Video 26: Using Joystick
Learn how to wire a joystick to an ESP32 microcontroller, covering detailed explanations, wiring configurations, code implementation, and testing.
Joystick components: Understand the components of the joystick, including variable resistors and switches.
Wiring configuration: Follow step-by-step instructions on how to wire the joystick to the ESP32 microcontroller, covering connections for analog pins, switches, power, and ground.
Code implementation: Learn how to write and upload code to the ESP32 microcontroller using the Arduino IDE, including code for reading joystick values and taking actions based on those values.
Testing and troubleshooting: Discover how to test the joystick setup using the serial monitor and troubleshoot common issues, such as incorrect wiring or code errors.
Video
