:
  • Supported LLMs:
    • OpenAI
    • Doubao
    • Deepseek
    • Gemini
    • Qwen
    • Grok
  • 1. Testing Piper — Check the supported languages of Piper TTS.
  • 2. Test Vosk — Check the supported languages of Vosk STT.
To switch, simply modify the initialization part in the code:
from fusion_hat.llm import Gemini as LLM
llm = LLM(api_key="YOUR_KEY", model="gemini-pro")
Troubleshooting
  • Robot doesn’t respond to wake word
    • Check if the microphone works.
    • Make sure WAKE_ENABLE = True.
    • Adjust the wake word to match your pronunciation.
    • Reduce background noise and speak clearly.
  • No sound from the speaker
    • Check the TTS model name (e.g., en_US-ryan-low).
    • Test Piper or Espeak manually.
    • Verify speaker connection and volume.
  • API key error or timeout
    • Check your key in secret.py.
    • Make sure your network connection is stable.
    • Confirm the LLM model is supported (e.g., gpt-4o-mini).
  • Wake word works but no response
    • Check if the STT language matches your accent.
    • Make sure the model downloaded correctly.
    • Try printing debug logs to confirm STT is running.
  • TTS works but no LLM reply
    • Check if the API key is valid.
    • Verify model name and LLM settings.
    • Ensure internet connectivity.
