Video 50: Temperature and Humidity Monitoring with Adafruit IO
Learn how to set up an ESP32 IoT project using MQTT and Adafruit IO, from hardware setup to code uploading and dashboard creation.
ESP32 Starter Kit Introduction: Overview of the components needed for the project.
MQTT Explanation: Understand the significance of MQTT in IoT applications.
Adafruit IO Setup: Step-by-step guide to creating an account and dashboard on Adafruit IO.
Hardware Wiring Guide: Detailed instructions on wiring the ESP32, DHT11 temperature sensor, and LED.
Arduino Code Walkthrough: Explanation of the code including library installation, Wi-Fi setup, and MQTT connection.
Project Demonstration: Watch the process of uploading the code, monitoring data on Adafruit IO dashboard, and remotely controlling the LED.
Video
